Old Dec 17, 2014, 12:57 AM
brcer's Avatar
United States, CA, Santa Barbara
Joined Dec 2010
Question
lean angel
Hello,
I took off the slide bar mounts to drill them out to 3/16, Im gonna use the alleven bars for now, I noticed lower hole mounts on the upper mounts closest to the servo, If I mount the slide bar in that lower position will I get less lean angel? Dunb question I know I assume it will, just not 100%
brcer is online now Find More Posts by brcer
Old Dec 17, 2014, 02:41 AM
Espa˝a, CL, ┴vila
Joined Sep 2008
Lean angle depends on bars lenght only. The longer they are, the less you can lean...
Guess what do you get with shorter ones?
The difference between a high or low slider mount is the place where bike's CG is applied to the ground when slider touches the track surface.
A high slider mount will add weight to tyres while a lower one will do the opposite.
trf_414_m2 is offline Find More Posts by trf_414_m2
Old Yesterday, 08:19 AM
Copenhagen, Danmark
Joined Dec 2009
And we want the higher weight on tyres to ease/help the bike rise again!
Erling.
gnilre is offline Find More Posts by gnilre
Old Yesterday, 11:32 AM
brcer's Avatar
Joined Dec 2010
Thanks guys, This was a big help.
Discussion political leanings based on occupation ... is anyone really surprised? logan5 Life, The Universe, and Politics 10 Dec 06, 2014 02:37 PM
Discussion Quad leans back on full throttle, KK2 mixer settings? jp0160 Multirotor Electronics 1 Oct 30, 2014 06:23 PM
Discussion Strange vibration/resonance leans out mixture??? Brutus1967 Fuel Heli Talk 7 Oct 01, 2014 02:21 PM
Problem: Lean to Lt.= Lean/ Rt.=Rich Turbowe4 Off-road Cars 2 Nov 29, 2003 02:15 AM
