Old Apr 02, 2013, 07:59 PM
United States, MA, Framingham
Joined Feb 2013
Mcpx v2 RTF broken right from the box
I just put the battery in my Mcpx v2 for the first time and I'm having the following two issues
1. The servo on the front right is buzzing. I can feel it twitching with no input and its loud
2. The main motor / rotor is bound up. It will spin up but only after it "breaks free". If I disconnect the battery, and try to turn the rotor gently it will skip a tooth rather than turn the motor.
This is my first heli other than the mcx2, but it does nothing like this. This one has not done anything other than try to gently spin up 3 times. Video to follow shortly.
Advice?
Blade Mcpx v2 problem (0 min 28 sec)
The video shows right what it did from the beginning. From the very first time applying battery and trying to throttle up. Sorry the video isn't better but you can hear the servo, and the motor straining without being able to move the main rotor.
I should add, it looks like the main gear is fine, meshes with the motor pinion, no broken teeth. Seems the motor is 'stuck' more than anything, and I'm not sure what's with the servo.
Jimdibb is offline Find More Posts by Jimdibb
Old Apr 02, 2013, 08:04 PM
Tucson, Az
Joined Feb 2007
This is not a co-ax and you should not try to spin it. Sounds like broken gear.
dankar04 is online now Find More Posts by dankar04
Old Apr 02, 2013, 08:30 PM
Fly Runaway Fans
DFW airport
Joined Jan 2009
Horizon guarantees that it works out of the box. Yours doesn't. Call them, they will replace it. If bought at hobby shop, they also will replace it assuming they have another in stock.
arbilab is offline Find More Posts by arbilab
Old Apr 02, 2013, 08:33 PM
Joined Feb 2013
Yup, that's what I was coming around to. Will call them tomorrow.
Thanks.
Old Apr 03, 2013, 05:52 AM
Joined Feb 2013
So I tried it a bit more. It will spin if I throttle up further but it starts with all I can describe as a "snap", then the whole heli starts to spin on the carpeted floor as I go a bit further. Then as I slow down it snaps back to a stop.
I assume this is not normal, my friends Msrx doesn't behave anything like that.
Old Apr 03, 2013, 08:01 AM
United States, MN, Otsego
Joined Dec 2010
Of all the helis I have the MCPX is the only one that doesn't spin freely with no power. I am told this is normal. I have a genius CP, several FP micros and even a Blade SR Huey and they all spin free without power but the MCPX I bought does not and when I increase the throttle slowly it takes getting to a point on the throttle where the blades finally go into action.
Perhaps someone else here can explain the why behind this but I believe it is a normal characteristic of the type of motor used in the MCPX (at least V2, I don't think the BL does this).
Jim
jcmors is offline Find More Posts by jcmors
Old Apr 03, 2013, 09:00 AM
Joined Feb 2013
Jim
Well, that is certainly helpful! Does yours also have a servo that is in continual motion from the moment it binds? Its constantly twitching (I'm using the Dx4e if that adds any info).
I'm feeling that may be normal as well, as I watched a review video and heard the same noise at about 4:40 and 5:20.
Eflite Blade MCPx v 2 BNF quick review and test flight (9 min 28 sec)
Old Apr 03, 2013, 10:28 AM
Joined Feb 2013
Replying to my own post:
My aforementioned friend with the MSRx flew my mcpx for a few seconds and it seemed to work fine.
Basically all the servos sit there and buzz, and the motor needs a good bit of throttle before it starts spinning, then it kind of snaps into motion, and on the spindown it snaps to a stopped position.
I guess I'll still call horizon to ask about it but it does fly.
Old Apr 03, 2013, 11:26 AM
Tucson, Az
Joined Feb 2007
My servos buzz and all fly fine. Sounds like you expect this heli to be like others and is a different animal. If your friend got it to fly ???? I don't know could be defective or handled badly.? Blade stuff is turn key for most part. I have six Blade helis/Quad and no issue at all.
