Old Mar 23, 2012, 10:21 AM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
Nah I'm just glad it stuck well enough
derk is offline Find More Posts by derk
Old Mar 31, 2012, 05:19 AM
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
- a blast from the past
- much more primitive
boredom.is.me is offline Find More Posts by boredom.is.me
Latest blog entry: RFD900 Case
Old Jul 14, 2012, 06:48 PM
Joined Nov 2007
Originally Posted by boredom.is.me View Post
As soon as I can get a little help with what to use for a mold and materials, I'll be trying fiberglass hulls. If I pull it/them off, I'll send one of each.
I have a new design and some who wants to help out with the composite aspect. Now I just need to get a new plug made. It's safe to say that this design may be the most advanced micro race boat RCG has ever seen and will see for a long time to come.
The vee is ready to go.
- FG hull
- 140mm long, 156mm with all hardware
- 40mm wide
- adjustable trim tabs
- fully adjustable stinger drive
- NO FLEX SHAFT DRAMA!
- interchangeable rudder mounts for aesthetics or offset
- pure beastliness
No more till later.
EDIT:
The only down side is the high part count. Without the trim tab associated parts, there are 24 parts. With the tabs, 28.
Old Jul 18, 2012, 01:39 AM
derk's Avatar
Joined Dec 2003
140 by 40mm? sounds like an open ocean racer, a far cry from a crackerbox
so going long and narrow instead of short and maneuverable?
interested to see what comes from it
Old Jul 18, 2012, 02:49 AM
Joined Nov 2007
Ya I'm going for a more reliable, less playful type thing. You know, trying to get a little more serious on straights.
I was looking at the mSRX main motor for power. It is an 8.4mm with an even longer can! I want to try out my custom props too. Everything about this would be purposed for it. I want to use an Rx31 within a custom housing to make it waterproof. I may need an esc as I'm scared that the standard 2 amp would blow especially since it is built in. Also an hk5320 servo which shouldn't have to worry about water too.
The hardest part is getting the plug made. What's funny is that that was the easy part for the cat, and the hard part was everything else. It's backwards now.
Build Log 26" 1/18th scale scratch built Downeast(lobster) boat CMEboston Scale Boats 30 Nov 21, 2010 08:59 AM
Sold Miss vegas hydro boat 100% rtr!!1 used,,runs strong!!! Silverdragon Boats (FS/W) 1 Aug 01, 2010 05:38 PM
Off Site FS 1/8 Scale B28 BAT BOAT Hull & Hardware only K.R.Joye Boats (FS/W) 0 Nov 23, 2009 10:05 AM
Discussion 1/30 scale Empire Flying Boat - is Depron waterproof enough RJPIoW Waterplanes 9 Sep 23, 2009 01:01 AM
Discussion orco2 is "iom" boat or 1 meter boat ? vasp Sailboats 4 Mar 19, 2008 04:08 AM
