Old Jun 12, 2014, 08:34 PM
Ich Fliege
goebelmj's Avatar
United States, TX, Texas City
Joined Sep 2013
Build Log
L-4 Grasshopper ~ My First Scratch Drawn Plan Build
Here are my plans for an L-4 Grasshopper I drew up from a 3 view pic. This is the first plan I've drawn up so it will be a work in progress until I get the" hopper" in the air. I will try to update regularly and welcome any feedback on improvements to the plan.
The plan itself is a combination of ideas I gathered up from my first 6 foamy builds from plans found through this site. It is built from 6 mm Depron and 1" pink foam, held together with CA, Epoxy, Gorilla Glue and Foam Tack.
SPECS:
Wing span = 48"
Length = 31.5"
AUW (with battery & painted) = 24oz
Prop = 10x6 Master Airscrew
Motor = 850kv
ESC = 20 Amp
Battery = 2200mAh, 20c, 3s1p Li-Po
COG = 50mm - 60mm from leading edge
Static thrust = 23.7 (calculated) @ 10amps
Motor thrust offset = NONE
My Setup:
Aileron/Rudder Mix = 20%
Aileron dual rate = 80%, expo = 40%
Elevator dual rate = 50%, expo = 30%
Rudder dual rate = 30%, expo = 30%
Note: I am in the process of building the prototype and will amended the plans as I go. So far so good, the pics match the plans.
MJG
Update:
I really didn't know what I was going to do about mounting the tail wheel. I ended up using two pieces of 1/8" ply laminated and drilled out for a .147 tail wheel wire. I notched the lower fuse to accept the laminated ply and epoxied it in.
Credits...
Like I said above, there were many contributors to this design. As I built from the many excellent plans here, I collected numerous ideas and incorporated them into this build.
Monoblock idea - Tony65x55's Bluebaby
VLF design ideas - dz1sfb's VLF Combat Planes
KFM2 design ideas - davereap
KFM2 design ideas - headlessagain
Thanks all, this was a fun project...
goebelmj is online now Find More Posts by goebelmj
Last edited by goebelmj; Jul 07, 2014 at 12:28 PM. Reason: Updated setup information
Old Jun 12, 2014, 08:49 PM
Ich Fliege
goebelmj's Avatar
Joined Sep 2013
Progress So Far
I work kinda slow but I'm hackin' at it...
The wing dihedral won't be scale like the 3 view but should help it fly really well.
MJG
Old Jun 13, 2014, 02:03 AM
skumgummi dave
Gresham, OR.
Joined Mar 2004
goebelmj:
Looks like you have a good start on things. I think you also did a good job on your plans. Looking forward to your build and first flight report.
Regards;
Dave-
foamdave is online now Find More Posts by foamdave
Old Jun 13, 2014, 09:30 AM
jeffsch's Avatar
Seattle, USA
Joined Oct 2009
Looks promising!
jeffsch is offline Find More Posts by jeffsch
Old Jun 15, 2014, 07:20 AM
Ich Fliege
goebelmj's Avatar
Joined Sep 2013
Thanks fellas and Happy Fathers Day!!
Making some progress, updated the build pics in the second post...
Have a great day Dads,
mjg
Old Jun 19, 2014, 10:15 PM
Ich Fliege
goebelmj's Avatar
Joined Sep 2013
Build Update
Making slow progress. Really had a tough time building the landing gear, couldn't get the solder to take. Any suggestions would be greatly appriciated.
Old Jun 19, 2014, 10:27 PM
JayJay76's Avatar
Stuttgart, Germany
Looking good so far! Just a guess but your copper wrapping wire looks like it totally rejected the solder flow, could it be that you used enamelled wire instead of bare copper? Where did you get it from? Really good looking gear for your first try, keep up the good work!
JayJay76 is offline Find More Posts by JayJay76
Old Jun 20, 2014, 07:48 AM
Ich Fliege
goebelmj's Avatar
Joined Sep 2013
Thanks Jay,
You know, I thought the surface of the copper seemed to feel different than what I was used to. I had a length of stranded ground wire left over from my shop rebuild so I stripped it and used the single strands for the gear. I'll bet it is enameled. I'm gonna rip it apart this evening and find some bare copper and try again.
Thanks again Jay,
Old Jun 25, 2014, 06:34 PM
Ich Fliege
goebelmj's Avatar
Joined Sep 2013
Build Update
Final paint almost complete. Shooting for a maiden this weekend but may not make it. Pic update in post #2.
Old Jun 28, 2014, 11:01 AM
Ich Fliege
goebelmj's Avatar
Joined Sep 2013
Finished & Ready For Maiden!
Now if the wind would just cooperate. I'll post results of the maiden and hopefully a video.
Old Jun 29, 2014, 02:36 PM
kdahlhaus's Avatar
United States, OH, Westlake
Joined Mar 2002
That looks nice. Good luck on the maiden.
kdahlhaus is offline Find More Posts by kdahlhaus
Old Jun 29, 2014, 04:22 PM
Slipping the Surly Bonds
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Me like too!
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Jun 29, 2014, 05:30 PM
crash expert
New Zealand, Canterbury, Christchurch
Joined Apr 2014
She looks fantastic!
felixx is offline Find More Posts by felixx
Old Jun 30, 2014, 01:33 AM
skumgummi dave
Gresham, OR.
Joined Mar 2004
Yep, that's a keeper. Clean build. Thanks for sharing...
Dave-
Old Jun 30, 2014, 05:55 PM
Ich Fliege
goebelmj's Avatar
Joined Sep 2013
Thanks all for the wonderful comments!! I added credits in the first post for all those the who helped make this build what it is.
The wind is still 12-16 for the next couple of days so she'll have to sit in the hangar for a while.
Thanks again,
Build Log L-19 Bird Dog, Scratch Build from Rich Uravitch Plans Joker 53150 Balsa Builders 49 Jul 06, 2014 06:16 PM
Build Log My first sort of Scratch quad build. nafan08 Scratchbuilt Multirotors 15 Nov 15, 2013 07:59 AM
Discussion E lfite l-4 Grasshopper vs V-mar L-4 Grasshopper Stavroforos Scale Kit/Scratch Built 2 Oct 11, 2011 09:52 AM
Build Log my first attempt to plan and build - Grasshopper insomaniac45 Foamies (Scratchbuilt) 9 Sep 10, 2010 07:35 PM
