Old May 13, 2016, 02:08 PM
jobinseattle is offline
Find More Posts by jobinseattle
jobinseattle's Avatar
Joined Nov 2014
Question
Patternship Plane Recommendations
I have about $300 -$400 total I can spend and would like to get into this kind of flying. Can anyone recommend a plane for a first patternship type plane?
Looking for a balsa or composite plane. I plan on using an electric setup.
jobinseattle is offline Find More Posts by jobinseattle
Old May 14, 2016, 12:32 AM
RED_HLG is online now
Find More Posts by RED_HLG
Adam RED Weston
RED_HLG's Avatar
Brier, WA
Joined May 2006
Sorta depends on your experience and where you have to fly. If you're in Seattle, our indoor season is wrapping up for the barn owls with only a few seconds up in Marysville (Barnowlsnw.org) and start back up in October.
With no real data about the pilot, I might suggest a flat foam 3d ship that you can fly outdoors over the summer in the 120 - 200g weight range say. Fly in the morning or evening when there isun't any wind and get use to flying low and slow. If you're a new pilot, consider EPP, otherwise depron flies better. Get a traditional motor and save up your money for when indoor season arrives.
Fancy Foam comes to mind, but there are several other companies out there too... , http://fancyfoam-com.3dcartstores.co...Kits_c_15.html
Keep posting, been pretty quiet around F3P.
RED
RED_HLG is online now Find More Posts by RED_HLG
Old May 14, 2016, 01:38 AM
Joined Nov 2014
That is a screen name I had when I lived in Washington many years ago. I have been flying a couple of years now.
Old May 14, 2016, 02:37 AM
Joined Nov 2014
What do you think of the 48" Vanquish MKII from Extreme flight?
http://extremeflightrc.com/48-Vanquish-MKII_p_274.html
Old May 14, 2016, 07:58 AM
Adam RED Weston
RED_HLG's Avatar
Brier, WA
Joined May 2006
Looks cool, it probably won't fly too much like an indoor pattern plane... But I've never flown one. I'm sure others have. RED
Old May 14, 2016, 08:53 AM
3Dreaming is offline
Find More Posts by 3Dreaming
Joined Feb 2007
Just so you know you stumbled into the indoor pattern section. From your question and other post I don't think most here are flying what you are looking for.
3Dreaming is offline Find More Posts by 3Dreaming
Old May 14, 2016, 08:55 AM
Joined Nov 2014
Ops, think wrong forum. Thanks
Discussion Retract recommendations for Great Planes Ultra Sport 1000 Skeezix Sport Planes 4 Apr 21, 2016 11:23 AM
Discussion 6s Battery Recommendation for Classic Pattern Plane Fatherof4 Batteries and Chargers 9 Apr 20, 2016 03:22 AM
Discussion recommend a small and stable plane for long range fpv? ahtiram FPV Aircraft 6 Mar 09, 2016 09:04 AM
Discussion Will a 12x8 prop work on a plane that recommends a 6x3 SavageThrasher Electric Plane Talk 5 Feb 27, 2016 02:20 PM
Discussion Plane Recommendation RJaggers Giant Scale Airplanes 6 Feb 21, 2016 10:22 PM
