Old Jun 07, 2010, 04:43 AM
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
My KX-131 dead :(
I was working on my fpv setup and inserted the 3 pin pluc into back of my KX-131 camera. The connector seemed loose and not right. So i took the back off and found the connector has come away off the pcb.
I de soldlered it and this is what ive found underneath, it has stripped the conductors off the pcb so i can solder it back on or solder wires to it as the conductors have gone :
Does anyone know of anyway around this, like plis etc i could take my wires to instead or is it a right off ?
Coyote64 is offline Find More Posts by Coyote64
Old Jun 07, 2010, 08:43 AM
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
Use a magnifying glass & follow the tracks back to other components & solder your wires directly.
It may involve micro-surgery but if it works make sure you anchor the wires securely via hot melt glue of it wont last 5 mins.
badlands is online now Find More Posts by badlands
Discussion kx-171 or kx-131 for daytime flying? lovegroove FPV Talk 16 May 30, 2010 06:34 PM
Discussion KX 131 Camera Resolution? lilphil26 FPV Talk 3 Mar 05, 2010 10:39 AM
Discussion KX-131 Connectors scrtsqrl FPV Talk 2 Oct 26, 2009 06:03 PM
Wanted Camera Kx-131 or sn480 dmondong Aircraft - General - Miscellaneous (FS/W) 1 Sep 01, 2009 12:42 AM
New Product KX-131 CCD. Cased and uncased. 12volt and 5 volt. reznikvova Aircraft - General - Miscellaneous (FS/W) 18 Oct 12, 2006 02:36 PM
