Old Jul 28, 2014, 12:57 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
Test fitting the firewall, engine mount, fuel tank and Spring Air retract unit that go in the nose area. The OS 61SF ABC-P will be mounted vertical at first so I can glue the nose together with the nose ring, etc. After more of the nose is constructed the mount will be turned 90 degrees to the right using its symmetrical mounting holes.
Because of the space provided by the air intake I can mount the nose retract unit further forward for clearance with the nose wheel and the front of the wing.
To be continued
Jet_Flyer is offline Find More Posts by Jet_Flyer
Old Aug 07, 2014, 08:25 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
More progress. I like to get the firewall related parts pretty well located together as an assembly so it can all be glued into the fuselage as one part.
To be continued
Old Aug 07, 2014, 08:31 PM
R_G
Wanna Hover? Fly a Heli!
R_G's Avatar
United States, PA, Farrell
Joined May 2010
Very nice Mike!
Ralph
R_G is online now Find More Posts by R_G
Old Aug 08, 2014, 08:16 PM
United States, GA, Alpharetta
Joined Dec 2007
Originally Posted by R_G View Post
Very nice Mike!
Ralph
We say that a lot in his build threads.
David
dhal22 is offline Find More Posts by dhal22
Old Aug 09, 2014, 12:31 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
Thanks for your support guys.
Old Aug 09, 2014, 12:32 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
More finish sanding on the firewall parts. The retract gear mounting plate will be tapered slightly to fit the inside of the fuselage after a get into the fitment process.
To be continued ……
Old Aug 09, 2014, 12:40 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
Planning the mounting position of the power plant. The position forward on the mount provides lots of space for the pump fuel lines and will line up correctly at the nose ring.
I love these OS 61SF ABC-P engines. Over the years I’ve been fortunate to add to my stock so that I now have three that have been run with low time like the one in the picture below, four new in box and lots of spare parts.
To be continued ……
Old Aug 11, 2014, 02:21 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
Drilled the firewall for the throttle cable and working on the nose gear steering. For the past twenty-five years Ive always made the steering cable mount removable, but because Ive never needed to remove a mount I glued this one in place. Ill cut off a little of the cable end of the nylon clevis and then I epoxy the clevis to the cable because it does not need to be adjustable and saves space for more movement if needed.
To be continued
Old Aug 11, 2014, 04:44 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
Much better. A Goldberg mini link. Wish I could find more of them.
To be continued
Old Aug 11, 2014, 04:48 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
Cool, found some on the bay!
Build Log Clausxpf, F-8 Crusader, Alpha-build jweber009 Scratchbuilt EDFs 231 Jun 25, 2014 03:24 PM
Build Log BritKit Build Off 2012 - Mercury Crusader RFJ Vintage & Old-Timer Designs 66 Jul 28, 2012 06:34 AM
Build Log When You're Out Of F8... The Crusader Build Thread GGRN Pusher Prop Jet Models 390 Nov 23, 2009 06:51 AM
Discussion F-8 Crusader jetset44 style build with Video agriebel Pusher Prop Jet Models 284 Aug 12, 2009 07:32 AM
Discussion Profile Super Crusader Build burkefj Pusher Prop Jet Models 17 Feb 21, 2008 08:58 PM
