Old Nov 08, 2014, 05:35 PM
Joined Feb 2004
Thanks Gilles. Am I correct to assume GMFC is adjusting the height of the outer panel to allow for different speed of cut of the tipp inner panel and the root outer panel.
Rod
Wetafly is offline Find More Posts by Wetafly
Old Nov 09, 2014, 04:29 AM
gm.cnc's Avatar
France
Joined Feb 2006
Rod
Yes, unless you have uncheck the kerf boxes in the cutting dialog.
Gilles
gm.cnc is offline Find More Posts by gm.cnc
Old Nov 12, 2014, 07:42 PM
Joined Feb 2004
Thanks Gilles
Cores came out nicely. 7.5 meter Diana 2.
I still haven't really got a good understanding of the new Foam management dialogue box. Is there a tutorial for it or a discussion somewhere? Perhaps we could have one here.
Rod
Old Nov 13, 2014, 02:45 AM
gm.cnc's Avatar
France
Joined Feb 2006
Thanks Gilles
Rod
Really good, congrats.
I know I should make a web page... This is really simple. The slice is cut without kerf in foam management. So cut the slice, then measure the height. The difference between the measure and the desired height is the kerf.
First determine the speed/heat on a rectangular slice, without checking "measure at the tip" .
Then measure the kerf at tip by checking "measure at the tip". This will cut a tapered slice with the C ratio. Choose a C that is close to the kind of wing you will be cutting with this material.
Gilles
Old Nov 13, 2014, 03:22 PM
Joined Feb 2004
That's great Gilles,
I understand now. My problem was that I didn't realise the Foam management dialogue box doesn't apply kerf in the tests. To test the kerf I would still use the trapeze project in the foam cutting dialogue box. I would adjust the taper ratio of the trapeze to be the same as the tests in the Foam management dialogue box.
Rod
Old Nov 21, 2014, 02:36 PM
Neal
Christchurch, NZ
Joined Nov 2004
It's been a while since I last posted, hi everyone.
My foam cutting machine is 98% finished after not touching it for a year. Sadly I've forgotten most of what I figured out! So please forgive me for asking the following.
I bought two power supplies, one is 48v 7.5A, the other is 36v 10A. Which one drives the steppers, which one the other gmfc thing? Are they OK or do I need to get something better?
Thanks, Neal
HotAir2 is offline Find More Posts by HotAir2
Old Nov 22, 2014, 01:21 AM
Fossilator
danfield's Avatar
Fullerton, CA
Joined Nov 2004
Thanks, Neal
Hiya Neal!!!!
I just asked JW a couple of weeks ago if he had seen you. Hope the house is coming along.
I know you have GGC but I don't recall what controller you have. The GGC will handle the 48v supply for wire heat. I would suspect the 36v to run the board/motors should be fine. Need to know the amps on your motors.
For wire heat using the 36v would run out of enough power around 42" of bow wire length IF cutting 1.9 EPP depending on wire type/dia and cut speed.
That's the way I would go, 48 on wire heat and 36 on motors. :-)
danfield is offline Find More Posts by danfield
Old Dec 23, 2014, 02:02 AM
Kevin Matney's Avatar
United States, MI, Monroe
Joined Mar 2000
new wing larger then table 2667. table is 770
I have a new big wing,105" or 2667 for a AW20 wing. I have made it into a 3 piece wing witch fits. But the TE of the tip is cut by 13 mms but not at root. Even if you tell it to make is 13 mms longer it does the same.
Kevin Matney is offline Find More Posts by Kevin Matney
Old Dec 23, 2014, 02:26 AM
Холодная война все еще здесь.
RCWorks's Avatar
Joined Aug 2003
I tried to open both files and it errored out.
RCWorks is offline Find More Posts by RCWorks
Old Dec 23, 2014, 11:06 PM
Joined Mar 2000
Asw 20
I have tryed to make this a 3 part wing,but the ## keep changing
To start with
Root Air foil is HQ 2.5/14% 11.75" Tip is HQ 2.5/13 6" with a 2" lay back
Half span is 105".
Wing skin is 1/16"
LE is 1/2"
But when you make into 3 parts the all the # change. The tip is now 189 mms not 152mms
Discussion CNC Foam Cutting problem with GMFC wimmeke CAD/CAM 0 Jan 14, 2010 01:24 PM
Discussion Foam works foam cutting software issue airmcn_3 The Builders Workshop 5 Aug 29, 2008 11:02 AM
CNC software for foam cutting KAMarks The Builders Workshop 0 Sep 15, 2002 09:20 PM
foam cutting software Dinah Power Systems 0 Mar 19, 2002 11:08 PM
Foam cutting CNC software foam_man Foamies (Kits) 10 Sep 08, 2001 09:50 AM
