Old Dec 26, 2012, 02:03 PM
Joined Dec 2012
Help!
Help me to choose best electronics for hydrofoam.
Hello! I wanted to ask for help,i have built something like this:
And i need to buy motor,propellers,ESC and battery for this hydrofoam,what you would recommend,i need good motor with reserve thrust and so on...
Would it be good setup?
Battery - http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
30A ESC - http://www.hobbyking.com/hobbyking/s...less_ESC_.html
Motor - http://www.hobbyking.com/hobbyking/s...tor_250w_.html
Propellers - 8x6 (no in stock Master Airscrew,recommend another in this size but good as master airscrew) ,
8x4 - http://www.hobbyking.com/hobbyking/s...eller_8x4.html
7x6 http://www.hobbyking.com/hobbyking/s...ller_7x6_.html
Thanks.
chip22 is offline Find More Posts by chip22
Old Dec 26, 2012, 03:46 PM
Joined Dec 2012
no one?
Old Dec 26, 2012, 07:21 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
You've built "something like" the picture... How close is it in size, design, etc.? It would be easier to make recommendations if we know exactly what we're dealing with and not an approximation; small differences can have a big effect.
The components you've chosen are matched fairly well. I wouldn't go above a 7" prop on that motor with a 3S battery, though. Also, Master Airscrew props are terrible. Go with APC-E or even "APC-style" props instead.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Dec 26, 2012, 08:05 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
If you are going to fly from water the motor would have to be mounted on a pylon. Otherwise the prop will be in the water and you will never get enough speed to take off.
Please supply a picture of what you have built. And as mentioned above supply the specs.
Wing span
Fuselage length
Weight
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Dec 27, 2012, 01:25 PM
Joined Dec 2012
It is 1:1 copy,about 400grams with all electronics on it. You really think that master airscrew props are bad,why? Which are better APC-E or APC-style?
Joined Dec 2012
Wing span
Fuselage length
Weight
Glen
Weight about 400g with electronics,200g without electronics.
Old Dec 28, 2012, 03:31 PM
Joined Dec 2012
Old Dec 28, 2012, 07:00 PM
United States, FL, Stuart
Joined Apr 2012
Originally Posted by chip22 View Post
You didn't say how long or how wide.
My suggestion; google "Model Airboat plans" it might get you going in the right direction.
Electrofish is offline Find More Posts by Electrofish
Old Dec 29, 2012, 05:40 PM
Joined Dec 2012
Weight 400-500 grams with electronics.
600mm long - incl. bobbers
400mm wide - incl. bobbers
Discussion Help me diagnose a problem with my electronics. GreenAce92_v2 Electric Plane Talk 9 Aug 04, 2012 05:08 PM
Discussion Please help me with these electronics NEAGRON Multirotor Electronics 7 Jul 18, 2012 01:53 PM
Discussion Help to choose best cheap electronics for hydrofoam. mareks166 Foamies (Kits) 0 Feb 11, 2012 07:09 AM
Data Electrons and oldtimer,the best thing..(for me) JMVC Vintage & Old-Timer Designs 4 May 12, 2004 05:09 PM
