Old May 11, 2014, 05:29 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Build Log
Slice-n-Dice
After flying the rekit for awhile I've grown to really like this airfoil. Quite good floaty performance coupled with some speed, even inverted.
But the design could use some tweaking. Although there seems to be plenty of elevon, it rolls quite slowly and the rudder could use some more umph as well, so I'll dig into the airframe once again and tweak things to suit my current flying skills. The airfoil is probably 12% thick, which is just fine by me. Vertical dives yield a lot of noise and maybe 60mph. Perfect for this lightly built wing.
On the building board are bigger elevons and a stretched out tail.
Kent
SnD slopin at Soberanes 2 (5 min 29 sec)
Knoll53 is offline Find More Posts by Knoll53
Old May 11, 2014, 08:16 PM
HerkS is online now
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Ancient Chinese wisdom: "Better is enemy of sufficient."
Looks like it is a great flyer from here. I used to fly the A-4 and the way it handles in that video reminds me of it. Very lively.
HerkS is online now Find More Posts by HerkS
Old May 12, 2014, 09:33 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
A-4 Skyhawk?.........funny, most hikers out there say that they first thought it was a hawk.
Old May 12, 2014, 09:48 AM
HerkS is online now
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
That's the one - flew the A and B models - old ones - long time ago. Very lively aircraft.
Old May 17, 2014, 09:19 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Just finishing up the rekit. The elevons have been widen out to a sharp TE with Rhinohide skins and taped hinges added. Hopefully these changes reduce some of the drag and noise of the old wing. The same tail has been pushed back to the sub spar position.
With any luck, some air time tomorrow.
Old May 18, 2014, 02:41 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
This wing is a lot quieter now and maybe a little faster too. The sharp TE really makes a difference at speed. Added 3oz. to the nose to get it to balance at 4% static margin. I was worried that the wider elevons would over control but it flys fast and smooth. Nice slope ship.
SnD w/ new Rhinohide Elevons (2 min 9 sec)
Old May 18, 2014, 02:56 PM
iron eagle is online now
Find More Posts by iron eagle
iron eagle's Avatar
United States, MA, Middleboro
Joined Jul 2007
I think you have nailed it.
iron eagle is online now Find More Posts by iron eagle
Old May 18, 2014, 04:39 PM
HerkS is online now
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Were you using the rudder function?
Did you notice a difference from moving the fin and rudder back a bit?
Old May 18, 2014, 05:01 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Yes I'm flying with rudder now. Not mixed into aileron, just manual. So rudder only turns are possible and are probably a good choice for easy thermal turns. I tilted the rudder hinge line in hopes of getting some up elevator coupled with rudder input but it's not enough and some up elevator is needed to carve a turn.
The rudder linkage has been stiffened up in addition to more aft placement so the rudder is now very effective. Big difference. I think I'll put it on expo just to give me a fighting chance to feed in just a little.
A few seconds of rudder only turns.
rudder only (0 min 29 sec)
Old May 24, 2014, 04:53 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Slopin in the UK
or at least as close as I'll ever get..........Couldn't help but think that the Brits wouldn't have been phased by today's fog. Finally tried using expo on the elevator. Much better.
Scratchin in the fog (2 min 19 sec)
Old May 24, 2014, 05:42 PM
Cable is offline
Find More Posts by Cable
United States, CA, Lancaster
Joined May 2013
http://youtu.be/ptMAoebunQM
I like this wing Kent. Looks like you are enjoying even in the light lift.
Cable is offline Find More Posts by Cable
Old May 24, 2014, 05:56 PM
HerkS is online now
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Kent - you are going to have a hard time improving on that aircraft when you build your next design.
Old May 24, 2014, 07:54 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
The winds should die down in a month or two and I'll have a go at hand launching into a thermal. The nice green grass is gone for the season and the tall dry grass should really cook up some nice thermals. Am enjoying trying to learn to use the rudder on this short coupled ship.
Old Jun 01, 2014, 05:04 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Nothing but fog around here lately, so I'm out on the ocean side of the mountain trying to find some sky. Along with the open sky, you get rocks..........what's the worst that could happen....
Slice-n-dice at Rocky Ridge (2 min 58 sec)
Old Jun 02, 2014, 02:16 PM
vincent123 is offline
Find More Posts by vincent123
InceCreations
vincent123's Avatar
Joined Jul 2009
Seems you got some news friends !
vincent123 is offline Find More Posts by vincent123
Discussion An interesting slice and dice of prop data matttay Power Systems 17 Aug 22, 2006 06:58 PM
Adding Slice to the Dice: SIG HUMMER EP conversion w/ Rudder genovia Parkflyers 13 Aug 13, 2005 05:29 PM
Multiplex EasyStar Thread 14 - Better'n sliced bread! intheswamp Foamies (Kits) 525 Feb 02, 2005 01:27 PM
