Old Feb 13, 2014, 09:49 PM
SingSoftKitty is offline
Find More Posts by SingSoftKitty
Joined Feb 2014
12", 3.7g Indoor ornithopter
Airframe:
Wing 12"x4" half ellipse. Carbon rods 0.5 and 0.3mm, 7g/m2 Mylar.
Stabilizer R 4.5 52 deg sector of the circle. 0.3mm Carbon, 2.2 g/m2 Mylar.
Fin and rudder 0.25mm balsa with 0.3mm carbon reinforcements.
Fuselage: 0.8mm carbon tube, EPP foam nose, Balsa+carbon lamination gearbox housing.
Components:
4x12mm Corelless motor
40mAh Full River LiPo
Deltang R42b Rx
Plantraco Nano Act
M0.2 1:125 gearbox
Performance:
Total weight 3.70g
CG = 1"5/8 from LE
Tail installation angle -18deg
Upstroke +30 deg
Downstroke -20 deg
Endurance - up to 10 min.
SingSoftKitty is offline Find More Posts by SingSoftKitty
Old Feb 13, 2014, 09:51 PM
Joined Feb 2014
3.5g, 12" RC Ornithopter (1 min 38 sec)
Old Feb 14, 2014, 11:36 PM
seagull10 is offline
Find More Posts by seagull10
Joined May 2011
Here almost everything looks clear until starting replicating it of course
I like the ruder position, seems efficient and side gusts will turn and bank the ornithopter in the right directions IMO .
What material this "tongue"- hinge that coming out of the actuator coil is made of?
Is it related to the auto centering or is connected to the magnet?
Have you investigated how the wrinkles on the wing membranes and tail affect performance in this scale?
Do you know some algorithm/software for optimization of the reduction ratio ,motor-gearbox efficiency and its weight in the models scale range?
Also gears looks like lubricated? What is the lubricant ?
Very clean, lightweight and simplified design Bravo!
Thanks for sharing Dmytro
PS here is an interesting web site with interesting ideas of one good in the micro stuff guy enjoy if you didn't know him already.
http://micro-plane.com/index.php?opt...mid=14&lang=en
seagull10 is offline Find More Posts by seagull10
Old Feb 15, 2014, 12:17 AM
Joined Feb 2014
The 2mm magnet is held by U-shaped 0.1mm music wire. No centering.
No, but I used to pre-wrinkle film on smaller models, when it is to hard to make membranes smooth.
Yes.
White silicon grease
TY
http://micro-plane.com/index.php?opt...mid=14&lang=en[/QUOTE]
Sure I do, here is another one
http://www.microflierradio.com/
The NANO stuff is not that hard to build. But it is extremely hard to tune and to fly, IMAO. The 5" orni just vanishes in the sky 30' away
Old Feb 15, 2014, 12:41 AM
Joined May 2011
Thanks a lot!
If you don't mind, please post link to the place where such algorithm/software can be found please.
Did you optimized the shown ornithopter by this software ?
Old Feb 15, 2014, 08:14 PM
Joined Feb 2014
Originally Posted by seagull10 View Post
Thanks a lot!
There is no link. I did a research on flapping wing in the university. Wrote a lot of Matlab code for data analysis.
As for algorithms, you can find a lot of articles on aerodynamics of a flapping wing.
In some of them you can read about effects of different parameters on the performance of a flapping wing.
I believe you know about this one
http://www.ornithopter.org/software.shtml
Old Feb 16, 2014, 05:22 PM
Ron_RC is offline
Find More Posts by Ron_RC
Ron_RC
Joined Nov 2011
I converted my cheap ebay ornithopter to a spektrum controlled ornithopter.
DSM2 Ornithopter Flying Bird (4 min 56 sec)
Ron_RC is offline Find More Posts by Ron_RC
Old Feb 16, 2014, 09:41 PM
Joined May 2011
Thanks Dmytro .
https://solarbotics.com/product/gm25/
Old Feb 16, 2014, 10:25 PM
Joined May 2011
http://youtu.be/UancpFE1J3s
What is the overall weight after conversion with the battery and what was the original weight of the original bird ?
Original------------------------------------- Converted
RX,ESC combo---------1.8 g---------- RX HK R415--------------------2 g
Battery 70mA/h 1 cell 1.98 g-------- ESC 3A Brushed with wires 1.6 g
EM actuator--------------0.47 g---------Battery 130 mA/h 1 cell-------3.8 g
------------------------------------------------Servos 2x HK 5320-------------3.8 g
------------------------------4.25 g-----------------------------------------------11.2 g
Weight increase 11.2 - 4.25 = 6.95 g
How you manage to fly it ? Overall weight over 20 g ?
Old Mar 30, 2014, 05:15 PM
Ron_RC is offline
Ron_RC
Joined Nov 2011
Seagull10, I just weighed it and it came to 20g. It seems the brushed ESC I put on it has more power that the combo system's ESC. Anyway, it flies nice but not as long as it did with the original system. I am running a 160mAh battery with a 30C rating and it does quite well. I did have to figure out the CG and now that I have the battery moved farther back it flies even better than in the video. All the best an Happy flying!
For Sale Micro 3D Airplane BNF 12" Span, 22.6 gm RTF- Great for Indoor 3D Flying scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Nov 11, 2013 04:22 PM
Question How small and light can you build using a 10g rx and 3.7g servos? RC Aerobat Foamies (Scratchbuilt) 7 Oct 21, 2013 10:10 PM
Question Smallest/lightest RC model using 3.7g standard voltage servos RC Aerobat Electric Plane Talk 10 Oct 18, 2013 10:21 AM
Video Tiny (12 3/4" span) BD-5 indoor scale Paul Willenborg Electric Plane Talk 3 Mar 12, 2009 08:53 AM
Sold 3 - 3.7g Sub Micro Servo dizzane Aircraft - General - Radio Equipment (FS/W) 2 Jan 18, 2009 10:04 PM
