Old Jan 21, 2014, 11:29 PM
Feeling the THRALL
Jackson Stone's Avatar
USA, CO, Parker
Joined Dec 2009
Hi Andrew,
Thanks for posting the videos with the turbine sound. I found these fascinating to watch and listen to. I would like to build a plane with the turbine sound, but am not certain what that will be yet.
I do have a couple of prop-engine-sound projects planned for this year, so I will be in touch soon.
Sincerely,
Jackson
Jackson Stone is online now Find More Posts by Jackson Stone
Old Jan 29, 2014, 09:54 PM
papernkero's Avatar
Sydney, Australia
Joined Jul 2008
Originally Posted by MrRCFlying View Post
I just got your email about this as well.
There are 2 outputs on the board. You could do all 6 to one output, or 3 to each. It will handle all 6 on one output, yes. The LEDs you are describing sound perfect. Low volt 2-5v, 10-20ma.
Andrew
Hi Andrew
Further to this, when I ordered my LEDs I bought two types to experiment with. One type is a 30,000 mcd 25 deg angle LED rated at 3.2V @ 20mA, the other type is much brighter (40 lm) with a 55 deg angle and a rating of 3.3V @ 100 mA. If I alter the load resistor to reduce the current on the higher intensity LED to around 25 mA it is still considerably brighter (both directly in-line and from the side) than the 20 mA LED.
My question is, what is the max current of the LED driver on the sound system. I'd like to be able to use 6 of the higher rated wider angle LEDs running at a reduced current of 25-30 mA each (180 mA). If that is too much then I could reduce the number of LEDs to 2 each side or as a last resort incorporate an additional switching circuit driven from the gun output to switch the LED'S at their full rating (don't panic, I have 40 years experience in electronics ).
By the way, I installed the sound system in my 1600mm P51 and tried it out last night. It was so loud on the balcony I had to cover the speaker with my hand to stop the neighbours complaining (and I'm in a house not an apartment). Its hard to believe you can get that much sound from such a small speaker .
Ian
papernkero is offline Find More Posts by papernkero
Old Jan 30, 2014, 02:38 PM
Joined Feb 2012
Originally Posted by papernkero View Post
Hi Andrew
Ian
Let me double check the output of the LED driver for you. It should be fine, I believe it is well above that, but I can't recall off the top of my head.
Are you running a single speaker or 2 speakers on the 1600mm? I recommend 2 for a plane that size. It is pretty amazing how much the system pumps out, isn't it.
Andrew
MrRCFlying is online now Find More Posts by MrRCFlying
Site Sponsor
Old Jan 30, 2014, 04:47 PM
papernkero's Avatar
Sydney, Australia
Joined Jul 2008
Andrew
I'm currently running a single speaker but I may order several more speakers anyway. I have a J3 Cub Id like to add the system to, but instead of moving the entire system from one model to another I'll just install speakers into several models and move the PCB across. That way the COG doesnt change
Old Feb 04, 2014, 11:01 PM
papernkero's Avatar
Sydney, Australia
Joined Jul 2008
Andrew
Hi Andrew
Any luck on the maximum LED driver current? Id like to have them as bright as I can but don't want to test the limit without your advice.
Thanks.
Ian
Old Feb 06, 2014, 04:28 PM
Joined Feb 2012
Hi Andrew
Thanks.
Ian
Sorry for the late reply. Not yet. I am trying to get in touch with my electrical engineer as I don't seem to have that on my specs page. It should be OK. It is worth a try, you should not burn anything out, worst case, they will just not light.
Andrew
Site Sponsor
Old Feb 06, 2014, 04:29 PM
Joined Feb 2012
A new video, this one is meant to be an advertisement type vid. It is a collage of several customers videos, with info on the system. Enjoy!
