Old Aug 22, 2012, 09:48 PM
iamsuperbleeder is offline
Find More Posts by iamsuperbleeder
Licensed Lunatic
iamsuperbleeder's Avatar
United States, FL, Lake City
Joined Mar 2012
35mm motors on X525 frame
So the motor mounts accept them, but has anyone ever ran them?
Even if you didn't use the stock motor mounts and just mounted them directly to the arms, how did it turn out? And if you did so, how did you mount them to the arms, zip ties? Drilled new holes and bolted? Any vibration dampening between the arm and mount?
After overheating and burning up an old motor, I decided to go bigger and got a set of 3536 1000kv Turnigy Aerodrives, and compared to the old 2822 1200kv's, they're MASSIVE
iamsuperbleeder is offline Find More Posts by iamsuperbleeder
Old Aug 23, 2012, 12:22 AM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
dont they have a common 19mm hole pattern..... usually 2 screws are enough...unless you are doing heavy lifting
jy0933 is offline Find More Posts by jy0933
Old Oct 10, 2012, 07:51 PM
s_mack is offline
Find More Posts by s_mack
Registered Loser
Canada, BC, Central Okanagan H
Joined Jun 2010
So how'd this turn out? I've got a 525 frame on the way and I'm hoping to use 4 35mm's I have already rather than buying new motors. eCalc says I'm going to have to run 11" props though... my math says that should fit, but someone with experience might be able to alert me to problems before it arrives. Cheers.
- Steven
s_mack is offline Find More Posts by s_mack
Sold ESC's, Motors, X525 Frame,KK Board $100 Shipped acuralegendz Aircraft - Electric - Multirotor (FS/W) 7 Apr 29, 2012 11:44 AM
Found Need motor mount for X525 frame XtremeWingRC Aircraft - Electric - Multirotor (FS/W) 15 Mar 11, 2012 06:58 PM
Question Need advice on new quad frame, to replace x525!!! Arxangel Multirotor Talk 3 Mar 01, 2012 04:29 PM
Sold Foldable Quad copter X525 V3 frame bdpowers Aircraft - Electric - Multirotor (FS/W) 7 Sep 19, 2011 12:23 AM
