Old Nov 16, 2006, 03:36 PM
Joined Nov 2006
Thrust to Weight ratio?
How much thrust should I be looking for to do 3D with an AUW of around 16-20 oz?
THANKS!!
pdxmonkeyboy is offline Find More Posts by pdxmonkeyboy
Old Nov 16, 2006, 03:43 PM
willhaney's Avatar
Fountain Valley, California
Joined Feb 2004
I like 2:1.
willhaney is offline Find More Posts by willhaney
Old Nov 16, 2006, 04:19 PM
edible_engine's Avatar
Just south of Cambridge, UK
Joined Oct 2003
1.5:1 is about minimum desirable, anything over is great! 2:1 is about perfect, when you approach 3:1 it is sometimes difficult to control the power
edible_engine is offline Find More Posts by edible_engine
Old Nov 16, 2006, 04:29 PM
Joined Nov 2006
So any suggestions on cheap motors in the 30-40oz thrust range... You knew that question was coming.
Old Nov 16, 2006, 04:37 PM
txfly's Avatar
frisco,tx
Joined Oct 2003
check united hobbies, xus, or grayson
txfly is offline Find More Posts by txfly
Old Nov 16, 2006, 04:42 PM
blucor basher's Avatar
United States, PA, Lancaster
Joined Jun 2003
Since most motors are not rated by thrust, I'd look for a motor capable of at least 20Amps with a Kv of 900-1100.
blucor basher is offline Find More Posts by blucor basher
Site Sponsor
Old Nov 16, 2006, 05:01 PM
Joined Aug 2004
Hacker A20-20L
Hands down my favorite motor on models 16-21 oz.
I bought a knock off of this motor and it just wasn't as powerful imo.
You get what you pay for.
shawn
sbmon is offline Find More Posts by sbmon
Old Nov 16, 2006, 06:45 PM
Joined Nov 2006
So what is THE best way to compare brushless motors? Watts? Amps?
I thought I understood this whole thing and now I'm starting to doubt myself.
I have seriously looked at about 50 posts and 100 different brushless motors in the last 4 days. Sorry guys, but electric flight is begining to seem like a real pain in the .
I just want to get out and fly this thing!!!!
Old Nov 17, 2006, 12:13 AM
I Wish I Was Flying...
sdueck's Avatar
United States, CO, Littleton
Joined Nov 2006
Originally Posted by sbmon
Hacker A20-20L
shawn
I'd have to agree here. I had a hyperion extra 300L with the a20-20l and a 10x4.7 prop and the thing pulled vertical so fast it was too far away to see in just a few seconds. I now have that motor on my mini ultra stick that weighs in at exactl 22 oz. It has unlimited vertical, though it would be tight for 3d performance (assuming hte control surfaces were a little bigger). No, I am not into the whole 3d thing, but I am just backing up sbmon that this motor is great, very quiet, and has plenty of power. I would highly suggest it.
sdueck is offline Find More Posts by sdueck
Old Nov 17, 2006, 12:38 AM
Christchurch, New Zealand
Joined Jun 2006
Electric flight is about calculating what the motors can do. Go download motocalc and play around with it. That'll give you a much better idea; performance is a consequence of a whole bunch of factors, and it's better to do the math (or have some software do it for you) than to guess.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Nov 18, 2006, 04:08 PM
Bodywerks's Avatar
United States, AZ, Tucson
Joined May 2004
Thrust-to-weight is usually best calculated in watts/pound. Ideally, you want a MINIMUM of 150-160 watts/pound, but ideally, 200+ is better, especially if you just want to show off your hover-pullout authority.
The A20-20L with a 10X4.7 or the EF Torque 22t-930 with an 11X4.7 (the two motors that I have the most experience with) would haul a 16-21 ounce plane quite well.
Bodywerks is offline Find More Posts by Bodywerks
Holy Thrust to Weight ratio Batman! SS ROCKET! eBird Parkflyers 24 Jan 21, 2003 12:08 AM
Thrust:weight ratio > 1 on a living room flyer! drliu Scratchbuilt Indoor and Micro Models 5 Aug 17, 2002 10:57 PM
thrust to weight ratio Joe_in_AZ Parkflyers 2 Jul 24, 2002 11:17 AM
Thrust to Weight Ratio??? sapok Beginner Training Area (Aircraft-Electric) 1 Feb 23, 2002 04:21 AM
Thrust to weight ratio Frank B Electric Plane Talk 6 Oct 19, 2001 07:08 AM
