Old Aug 18, 2007, 10:07 PM
crazy plane is offline
Find More Posts by crazy plane
United States, MN, Shakopee
Joined Nov 2006
Help!
electronic ignition on a gas engine
i cant get my reichmuth ignition to work right. i have the timing set right because it idles perfectly. at faster rpm it starts to pulse and eventually dies. does anybody have any thoughts about this?
thanks
crazy plane is offline Find More Posts by crazy plane
Old Aug 19, 2007, 12:42 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
thanks
Hello "crazy plane"
I am glad that your plane is crazy cause I am sure YOU are not crazy.
I do not use this system but as you said "does anybody have any thoughts about this?". I can do some thinking .
http://www.dandbengines.com/
Because it idles perfectly does not mean the timing is set right.
At idle the ignition timing should be a few degrees like 3 to 8 before TDC. It has to advance to about 20 or more degrees at high rpm.
An engine may idle quite well with ignition after TDC and also with ignition well before TDC.
The above URL is worth reading and will save me lots of typing suggest you go and read it. Link in the site to ignition.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Aug 20, 2007, 03:31 AM
Artisan is offline
Find More Posts by Artisan
NM2K
Ringgold, GA, USA
Joined Jan 2006
thanks
Keep in mind that a bad battery (low voltage, insufficient capacity) or a defective Hall sensor can lead to problems, most of which manifest themselves at higher rpm.
You might want to bite the bullet and give R/C Ignitions or Brillelli a call to order a new C&H ignition system. Life is too short to troubleshoot out of production products, unless money is scarce and time is aplenty. BTDT myself, so I can understand that position with a history of experience.
I bought my last C&H ignition system from Brillelli for well under $100, plus I bought an add-on module (which made it slightly more expensive than $100) to add the Synchro-Spark automatic timing adjustment feature (not absolutely necessary, but nice).
I say this because lots of folks used to pot their electronic circuit boards in epoxy, making them basically unfixable. Some of the older Reichmuth ignitions might have been potted. Don't know for sure though. It is easy enough to see once you remove the cover.
Ed Cregger
Artisan is offline Find More Posts by Artisan
Article Zenoah 20cc Electronic Ignition Gas Engine Review RichN Engines 88 Mar 27, 2013 12:29 AM
Wanted FPE/Brison 4.2 gas engine with C&H Electronic Ignition Joe Elston Aircraft - Fuel - Airplanes (FS/W) 2 Jun 08, 2004 01:22 AM
new FUJI BT50EIS electronic ignition gas engine AMCross Product Announcements 1 Apr 17, 2004 08:07 AM
WTT my parkflyer for electronic ignition to fit gas engine Airshow Aircraft - Electric - Airplanes (FS/W) 5 Mar 25, 2002 11:02 PM
