Old Aug 17, 2014, 08:05 PM
Tim B.'s Avatar
Oakland Ca.
Joined Aug 2009
Big one
Another big one Louie but I think Paul would like it ~
Remote control tug boat 1/24 scale
"Accurate scale model of SUN KENT Thames tug boat one of a kind powered by 12v motor and gel battery
Dimensions 54" long x 16" wide x 39" tall propellor 6" diameter
Constructed of metal excluding hull and superstructure
Full working lights and fire hydrants
Weight 50kgs
Extremely powerful model
Comes with new 5 channel remote control
Any questions contact Stewart on 07904612841
Advertised elsewhere can be withdrawn at any time"
http://www.rcgroups.com/forums/newre...eply&t=1537093
Tim B. is online now Find More Posts by Tim B.
Old Aug 17, 2014, 08:07 PM
Band1's Avatar
Joined Oct 2011
Originally Posted by Tim B. View Post
Any of you guys near Johnstown ?
MODEL TUG BOAT R/C FOUR FOOT
"THIS R/C MODEL TUGBOAT WAS BUILT ABOUT 3 YEARS AGO...IT IS 48" LONG, 15" WIDE, 22" TALL.....IT WEIGHS 60 LBS...SO NO SHIPPING-PICKUP ONLY
INCLUDED IS ALL DOCUMENTATION ( FRAMES, CABINS,WIRING ETC.)
ALL FUNCTIONS WORK...NEEDS TLC ..CLEANING......
FEATURES: 12 VOLT DRIVE MOTOR...12 VOLT BOW THRUSTER...CHARGER FOR 12 VOLT GEL CELLS...CHARGER FOR TRANSMITTER....LIGHTS.....HORN.....DEISEL SOUND GENERATOR....HEAVY BRASS PROP AND RUDDER....FUTUBA FP-T4NBF TRANSMITTER.....
BECAUSE THIS MODEL IS APPX 3 YEARS OLD IT IS BEING SOLD AS IS....I DID CHARGE THE BATTERIES FOR ABOUT A 1/2 HR AND TESTED ALL FUNCTIONS
GOOD LUCK BIDDING..........."
http://www.ebay.com/itm/MODEL-TUG-BO...item2ed58ca4bf
Looking at this set up this model has been around a while.
Band1 is offline Find More Posts by Band1
Latest blog entry: 32 Ford rat Rod
Old Aug 17, 2014, 08:26 PM
Tim B.'s Avatar
Oakland Ca.
Joined Aug 2009
Any lobster boat fans theah ?
He wants $625.00 for a BIN, ends in a few minutes !
"This is my midwest boothbay lobsterboat, 30"x 10", with basically every option. A lot of swett, sandpaper, ca glue, paint, and internet searching spent on this beauty. Its gorgeous sitting still, and cruising on the water! I've only taken to the pool 3 times, but I had to list as used. The lrp 17t v10 motor is probably not even broken in! The strips of metal taped together are a removable ballast , since I only run on 1 battery, runs very nice on painted water line. "
http://www.ebay.com/itm/Boothbay-lob...3D201151304213
Old Aug 17, 2014, 09:57 PM
needabiggerboat's Avatar
United States, NY, New York
Joined Feb 2012
Hi all
Hey Charlie we missed you today! Turned out to be nice .
Here are some pictures of today's run. Enjoy
Doug
needabiggerboat is offline Find More Posts by needabiggerboat
Old Aug 17, 2014, 10:14 PM
Joined Feb 2012
A couple of video's of today's run. Enjoy
Doug EMPIRE STATE MODEL MARINERS August 17 2014:
EMPIRE STATE MODEL MARINERS August 17 2014 (0 min 45 sec)
EMPIRE STATE MODEL MARINERS August 17 2014 (1 min 14 sec)
Old Aug 17, 2014, 11:16 PM
Tim B.'s Avatar
Oakland Ca.
Joined Aug 2009
This is a nice one ~
Who's is it ?
Old Aug 17, 2014, 11:19 PM
Tim B.'s Avatar
Oakland Ca.
Joined Aug 2009
Doug those are Great vid's ~
But what language is that those guys are speekin ?
I cant understand 'em !
Old Aug 18, 2014, 03:20 AM
no such thing as to many boats
louie R/C NUT's Avatar
Joined May 2010
Nice Tim .
Thanks Doug great shots .
louie R/C NUT is offline Find More Posts by louie R/C NUT
Old Aug 18, 2014, 04:44 PM
Band1's Avatar
Joined Oct 2011
"This is my midwest boothbay lobsterboat, 30"x 10", with basically every option. A lot of swett, sandpaper, ca glue, paint, and internet searching spent on this beauty. Its gorgeous sitting still, and cruising on the water! I've only taken to the pool 3 times, but I had to list as used. The lrp 17t v10 motor is probably not even broken in! The performance was surprising! Very quick and jumps to plane when you throttle up. The 12 pics and description I give won't be enough to describe it, and I'm going to try and put together a 125 pic build log on a usb drive , included in sale. Everthing pictured is included. You'll only need a good charger, I use a onyx 245, because it charges all batteries, perfectly. The radio is a futaba ty4f, 72mhz fm , with 4 channel reciever, and basic s3003 servo. The esc is a brushed watercooled, lipo ready chinese import, with deans, no on/off just plug and go. Will also include hobby king lvd, that I never installed. The lrp motor can and brushes are water cooled by a trinity kit, very trick. All the water cooling is controlled by a dimensional engineering battleswitch, simply toggle down the right radio stick, and the self priming pump pulls water through all the electrics, and out the boat through a proboat outlet ! Works perfectly, and is very cool! Lol. So it doesn't run all the time, only when you stop to pull in the traps. I used a graupner universal instead of clunky dog bone, and keep shafts greased with grim racer lube.I didn't list any night shots, but it has ram nav lights in scratch built wells, and the int/ext cabins are lit as well. I did a lot of scratch built accessories, the engine box, live well, serving board, vhf radio/ antenna. Furuno radar, radar reflector, captains chair, fire extinguisher, trap rack, danforth anchor. Will also come with stove, cooler, life ring, seagulls, and of course doug as captain, and bob as mate. I named boat after my wife, but you could change, just stickers. I will also include model master paints. The aqua is 3 different shades I mixed. Boat is all brushed.as directed by midwest. Hull has 2 layers of fiberglass, motor/ battery bays are also glassed. The hull has 2 coats auto primer, and 2 coats white primer, before finish paint.feel free to ask any ?
Side windows are full tint, front have 1/4" of tint
All batteries are pretty new, you get a racers edge 2s 4000mah 75c lipo, 2- 4.8v nicads for pump and battle switch, and 2 -9v for nav lights. The hard case lipo is a tight fit, a lipo with front facing wires would fit better than top pigtail style.
Great tug Tim, would look good next to mine.
The lobster boat is nice I was looking for one for the past 2 weeks
I can't believe I didn't see this one.
I will make this my winter project , I have to scale down in size for the
New place that I am about to move in.
Discussion Could a Single Marine Unit Destroy the Roman Empire? Big Foot 48 Life, The Universe, and Politics 162 Nov 07, 2011 05:47 PM
Gallery North Shore Model Mariners charlie eaton Dock Talk 106 Jun 22, 2011 09:30 PM
Empire Mine State Park - Bourne Cottage MX Aerial Photography 9 Feb 17, 2004 04:31 PM
