Old Feb 08, 2013, 04:16 PM
Vienna, Austria
Joined Oct 2010
Telemetry speech output for Spektrum radios, VSpeak available !
Volker did it ! Vspeak for Spektrum radios is available. Supported radios are DX7s, DX8, DX10t, DX18, DX18QQ. I tested it with a DX8 and DX18. Works like a charm.
What can it do ? Speech output of all telemetry data, of course configurable, alarms for various values (independent from the telemetry alarms of the radio), vario using the original altitude sensor, capacity counter using the "dumb" current sensor. You can choose many different languages and voices, even use your own voice !
You can find it on Volkers homepage: http://www.vspeak-modell.de/index.php/en/sprachausgabe
I have built it into my DX18 without drilling holes using the holes for gimbal adjustment. Have a look at the attached pictures....
If you want speech, you can have it now without an I-Thingy, directly from your radio. And you get vario and capacity sensor free of charge using standard sensors
And of course, it does not affect the RF module, just "sniffs" the telemetry transmission.
If you have questions.....ask !
Mukenukem is offline Find More Posts by Mukenukem
Old Feb 08, 2013, 04:33 PM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Video so we can hear it in action?
freechip is online now Find More Posts by freechip
Old Feb 08, 2013, 04:39 PM
Vienna, Austria
Joined Oct 2010
There are some Youtube videos available: http://www.vspeak-modell.de/index.php/en/home
The display and speech output are independent.
Old Feb 08, 2013, 04:55 PM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
Oh, I was asking you if you had some since you already have it installed want to see/hear what it was like from a user/rcg member and not the manufacturer website.
It's all good.
Old Feb 08, 2013, 05:22 PM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
Originally Posted by Mukenukem View Post
<snip> If you want speech, you can have it now without an I-Thingy, directly from your radio. <snip>
Except the i-Thingy won't void your warranty.
Originally Posted by Spektrum VSpeak adapter
Attention: The necessary modifications of the radio will void your warranty !
Old Feb 08, 2013, 06:31 PM
Vienna, Austria
Joined Oct 2010
The problem with the STi is the limited range. I found that it has a lot more signal drops than the radio. The voice of the STi is horrible. The App is outdated and does not support all sensors. Also, at least with my Ipot, the battery consumption is huge. With VSpeak, you do not have to take care of another battery, it runs from the TX.
A big advantage of VSpeak: It can also announce Powerbox values. Especially if you have DIY sensors. And the vario, which is not available from Spektrum.
I have it installed already for about a month because I assisted Volker with testing and some minor issues during development . No problems. Have been flying in the gym for some hours and everything worked like it should.
But I do not get money for advertising, just like to inform you all
Of course modifying the radio voids the warranty. But if you, for example, swap switches, your warranty is also void...
Old Feb 08, 2013, 06:46 PM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
Yes STi range isn't the same as the radio - Agreed.
STi voice horrible - Agreed, it could be improved.
Outdate - Only for some time, once they release an update I think Apple needs to approve it for release so it will be updated then it will support the current line of sensors.
iPod battery performance - I use my iPhone or iPad and the battery is very good but it's not the first time I hear battery drain with the iPod. Someone posted information about using a cable to use the STi and charge the iDevice at the same time.
Voiding the warranty is something every one needs to consider when doing anything to their equipement.
Old Feb 17, 2013, 05:43 PM
czorzella's Avatar
United States, FL, Kissimmee
Joined Jan 2012
It's all good.
Mukenukem, +1 on this request.
I'm following all your comments about DIY sensors and I'm very much interested to see what the vspeak looks and sounds like in action. Most important; please shown your own experience as a RCG member, not the manufacturer's friend.
czorzella is offline Find More Posts by czorzella
Old Feb 18, 2013, 09:55 AM
Vienna, Austria
Joined Oct 2010
Okay, what do you want to see ? I can setup some sensors on the bench and let my radio talk. Anything specific you are interersted ?
I can't give you outdoor footage. It's cold here in Austria and I am a pussy, I only fly outdoors if it is 10°C or more
Old Feb 27, 2013, 07:15 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
My DX18 install
I am pretty happy with this configuration. Note that after picture I repositioned the adapter slightly. It must stay above the white plug just by the bottom right corner of it so the battery compartment does not hit it.
davidmc36 is offline Find More Posts by davidmc36
Old Feb 27, 2013, 09:08 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Having some fun playing around with the settings on this. RPM seems pretty accurate, maybe one percent or so higher than displayed. I think I will have to do some wav file recording though. I don't like her say "revolutions per minute" I would like it changed to "RPM".
Old Feb 28, 2013, 02:10 AM
Vienna, Austria
Joined Oct 2010
Cool. You did it the "drilling way"
Did you set the multiplier right ? Plane or helicopter ?
Old Feb 28, 2013, 04:24 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Yeah I went for the gusto in the "I want them positioned where I like them" department rather than "take what I can get" I'm pretty pleased with how it turned out.
Got the multiplier set no problem. At 9320rpm on display it was reporting 9338. That's pretty darn good. I only set it for one plane so far.
http://www.top-flite.com/airplanes/topa0300.html
I was able to play around with the motor since the prop is off while I am installing landing lights.
Old Feb 28, 2013, 04:33 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
I think I envision only using the announcements on demand. I don't like the idea of it going off when say I am concentrating on making a tricky turn. I envision just hitting the button when I am cruising along straight and level. Something like race car drivers only talking to their pit crew on the straightaways.
Any thoughts on this?
Old Feb 28, 2013, 12:35 PM
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Sub.
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Discussion Using the Speech Module made by "VSpeak" kensp Radios 6 Feb 08, 2013 10:19 AM
Question PPM and RSSI output from a NON-telemetry FrSky nige838 Video Piloting (FPV/RPV) 4 Jan 29, 2013 06:10 PM
Wanted Telemetry Cable for APM 2.5 to 3dr radios wootenelli FPV/RPV - Equipment and Vehicles (FS/W) 0 Jan 10, 2013 08:40 PM
Discussion Spektrum telemetry data inside transmitter for speech output seuchato Radios 17 Aug 17, 2012 10:45 AM
For Sale Spektrum TM1000 Telemetry unit(s) 3 available! new! (out of my DX8's) HD Hucker Aircraft - General - Radio Equipment (FS/W) 1 Jun 03, 2011 01:12 PM
