Old Jan 17, 2004, 03:59 PM
t_predator90 is offline
Find More Posts by t_predator90
-=Futaba RuLEz=-
t_predator90's Avatar
Netanya, Israel
Joined Sep 2002
Idea
Bold new engine design
BOLD NEW ENGINE DESIGN
Hey folks.
Right, what will be said and shown here must not be repeated or reposted anywhere else, ok?
A friend of mine works for a new model aircraft engine design company. He designed a new, super-lightweight engine. It is made of the latest space-age lightweight composite materials, produced for NASA. Lighter then aluminium, yet stronger then titanium. The new construction method (that I am not allowed to repeat here for obvious reasons) is revolutionary and cuts manufacturing costs by half. Folks, you are witnessing a new generation of R/C engines in the making! This guy is a genius! This prototype is a revolutionary 6-stroke engine for R/C aircraft, designed to swing big props for TOC-style aircraft. And it only weighs 200 grams!!! This thing is amazing! With super low cost, and super-fast construction, this engine is sure to send shockwaves throughout the industry! And, the big plus is the huge amount of power, with a fraction of the weight!
As an exclusive for R/C Groups I was able to sneak in some pictures of the new design. THESE PICTURES MUST NOT BE SHOWN ANYWHERE ELSE OR SENT TO ANYONE ELSE! TOP SECRET!
(Shown here with prop and spinner designed specifically for this engine. The prop has radio controlled adjustable pitch, and is pictured here with neutral pitch)
t_predator90 is offline Find More Posts by t_predator90
Old Jan 17, 2004, 07:48 PM
glowpwer flyer is offline
Find More Posts by glowpwer flyer
glowpwer flyer's Avatar
Morristown,TN
Joined Oct 2003
Dude that look like lego but either way it kinda funny and awsome.
Kevin
glowpwer flyer is offline Find More Posts by glowpwer flyer
Old Jan 17, 2004, 08:04 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Aaah. You spoiled the joke by adding the picture.
DaveSawers is offline Find More Posts by DaveSawers
Old Jan 17, 2004, 08:48 PM
mode1 is offline
Find More Posts by mode1
mode1's Avatar
Southwest Missouri
Joined Oct 2002
Sad news folks. I have the first pre-production model for testing. The inventor named it the OGEL 49.
I am having a hard time getting it to run more than a few seconds at a time. I have tried several different glow plugs. The best so far is the OS type "F". I started with 10% nitro and worked my way up to stronger blends trying to get it to run better.
The best fuel so far is PowerMaster 20/20 which is what I run in my YS engines.
I broke the first prop but found an inexpensive replacement at Toys-R-Us. I will keep trying and report again later.
mode1 is offline Find More Posts by mode1
Old Jan 17, 2004, 10:10 PM
Morristown,TN
Joined Oct 2003
Dude one word:HILARIOUS, now 3 word:VERY VERY FUNNY
Old Jan 18, 2004, 04:50 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
We've had some good results with South Utopian Lindseed oil and Nitro in a 60/40 mix
Up&Away is offline Find More Posts by Up&Away
Old Jan 18, 2004, 06:41 AM
-=Futaba RuLEz=-
Netanya, Israel
Joined Sep 2002
Hi mode1
What plane do you have it on? Which prop did you choose for it? Here we have no problem with even 5% mixtures. He (anonim, the designer) recomends a 4-bump flat plug, but I used a 4-bump thick plug, and doubled the RPM. Try these and let us know. If you experiance any further issues, you might have to send the engine to us for testing. Also, try playing with the fuel injector valve. I've found that if you turn the spiked wheel (Inter-prompansational thumpurtemprature inverter) about 3 clicks up, you get beter results. Of course, this all depends on your subjectional anti-plorespetien's floresintisity.
Here are the test result of yesterday's bench test:
EDS: | PFMB: | TCMTS:
345.9 | A745 | 742
976.23| G256.3 | 634
63.7 | G452 | 9782
6753.356 | E985 | 55
985.46 | C652 | 764+
I think the results speak for themselfs...
Old Jan 18, 2004, 07:31 AM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Uh, I think you have a misprint there T_Predator. That last bench test came out 985.46 | C652 | 764- not 764+
Old Jan 18, 2004, 10:02 AM
-=Futaba RuLEz=-
Netanya, Israel
Joined Sep 2002
Ugh, your right... Silly me... Sorry, my hand is tired after that bench test....
Old Jan 18, 2004, 01:49 PM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
You shouldn't wind those rubber bands so hard...
Old Jan 19, 2004, 03:16 AM
mode1 is offline
mode1's Avatar
Southwest Missouri
Joined Oct 2002
Ogel 49 test update:
Much better luck today! The carb intake hole was never drilled out! I reemed it out with a #8 fingernail file. Also, the muffler outlet hole was small so I doubled the size.
For fuel, I have been useing Armorall. Really improved the performance. Also, the outside casting looks a lot better now.
The most RPM obtained so far is 16revs-per-minute obtained by freewheeling in the wind on my patio.
I plan on adding a pressure tap to the muffler in the new future.
More test data coming soon.
Old Jan 19, 2004, 03:34 AM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Armorall! You have been experimenting! Just make sure your levels of subjectional anti-plorespetien's floresintisity stay within the accepted levels. Too much sediment could alter the ultra-physoplasty of the basic inner-molecular disco-mirror-ball.
Old Jan 19, 2004, 08:13 AM
Tony Oliver is offline
Find More Posts by Tony Oliver
Tony Oliver's Avatar
North-East England
Joined Mar 2002
Just a thought - if you remove the left handed oojah sprocket and replace it with two super mangelworzles with right handed gigglepin drivers, you will lose a further 122gm and improve the aspiration by at least 16%. THis should increase the power to 27cubic roubles per fathom.
What are you waiting for?
Get on with it!
Tony
(ps: I like the inverted dimples on the prop - was that derived from golf-ball technology?)
Tony Oliver is offline Find More Posts by Tony Oliver
Old Jan 19, 2004, 08:22 AM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
Shhh. That's still part of a top secret design from NASA. It is based on the same theory that gives those little air disturbingy thingamajingies on airline wings.
Old Jan 19, 2004, 08:24 AM
Up&Away is offline
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
You can't. You will have problems with the 70's mirorred disco ball otherwise.
So happy with new LiteGlider design! Harm Botman Parkflyers 22 Nov 08, 2002 02:59 AM
For Sales: .40 Trainer (New) Engine and Radio installed!!!! Captain Carlton Aircraft - Fuel - Airplanes (FS/W) 0 Aug 06, 2002 11:57 PM
So happy with new LiteGlider design! Harm Botman Electric Sailplanes 0 May 18, 2002 12:20 PM
So happy with new LiteGlider design! Harm Botman Electric Sailplanes 0 May 18, 2002 12:07 PM
New Foamie Design d_trafalgar Foamies (Kits) 8 Apr 03, 2002 01:53 AM
