Old May 05, 2015, 05:20 AM
Manoo430 is offline
Find More Posts by Manoo430
Manoo
Manoo430's Avatar
United Arab Emirates, Dubai
Joined Feb 2015
Skysled FPV Wing
Hi Guys;
Here's my latest design in FPV wings....it follows the same concept of Skywalker X6......I named it "Skysled".....Its supper strong fuselage and wing design
It's made of Depron and Plywood....here r some specifications:
Wing Span: 1,400 mm
Wing Area: 40 sqdm
Dry Weight: 650 gr
Max FPV Play load: 2,000 gr for 50 gr/sqdm wing loading.
Radio: EzUHF 12 Channel PPM/PWM setup
AP: MFD
Video: 1.3 GHz, 1000 mW Lawmate
Camera: Fatshark Pilot Camera
Manoo430 is offline Find More Posts by Manoo430
Old May 05, 2015, 07:49 AM
Granted is online now
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Nice! Even looks seaworthy, with and without the wings.
Granted is online now Find More Posts by Granted
Old May 05, 2015, 12:59 PM
coalhugger is offline
Find More Posts by coalhugger
Joined May 2015
Very cool in new to this site and I hope all you guys can help me with my flying wing process. I'm currently building a foam stelth bomber and cannot decide where to mount the motor
coalhugger is offline Find More Posts by coalhugger
Old May 05, 2015, 06:36 PM
foamdave is online now
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
Manoo430:
Excellent design and build work. Very well done!
Dave-
foamdave is online now Find More Posts by foamdave
Old May 11, 2015, 01:35 AM
Manoo430 is offline
Manoo
Manoo430's Avatar
Joined Feb 2015
Thanks guys
@ Coalhugger;
well...to share what I got in this.....I have tried many wings with different motor positions...if you keep it aligned with the central horizontal line of the wing...gives you the best balance and easy to find the right CG ( if this is your first time...I recommend you this method). Of course with this method your motor will be at risk of damage when u land...so you can use a folding prop and also fix some skid at the bottom to keep the motor clear from the ground when you land.
You can also keep it same rear month but with an angle downwards....so the thrust line passes through the CG of your wing! this is the best according to the motor and prop safety during landing....but of course the worst and hardest according to finding the right CG and aerodynamics of the flying.
You can find many useful material about "Motor Thrust Line of Flying Wing" on the net.
Wish you luck
Cheers
Old May 11, 2015, 01:39 AM
Manoo430 is offline
Manoo
Manoo430's Avatar
Joined Feb 2015
One more thing....that air intake which you fixed at the nose makes your wing a nice slow flyer but needs some down motor thrust...because it takes the nose up when flying and works like up elevator...to compensate that you need to give that down thrust to your motor
Old May 11, 2015, 01:46 AM
Manoo430 is offline
Manoo
Manoo430's Avatar
Joined Feb 2015
These are some new photos of the finished plane geared with FPV setup. And also a quick shot of the first test flight
SkySled FPV Wing - Test Flight (0 min 45 sec)
I also tried my new open source head tracker on it...it was working just fine smooth with no drift!!
Open Source 3Channel HeadTracker on Zeiss Cinemizer - SkySled FPV Wing (0 min 22 sec)
Old May 15, 2015, 11:59 AM
Svede is online now
Find More Posts by Svede
United States, CA, Lemoore
Joined Nov 2008
Clean build. Nice
Svede is online now Find More Posts by Svede
Old May 18, 2015, 08:56 AM
Manoo430 is offline
Manoo
Manoo430's Avatar
Joined Feb 2015
Tnx Svede
Old May 20, 2015, 07:43 PM
Number_6 is offline
Find More Posts by Number_6
Ft Lauderdale
Number_6's Avatar
Joined Sep 2012
Originally Posted by Manoo430 View Post
Thanks guys
@ Coalhugger;
Wish you luck
Cheers
Hey Man...thanks for this info.
I am building 2 forward swept wings and of course
they have negative CG numbers at the root chord....
so I am researching 'pods' for batteries and electronics.
You have given me some ideas and I appreciate that.
Later,
Bob
Number_6 is offline Find More Posts by Number_6
Old Jun 13, 2015, 08:19 AM
Manoo430 is offline
Manoo
Manoo430's Avatar
Joined Feb 2015
Cheers Bob good luck man
Share your build please
Excited to see it.
For Sale Dark wing fpv flying wing raventech Aircraft - Electric - Airplanes (FS/W) 0 Feb 03, 2015 07:04 PM
Wanted Wanted wing or pusher fpv platform. I really want wing Daman691003 FPV Equipment (FS/W) 12 Dec 20, 2013 02:47 PM
Discussion Fixed wing FPV vs Rotary wing (VTOL) FPV ?? khaled_abobakr FPV Talk 8 Jul 20, 2011 01:43 PM