Old Apr 03, 2013, 11:39 AM
United States, CA, Fountain Valley
Joined Dec 2012
I would just call in to the LHS that you got it from and ask for an exchange, if they wont allow call horizon hobby and work it out with them, you may like to stop messing with it more it might get worse to the point they may not allow the exchange, im sorry to hear that you are having problems with it. I just got one recently RTF and its a hell of a fun heli to fly! I hope you get this settled and you do deserve to have a working Brand new kit to fly with, and not trying to fix it. FYI all three servos do make a buzzing noise but you shouldnt have any problems with moving the the servos, the throttle should spin smoothly without any binding or snap sounds.
jonathan2tran is offline Find More Posts by jonathan2tran
Old Apr 03, 2013, 12:07 PM
Joined Feb 2013
Thanks again. I just don't have that much experience with different ones and the few others I have seen are significantly different. Having my friend successfully fly it, and your 'mine does the same thing' comments have been quite reassuring.
Old Apr 03, 2013, 12:11 PM
Joined Feb 2013
Thanks Jonathan. Being quite new I wasn't sure if I was having a problem or not!
I don't have a problem with the controls.
The motor seems like it must have very strong magnets that hold the shaft in place until energized. It doesn't make a snapping sound, it more like suddenly starts turning. When it spins down it stops turning abruptly enough that it torqued itself over.
Old Apr 03, 2013, 12:50 PM
Joined Dec 2012
Hmm maybe check if the motor pinion is too tight against the maingear which may be causing the teeths binding. if so try to loosen the two screws from the main motor and nitch it over just a teeny bit... Also in events of minor crashes the main gear tends to slip, you can tell this by grabbing the main rotor hub and move it up and down there shouldnt be movement but it cant be completly flush either just very tiny play of movement enough for a paper or two thickness (persay) of movement. if there is in fact slippage just hold the top of the hub with your thumbs and your fingers around the heli fingers against the maingear and squize/snap it back in make sure the main gear grooves fit with the grooves of the main shaft if not pull off the skids (no screws) and pull off the main gear (no screws) realign grooves push back together and your good to go! i hope this helps.
Old Apr 07, 2013, 12:43 PM
United States, MA, Plymouth
Joined Jan 2013
This behavior is normal. Servos make noise constantly, and on startup the blades snap into action suddenly. On landing, the opposite. It stops suddenly, often with enough torque to knock the bird right over.
I too thought it was odd at first, as my Super CP didn't do anything similar. I found two things:
1) It's the strength of the magnets, as you guessed.
2) Batteries make a big difference on how smoothly and abruptly it starts/stops. Better batteries show less of this jumpiness. Especially at the end of flight time.
Arr0wHead is offline Find More Posts by Arr0wHead
Old Apr 08, 2013, 09:26 AM
Joined Feb 2012
One thing to avoid is flying to LVC (Low Voltage Cutoff)...it's not good for LiPo batteries and MAY contribute to the abrupt stop situation...
Try to time your flights so you're landing about :30 to 1:00 PRIOR to LVC..
Good Luck!
dasBlade300X is offline Find More Posts by dasBlade300X
Trade Brand New In Box MCPX V2 for Nano CPX! ryanf58 Want To Trade 0 Feb 28, 2013 11:01 PM
For Sale Brand New In Box Blade MCPX V2 ryanf58 Aircraft - Electric - Helis (FS/W) 3 Feb 24, 2013 09:30 AM
Sold Brand New In Box MCPX V2 ryanf58 Aircraft - Electric - Helis (FS/W) 2 Feb 22, 2013 01:18 PM
Sold Mcpx v2 out of the box and into the wall BedEvil Aircraft - Electric - Helis (FS/W) 8 Feb 13, 2013 03:37 PM
Discussion First Night with MCPX V2 - Broken Swash TexasC Micro Helis 9 Mar 01, 2012 08:56 PM
