Old Oct 07, 2003, 04:44 PM
Joined Aug 2003
Gws Esc
Hi Everyone,
I have had several GWS planes - all from Horizon Hobby. The P-51 and E-starter were my first two planes and Horizon recommended the GWS100 (5 amp) ESC. I've been using that ESC with an 8 cel 800Nimh AAA battery which pulls about 6-7amps (I believe?)
I am now in the process of building the Formosa and Corsair. So, two questions:
1. Do both of these planes come with a 350 motor?
2. While using the same battery, will I still be able to use the same ESC? Or might I burn up the ESC?
Fundy is offline Find More Posts by Fundy
Old Oct 07, 2003, 06:31 PM
but it's a nice obsession
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
1. Yes
2. Yes, if you use a 9X7 prop. If you go to 10X8, then you should get an ICS-300.
Jon
jgmtens is offline Find More Posts by jgmtens
Old Oct 08, 2003, 01:43 PM
Pontificating Member
tone's Avatar
Atlanta
Joined May 2003
Fundy -
The reason you're only pulling 6-7 amps is that the ICS 100 is acting like a governor. switch to the ICS 300 (not 300E) and you'll enjoy it much more. shorter takeoff, more power. The ICS 300 also comes with all the connectors just like the ICS 100, so no soldering and it is a perfect replacement.
I flew my estarter on the 100 for a while and other guys estarters were much snappier. since the change, the plane was becoming my favorite.
Then i finished my Formosa.
My first Brushless system with a razor 400 and CC 25. Wow built it as light as i could and it comes in under 13oz with a 2S 1200 RTF. On the 11x8 prop it really does well. Does everything i wanted it to.
just got 3S 1200's though so i'll be dropping the prop down to 9x7 or 10x8, will really rock. hoping to be able to switch props and enjoy both setups.
Tone
tone is offline Find More Posts by tone
Yippee! No glitches with GWS ESC's Vonbaron Parkflyers 11 Nov 28, 2004 09:13 PM
Problems with my GWS esc JStory Foamies (Kits) 0 Jan 21, 2002 05:21 PM
Anyone have a GWS esc for sale? JStory Aircraft - Electric - Airplanes (FS/W) 2 Jan 16, 2002 09:06 PM
Question Hitec Prism and GWS ESC question jah Parkflyers 5 Jan 06, 2002 08:03 PM
GWS ESC with speed 280? Christophe Parkflyers 6 May 07, 2001 03:37 PM
