Old Mar 09, 2014, 05:13 PM
plane smasheruper
United Kingdom, England, East Cowes
Joined Apr 2013
Alert
handy glue found
hi all, thought i would share my experiance of a new glue i tried this weekend on my epp pitts build, ive tried CA with kicker and epoxy glues in the past but this stuff is excellant...its called unibond 100% power glue (no solvent)so it has no smell, it claims to be able to glue any material including foam..it has a tack time of 30 min and a max drying time of 24hr so its slow going and not suitable for field repairs, but if you want a strong flexible joint this stuff is great. it sets like firm latex..it retails at 5.99 and is available at any sainsburys supermarket so is always available..go ahead and give it a try
Se5me is offline Find More Posts by Se5me
Old Mar 10, 2014, 03:13 AM
Not always grumpy!!
insomaniac45's Avatar
UK, Eastleigh, Eastleigh
Joined Jul 2010
Wow.... your in Cowes... Im in Eastleigh
i found some stuff in B&Q yesterday from Bostick its called Glu and Fix, it claims to be able to bond foam, RRP a few quid, results so far is that it can eat foam.
It will eat foam, if you dont spread it, directly apply the glue to area, then with stick or card, spread the glue. This not only releases the solvents but dramatically reduces tack time to about 30 seconds, flight worthy bond about 30 mins. The worst is have seen it eat foam so far, is etching the surface about 0.5mm.
BTW it would have been pertanant to say this thread is based in the UK, as it is not that easy to get ahold of Uhu Por, or Gorilla Glue. unless you know exactly where to look. (Hobby Craft) But they will charge you through the nose for the stuff.
insomaniac45 is online now Find More Posts by insomaniac45
Old Mar 10, 2014, 10:24 AM
Don't look at me like that....
62pilot's Avatar
United States, AR, McDougal
Joined Aug 2005
Loctite Crafters is a great glue to bond foam, plastic to foam, wood to foam. Dries clear and flexibil .
62pilot is offline Find More Posts by 62pilot
Discussion Blitzworks RC Sky Surfer V5 Assembly question - Glue or no Glue? pgallett Foamies (Kits) 1 Jan 27, 2014 07:15 PM
Discussion Handy Dandy Hot Melt Glue Field Repairs goldguy Foamies (Scratchbuilt) 13 Aug 20, 2011 06:48 AM
Discussion I found a new foam glue booger Foamies (Scratchbuilt) 11 Nov 05, 2006 07:11 PM
FOUND: New Spray glue, safe for foam. Magna Electric Plane Talk 8 Nov 20, 2003 03:08 PM
I found a handy Slowstick repair fix for aluminum channel repairs! mrebman Parkflyers 4 Jan 19, 2003 05:52 PM
