Old Dec 21, 2014, 09:42 AM
United States, NJ, Pennsville
Joined Feb 2008
Turning lights on and off
I have the HK Flybeam which I have added the Turnigy remote switch which turns the lites on and off via my Spektrum DX6 Gen2 radio using the gear channel. I want to add the 16 led circular light disk to the bottom of. the plane for landing lights. I only want the landing lights on when making my final approach to land. I know I need another Turnigy remote switch for the led disk, but is there a mix or way to turn both sets of lights independently with my 6 channel DX6 Gen2 radio?
I appreciate your help.
stemo99 is online now Find More Posts by stemo99
Old Dec 21, 2014, 11:06 AM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
You need free channels for that, one for each light kit if you want individual control for them.
freechip is offline Find More Posts by freechip
Old Dec 21, 2014, 11:25 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
This unit here will control more than one thing from just one channel on your radio.
http://www.hobbyking.com/hobbyking/s...f_Switch_.html
Just a simple two position switch like your gear switch will make it turn on and off different things by hitting the switch for the right amount of time and cycling through the 7 ON-OFF ports.
You can set up various Modes so that more than one thing is turned on at the same time or all things are off.
http://www.hobbyking.com/hobbyking/s...9X48229X55.pdf
davidmc36 is online now Find More Posts by davidmc36
Old Dec 21, 2014, 11:50 AM
Joined Feb 2008
Thanks Davidmc36, that thing is slicker than whale sh_t. It's exactly what I needed. thanks again.
Steve
Old Jan 27, 2015, 08:10 PM
United States, TN, Nashville
Joined Dec 2014
How could i make this item, without buying and solder my own contraption? I want to put my lights on a switch but i want a separate battery to power the lights.
Gamma370pro is offline Find More Posts by Gamma370pro
Old Jan 29, 2015, 01:30 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Likely not that hard if you can do Arduino or other microcontroller programming.
Old Jan 29, 2015, 06:42 AM
Joined Dec 2014
lol i seen i put without soldering. I meant soldering i don't mind soldering just don't know how i would get a board like this. I was also thinking if i connected another reciever through gear switch from reciever "A" and connect it to auxilary on reciever "B" then the switch would control turning the reciever on and off. Then i could connect a battery to the bind/batt port and put my lights on gear all on reciver "B" but can i put 12 volts on a recevier is my only question? I dot think you can so i will have to see other ways. I know i will probably figure something out. But if you or anybody could help i appreciate it.
Old Jan 29, 2015, 08:06 AM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
I don't know of any Rx that can handle 12 volts. Arduino is the way I would try. It can have multiple inputs and outputs that will respond to multiple switch positions for different output effects. The Arduino could switch transistors on and off to handle higher current draws.
Old Feb 22, 2015, 12:05 AM
Master of Repairs
kknox's Avatar
United States, UT, Grantsville
Joined Mar 2013
https://www.servocity.com/html/rc_sw...l#.VOliIX1lDMI
This might work....
kknox is offline Find More Posts by kknox
Latest blog entry: Spitfire Repair
Discussion Turning on/off Landing Lights on Airplane Jimd0586 Night Flying 2 Jun 16, 2014 07:36 PM
Help! Can I turn my Navigation lights on and off with my DX6i and gear channel on RX dolbydarma Night Flying 6 Nov 17, 2010 07:49 PM
Landing lights - How to turn on/off in flight mag1 Scale Kit/Scratch Built 17 Aug 13, 2005 05:58 PM
