Old Dec 24, 2011, 10:59 AM
13Flatspins is offline
Find More Posts by 13Flatspins
Build it up!
13Flatspins's Avatar
United States, MN, Coon Rapids
Joined Dec 2007
Engine break-in or run-in
I got a Trex 600N and an OS .55HZ engine for Xmas. This will be my first nitro build. All my planes (sans Zagi) are nitro. I took the time to break them in on a test stand before I mounted them in the airplanes. My big block Saito 4 strokers didn't really get dialed in until after 8 hours of run time. Do any of you break your heli engines in? If so, how do you do it? And for how long?
Thanks in advance!!
Flatspins
13Flatspins is offline Find More Posts by 13Flatspins
Old Dec 27, 2011, 04:17 PM
Rafael23cc is offline
Find More Posts by Rafael23cc
Helicopter Pilot
Rafael23cc's Avatar
Junction City, KS
Joined Sep 2004
I've never bolted a heli engine on a test stand. I always assemble the helicopter and go flying. Now, during the first few flights, I adjust the needles to get a rich setting while the temperature is still coming up into the operating range. I fly this way for the first 3 tanks. After that I start leaning the needles until I get enough power while still operating at a reasonable temperature. After about 6-8 tanks, I do not worry about breaking-in anymore.
Rafael23cc is offline Find More Posts by Rafael23cc
Old Dec 28, 2011, 02:16 PM
koppterX is offline
Find More Posts by koppterX
koppterX's Avatar
moreno valley california
Joined Jun 2008
+ 1 above. no tricks needed. mount and fly.
koppterX is offline Find More Posts by koppterX
Old Jan 02, 2012, 10:27 AM
Build it up!
Joined Dec 2007
Thanks guys! That is what I will do. I noticed after I started this post that the heli engine(s) came (comes) without a propeller type thrust bearing so mounting a prop to it is out of the question.
Flatspins
Old Jan 02, 2012, 02:09 PM
barracudahockey is offline
Find More Posts by barracudahockey
Multi-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Yup, thats because there is no point.
Doing autos is great for heat cycling. Nice smooth climb outs followed by a cool down period.
Start out slightly rich but enough as Rafael says, to get it up to operating temp. As the ring seats you will notice it needs leaning a bit at a time, when it quits needing tweaked, its there.
The biggest thing is to not but undue loads on the engine for a few flights till that ring seats (like repeated tic-tocs) or leaning it out too far.
barracudahockey is offline Find More Posts by barracudahockey
Discussion OS 55AX break break in question. Dale 813 Engines 4 Nov 11, 2011 02:08 PM
Discussion Slayer Pro 3.3 Engine Break-In chucksolo69 Nitro and Glow Power Cars 6 Oct 01, 2011 01:00 PM
Discussion Must break in engine again if you change fuel brands? Killionaire Engines 7 Sep 04, 2011 12:48 AM
Discussion engine temp durning break in carp886 Engines 6 May 12, 2011 03:04 AM
Question Can I re-break in an engine with a bad break-in? lectraplayer Engines 4 Jul 26, 2007 08:33 PM
