Old Oct 13, 2003, 07:50 PM
Gravity Always Wins...
bnl2001's Avatar
Medina, Ohio
Joined Jun 2003
Average Cost?
For those of you that have been at the electric thing for a while just curious what you would estimate your average cost per plane for the whole setup from bench to flight have been.
I thought starting out in this that the costs wouldn't be that much but with the brushless motor setups and Li-Pos all over the place I can see this hobby getting expensive.
Basic requirments per plane:
1. Aircraft Kit
2. Motor
3. ESC
4. RX
5. Servos
Any guesses?
bnl2001 is offline Find More Posts by bnl2001
Old Oct 13, 2003, 08:07 PM
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
For me, ~$350. Some higher some lower. This will go up when I get into the 'bigger' planes I'd guess.... I don't move stuff from plane to plane (very often) so...... New outfit for most every new plane (servos I never move). Yep, slows you down a bit on buying 'new' planes . And the only ARF I now fly is the 'funky' chicken. All others from balsa kits.
rclark is offline Find More Posts by rclark
Old Oct 13, 2003, 08:10 PM
Closet Extrovert
Jim Poor's Avatar
In transit Los Angeles ->AZ, -> KY
Joined Aug 2003
Too much
I've gone through several planes this week, so I decided to try one of the really cheap wattage oddysey models out. Let's just say you get what you pay for.
ON average, to get a plane up and running, I figure 200 as a very low min. 300 more like the average.
jim
Jim Poor is offline Find More Posts by Jim Poor
Old Oct 13, 2003, 08:11 PM
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
I'd agree with RClark.. I don't do musical electronics.. I buy a new setup for each plane, unless something has died and it's an organ donor.
Seems my planes usually go like this:
~$80 kit
~$60 servos
~$150 motor/esc
~$100 batteries (2 packs)
~$20 covering
then you have the misc stuff.. I'd say $350 sounds like a good average..
Tram is offline Find More Posts by Tram
Old Oct 13, 2003, 08:16 PM
nose_first's Avatar
Riverview, FL
Joined Dec 2002
1. Aircraft Kit - $35+ (this is very broad range as some kits can be 100+)
2. Motor - some kits have them included but for a brushed motor maybe $20-$35+ (gws ips or 300 geared)
3. ESC
4. RX
5. Servos - you can usually find the gws flight packs for around $80 with esc/rx/and servos
dont forget battery packs - ~$20 each for nimh
charger - ~$40
nose_first is offline Find More Posts by nose_first
Old Oct 13, 2003, 08:27 PM
Nimble with Gimbals
San Diego, CA
Joined Apr 2003
I've always simply ripped the electronics out of my old planes and kept the airframe in storage. It makes the hobby very, very affordable and it only takes about 15 minutes to put the stuff back in if I so desire.
Awakened is offline Find More Posts by Awakened
Old Oct 13, 2003, 08:30 PM
Registered Boozer
Ralph_D's Avatar
United States, CA, Tustin
Joined Sep 2003
But don't you like flying multiple aircraft when you go out to fly?
-Dujara-
Ralph_D is offline Find More Posts by Ralph_D
Old Oct 13, 2003, 08:40 PM
Nimble with Gimbals
San Diego, CA
Joined Apr 2003
I suppose that would be nice, but it's not within my financial abilities.
Old Oct 13, 2003, 08:44 PM
Brunswick, Ohio
BrunswickOH's Avatar
Joined Aug 2003
I agree with Tram except for the Batteries, I use a prop and gear that will work with the batteries I have. If I buy a new battery it's usually because it's something I want to try not necessarily something specific to a certain plane.
BrunswickOH is offline Find More Posts by BrunswickOH
Old Oct 13, 2003, 08:51 PM
Closet Extrovert
Jim Poor's Avatar
Joined Aug 2003
I don't like musical electronics (hey you coinded a phrase) either, but I'm to the point now where I have to choose. I can only take so many planes to the field/slope anyway.
Old Oct 13, 2003, 09:07 PM
Tram's Avatar
Florence, Al
Joined Oct 2000
Yeh, I was just throwing the batteries in there.. I usually try and get planes that will work with what I have, but being a newb to electrics I still need more packs.
Old Oct 13, 2003, 09:10 PM
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
I'm getting to the point where I just have too many planes to keep track of. It was over 20 at last count. I've finally started removing the gear from planes I don't fly anymore and selling the airframes cheap, then moving the gear to a new project. Once you get to that point the hobby is pretty inexpensive, you're basically just out the cost of a kit, covering and building supplies when you build a new project.
Brushless definitely has a higher up-front cost, but they last forever if you don't crash and bend a shaft. I've worn out some planes, but have yet to wear out a BL motor
Tres Wright is offline Find More Posts by Tres Wright
Old Oct 13, 2003, 09:22 PM
Closet Extrovert
Jim Poor's Avatar
Joined Aug 2003
So how about passing some of those cheap airframes to a guy with a last name like mine?
I've bounced all over so many different types of planes that none of my packs really go with any of the others.
Old Oct 13, 2003, 09:47 PM
bnl2001's Avatar
Medina, Ohio
Joined Jun 2003
Well the other night I promised my wife that I would only ever have 4 planes at any one time. Of course I didn't specify that what I really meant was 4 complete setups that would all fly at any given time. I kinda like the idea of getting sets of gear and then building airframes around the gear sets so that each new model isn't 200 to 300 bucks out of pocket. Just basically the cost of the kit and maybe covering. That should keep each new kit plane after that to around 70 dollars or so.
I kind of have this in mind for the four aircraft.
1. A three channel slowflyer
2. A 3D/Pattern ship
3. A scale warbird
4. A EDF Jet
I'm half way there with a MiniFlash and BLT. X-Mas is only a little more than 2 months away.
Old Oct 13, 2003, 10:08 PM
Albuquerque Intl, New Mexico, United States
Joined Jun 2003
With all of the recent developements, I try to stay under 100$ per month - Brian
mbcone is offline Find More Posts by mbcone
Discussion What is the average cost for one of you guys to kit a plane??? wiredconcepts Foamies (Scratchbuilt) 27 Aug 09, 2007 10:18 PM
Discussion CP2...average cost & repair time for conservative beginner crashes? duganderson Micro Helis 3 Nov 23, 2006 01:54 PM
