Old Apr 04, 2014, 08:36 PM
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
Sky Hero Spyder 1000 Build
Spent a few hours on eCalc and came up with a plan for the Sky Hero Spyder 1000 frame that should give me at least 15 min flights. This rig is designed for long duration AP work so reliability and consistency is critical.
Here's the parts list so far:
  • Sky Hero Spyder 1000 frame (quad)
  • DJI Naza V2 w/GPS
  • DJI Zenmuse H3 2D
  • GoPro Hero3+ Black
  • Tiger U5 400kv motors
  • RangeVideo 20x5.5 props
  • 6s2p 10000 mah lipo
  • Castle Creations QuadPack 35Amp ESC
I had to purchase the pancake motor upgrade kit to allow the U5 motors to fit. Unfortunately Sky Hero only makes them in olive drab so I'm painting them to match the rest of the frame.
Next batch of parts should arrive on Wednesday.
seojeff is online now Find More Posts by seojeff
Old Apr 05, 2014, 05:49 PM
seojeff's Avatar
Joined Aug 2011
Made more progress today. Also ordered a set of Tiger 45A ESCs since I'm not sure the Castle 35s will be enough.
The pancake motor mounts came out okay with some Krylon.
These RangeVideo props were pretty easy to balance but I can't say there a big leap in quality. I would say they are very similar to props I've purchased from RCtimer in the past.
Old Apr 14, 2014, 04:21 PM
seojeff's Avatar
Joined Aug 2011
Finally received all the parts I need. Here's the progress today.
Old Apr 20, 2014, 08:25 PM
seojeff's Avatar
Joined Aug 2011
The U5 400 kv motors were not able to handle 20" props. The quad fell out of the sky after about 2 mins. Same scenario on 18" and then again on 15"s after 4 mins.
The issue appears to be how the ESC is mounted in the boom. If you notice there are 'vents' next to the motor where the mount meets the boom. The idea being that air flows from the prop down inside the boom to the inside of the fuselage. This flow is critical to keep the ESC from overheating. It's important to make sure that you don't stuff the booms with wire - so that air can flow around the ESC to keep them cool.
Stay tuned for version 2.
Old Apr 22, 2014, 03:19 PM
seojeff's Avatar
Joined Aug 2011
Here's what happens when you have no airflow through the arms.
Old Apr 23, 2014, 06:09 PM
hollgi's Avatar
Joined Sep 2012
U5's are not meant for 20" props.
14/15/16” is closer to the mark...
hollgi is offline Find More Posts by hollgi
Old Apr 25, 2014, 10:10 AM
seojeff's Avatar
Joined Aug 2011
Yeah, it was totally my error. They don't like 18"s either.
Old Apr 25, 2014, 11:00 AM
Mrtarango32's Avatar
United States, CA, Glendora
Joined Oct 2012
Some people are having issues with simonk and u5 motors also. So they may contribute.
But yes 20" props won't work on those motors
Mrtarango32 is offline Find More Posts by Mrtarango32
Old Apr 28, 2014, 08:29 PM
seojeff's Avatar
Joined Aug 2011
After a lot of bench testing I've discovered that the issue is the T-Motor ESCs. Running at 50% throttle they reach 150 degrees rather quickly. If I hook up the U5 motor running a 15x6.5 to a Castle 35amp ESC they top out at 126 degrees at 50% throttle.
Old Jun 17, 2014, 12:19 AM
Joined Apr 2013
so any update on how to mount the esc? im planning to use mn4014 400kv with 45amp tiger 600hz esc but quite worried to stuff everything inside the boom.
garseng is offline Find More Posts by garseng
Old Jun 17, 2014, 09:17 PM
seojeff's Avatar
Joined Aug 2011
I cannot recommend tiger ESCs mounted in the booms.
Old Jun 21, 2014, 01:49 PM
seojeff's Avatar
Joined Aug 2011
Here's the current version in flight. It's ultra-stable and reliable. Lately I'm flying with a Zippy 6s 8000mah and getting about 15 mins of flying time. I'm still determining the max time I can get on those batteries.
Old Jun 22, 2014, 12:29 AM
Joined Jun 2012
Nice... Do you have any flight video, not FPV but filmed from the ground. I would really like to se how it looks in flying and, how agile it is.
PAPE is offline Find More Posts by PAPE
Old Jun 22, 2014, 02:16 AM
Corvallis Oregon
Joined Jun 2008
I would not recommend mounting any ESC in the boom. Here is an example of how I configured my Sky-Hero. It works out great with plenty of cooling for the ESC's.
Your 1000 looks great.............
mangoats is offline Find More Posts by mangoats
Old Jun 23, 2014, 08:24 PM
seojeff's Avatar
Joined Aug 2011
Here's some footage:
Spyder 1000 filmed via TBS Discovery Pro (4 min 33 sec)
Review Sky Hero “The Hero factory” Spyder and Spy Multi Rotors Sleepyc Multirotor Talk 361 Today 06:51 AM
Sold Sky Hero 700mm Spyder dizzane Aircraft - Electric - Multirotor (FS/W) 3 Jan 19, 2014 09:36 PM
sky lipo 1000 mah 40c<<<<<< ED3 Non R/C Items (FS/W) 8 Dec 02, 2013 11:42 AM
Discussion Sky Herp Spyder 1000 aeng Multirotor Talk 7 Aug 24, 2013 05:18 AM