MrRCSound V4.1 Aircraft Version Overview (3 min 25 sec)
Site Sponsor
Old Feb 07, 2014, 03:10 AM
czorzella's Avatar
United States, FL, Kissimmee
Joined Jan 2012
https://www.youtube.com/watch?v=UYOm8OvYCG8
This is really good, Andrew!
czorzella is online now Find More Posts by czorzella
Old Feb 07, 2014, 10:38 AM
Joined Nov 2005
Can someone provide the weight of the small round speakers, and are they available now for sale? Also, when using the smaller speakers, does the volume need to be turned down on the board so not to blow them?
I know they are not as load, but for smaller twins, I would like to use two 1.22" speakers instead of one 2" speaker to get the stereo sound.
tclaridge is offline Find More Posts by tclaridge
Old Feb 07, 2014, 11:11 AM
Joined Feb 2012
I can weigh one up for you. It should go full volume on the v4 and 4.1, but to be safe you may want to turn it down a little. Honestly, I prefer the 2" speakers. One 2" is louder than tow 1.22"
Andrew
Site Sponsor
Old Mar 14, 2014, 02:48 PM
Joined Nov 2005
When will the new TT-25 speakers be available to order?
Old Mar 14, 2014, 03:16 PM
Joined Feb 2012
They are up on the page now, and will ship Monday.
Andrew
Site Sponsor
Old Apr 01, 2014, 05:25 PM
Joined Feb 2012
A simple rebuttal.
It has recently come to my attention that a competitor is making accusations against the way that I measure the volume output of the MrRCSound system. This same person has made all kinds of accusations in the past as well, many false and misleading. Simply put, I want to set the record strait on this one. Nothing more, just a simple rebuttal of the claims made against me.
This competitor has accused MrRCSound of using incorrect methods to test volume output, and thereby artificially inflating the db output. While it is true that many of the videos showing db output are conducted on a bench at exactly 1M, this is for ease of setup, and recording of the video. Our claim of 108db output comes from a single MrRCSound proprietary TT-25 mounted in a vice to hold it, with a 3"X4" piece of foam attached. Running the Generic Turbine sound and measured in open air at exactly 1m, not on the bench, the peak output was recorded to be 108db, with a steady db reading of 103db. Power draw for this test measured just 12v, 0.22A and 5W.
MrRCSound has at least a dozen videos on Youtube showing exactly how the output was measured, and the real time db reading. Yet, this accusing competitor, appears to not have one single video demonstrating the volume output of their system. In fact the only video that can be found with any kind of reading of the competitors system was done by a professional videographer, with a reading of 101.8db, over a bench, at what appears to be MUCH less than 1m.
Thank you,
Andrew
Site Sponsor
Old Apr 01, 2014, 05:58 PM
Roaring Radial Fanatic
corsairnut's Avatar
United States, OH, Hilliard
Joined Jan 2012
Claims by modelsounds
It amazes me still to this day that Dave cant be content to sell his product on his own merits but still try to make false claims against a competitor. If his sales are so good why is he the only one throwing barbs at his biggest competitor?
Dont see Thomas Benedini doing that. Theres only 2 things that cause a person to continually go after competition. Either his sales are down or he just cant accept the fact that his competition is doing better than him.
If those 2 reasons are false, then he should have no reason to go after Andrew. So which is it?
corsairnut is offline Find More Posts by corsairnut
Old Apr 01, 2014, 06:43 PM
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Andrew, my dad told me "never argue with an idiot it's hard for the people standing around to tell which one is the idiot ". We all know you're a man of quality.
When he reads your response and defense he smiles because you responded. If you're going to play to win when something! Don't waste your emotional energy swinging your sword or windmills.
Your friend,
DJ
Sculptor is online now Find More Posts by Sculptor
Discussion Welcome to the SMAC Forum Azarr Springfield Model Airplane Club 0 Apr 12, 2013 09:27 AM
Question Vendor Forum Request for Diamond Hobby jogorek Site Suggestions / Complaints 3 Mar 12, 2013 12:21 PM
Discussion Welcome to the New Skyartec Vendor Forum skyartec-usa Skyartec 27 Jun 04, 2009 02:08 PM
Welcome to the Vendor Talk forum! Please read these guidelines before posting... Tres Wright Vendor Talk 0 Jul 15, 2003 10:29 AM
