Old Apr 24, 2014, 06:14 PM
United States, WI, Milwaukee
Joined Sep 2008
Originally Posted by Bivens View Post
Um....remember all of that RIGHT thrust in the firewall to minimize rudder "work" in upright flight.....
So, yes....Left rudder becomes necessary in many inverted or negative pitch change maneuvers....
Waterfalls
Inverted harriers
Inverted negative pulls to vertical from inverted level
Anything slow and inverted...or negative pitch changes...or rapid throttle up when inverted......all need left rudder
A good observation on your end for sure....many people take a while to notice it at all....and a long time to learn this left rudder relationship when inverted....just keep it in mind and suddenly the plane's behavior makes sense.
Ah, makes sense. Yeah, I give sharp left rudder when coming in slow inverted and pulling up sharply into a hover (with a blip of power). Never made the connection in inverted harrier.
Awesome - thanks!!!
Brownie433 is online now Find More Posts by Brownie433
Old Apr 24, 2014, 06:28 PM
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Yep...the combination of right thrust, P-factor, and gyroscopic precession....all are going against the norm when we do that inverted push thing to hover....takes a LOT of left, doesn't it...and that's all proportional to the throttle...isn't it...
Bivens is offline Find More Posts by Bivens
Old Apr 24, 2014, 06:33 PM
Joined Sep 2008
It sure does Quite a bit!
Old Apr 24, 2014, 10:46 PM
mdv
United States, CA, San Diego
Joined Jun 2009
Doesn't make sense to me that inverted requires more left rudder than upright. Maybe I need to think about it more but the prop is still rotating the same way relative to the airframe so torque is the same. I have never notice inverted requiring more left rudder on other planes. I haven't built my 58 yet.
mdv is offline Find More Posts by mdv
Old Apr 24, 2014, 10:52 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Same on any plane...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Apr 25, 2014, 04:13 AM
Your mother.
Phonic450's Avatar
USA, VA, Abingdon
Joined Jan 2011
Took the Edge up with a pair of 3S 2200s last night to see how it would do.
5 minutes of gentle(ish) flying gave me 68% left, I couldn't believe it.
It's always been a porker on 4000s but would follow through on hard moves nicely with the extra weight.
The lighter setup on 2200 turned this plane into a big old foamie, it'll get a lot more stick time now.
Phonic450 is offline Find More Posts by Phonic450
Old Apr 25, 2014, 08:26 AM
United States, PA, Philadelphia
Joined Dec 2011
Do you try inverted harrier on a straight line for long period of time? If so, you will find you need left rudder a lot of time. Also, it's more pronounced when you step up to bigger planes and props.
Vince_TT is offline Find More Posts by Vince_TT
Old Apr 25, 2014, 12:04 PM
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
Yep...trying to work this out in your mind....left rudder, right thrust....inverted.....takes a while to build the mental picture....but it's the same on all planes with a standard rotation prop.....sometimes you just get used to it and don't notice...but it's there...
Old Apr 25, 2014, 12:55 PM
Joined Sep 2008
+1
Yeah this through me off as well. I don't remember this being very pronounced on my 47" SHP. But both the 57 Extra and 58 Edge do it much more significantly and is why I have been noticing it so much.
Old Apr 25, 2014, 07:44 PM
Joined May 2013
Yep, I've wondered why too. Now it's been explained it's obvious
Jason50 is offline Find More Posts by Jason50
Old Apr 30, 2014, 07:52 AM
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
Hopefully she goes back together straight and true.
rayonnair is offline Find More Posts by rayonnair
Old Apr 30, 2014, 08:44 AM
rayonnair's Avatar
Joined Jun 2012
Gah!
I'm trying to repair her but kitty isn't letting me.
Old Apr 30, 2014, 09:33 AM
Joined Sep 2008
Waterfalls
Inverted harriers
Just another big thanks! Weather finally cooperated today and was able to get out. This post helped me immensely today as I new in advance what was going on and after coming over the top near stall and going inverted I got on the left rudder as soon as it was almost flat and got some great inverted harriers without rotation (still have some work to do ). Better waterfalls as well.
Very cool - THANKS!!!
Old Jul 22, 2014, 07:44 PM
SteveT.'s Avatar
San Jose, CA
For those running 5S, in case it might be of interest, a new battery box/holder to make it easier to get the batteries far enough forward to get your CG where you want it and still be easy to strap in...
And though only a small 4S pack would fit in this holder if there is interest, I can design and have made one to work with 4S
SteveT.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
