Old Jun 07, 2015, 09:49 PM
ripper-911 is offline
Find More Posts by ripper-911
ripper-911's Avatar
Toronto, Canada
Joined Mar 2010
Question
RPM Output from DLE Engine Ignitions
Can the rpm cable that comes out of DLE ignitions be connected to the RPM connector on the eLogger V4? The DLE rpm cable is normally connected to an RPM display that can be purchased from DLE.
Please advise.
Thank you in advance.
Regards,
Robert
ripper-911 is offline Find More Posts by ripper-911
Old Jun 08, 2015, 08:13 AM
JohnET is online now
Find More Posts by JohnET
JohnET's Avatar
United States, NC, Charlotte
Joined Apr 2013
Hello,
We have not tested with this and do not know what the specs are from that output and do not recommend that you connect that output to the eLogger as it could damage the ignition, eLogger or both.
Regards, John
JohnET is online now Find More Posts by JohnET
Site Sponsor
Old Jun 08, 2015, 01:15 PM
ripper-911's Avatar
Toronto, Canada
Joined Mar 2010
Ok. Thank you John.
Regards,
Robert.
Old Jun 11, 2015, 04:26 PM
ripper-911's Avatar
Toronto, Canada
Joined Mar 2010
RPM Senor
Do you know if a Futaba optical rpm sensor can be used with the eagle tree? This way I don't have to go through the grief of remounting the sensor because mine is not working where it is but my buddies works using the futaba sensor which apparently has a longer range.
Regards,
Robert
Sold DLE Engines Electronic Ignition #3 DLE-30 (NIB) highonthai Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 02, 2014 08:28 PM
Sold Used DLE-111 gas engine with mufflers, ignition. (Version 1) - $375 bobzilla Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 10, 2013 09:31 PM
Wanted DLE 20 Engine w/muffler and Ignition module jlewis99 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 06, 2012 10:18 PM
Sold DLE-55RA Rear Exhaust Engine, includes electronic ignition, muffler and standoffs ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 Aug 31, 2012 09:44 AM
Sold DLE-55RA Rear Exhaust Engine, includes ignition, muffler and s ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 3 Aug 14, 2012 08:17 AM
