Old Feb 06, 2016, 10:32 AM
natterjak is offline
Find More Posts by natterjak
Asks too many questions
natterjak's Avatar
Berkshire, UK
Joined Nov 2005
Safe charging current for old A123 cells?
I have some A123 cells which I've probably had for 7-8 years (since whenever they first became widely available, don't recall when that was). Their useful capacity is around 1600mAh now, down from 2300 when new. Just wondering what charging current would be deemed safe?
natterjak is offline Find More Posts by natterjak
Old Feb 06, 2016, 11:24 AM
Zeeb is offline
Find More Posts by Zeeb
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
Well I don't think the age is an issue nor the useful capacity for a charging rate. I generally charge my A123's about 2C.
However, might I suggest that with only 1600 mah capacity remaining, the batteries should not be used for a model airplane anymore.
Zeeb is offline Find More Posts by Zeeb
Old Feb 06, 2016, 02:21 PM
vollrathd is online now
Find More Posts by vollrathd
vollrathd's Avatar
Joined Jan 2007
I've got some 6S2P A123's around six years old. And still charge those 4600 Mah packs at 19 Amps.
Strange thing about these cells. When they get old, they still hold voltage at 40 Amps per cell, but their Amp Hours drops off as you've found.
(My models have 140 A123 cells in them)
vollrathd is online now Find More Posts by vollrathd
Old Feb 07, 2016, 03:16 AM
natterjak's Avatar
Berkshire, UK
Joined Nov 2005
Thanks and no worries on that front - they are actually flying in a 7S configuration in one of these! An application they excel at and cheaper than a replacement Dyson battery pack
Old Feb 07, 2016, 03:20 AM
natterjak's Avatar
Berkshire, UK
Joined Nov 2005
Thanks, sounds like I have no reason to worry about sticking with low charging currents, despite the diminished capacity. I've been staying on the cautious side and charging at 2.3A until now, but if your 6 year old cells still take 19A charges without issues then I'll ramp it up a bit. Useful info for me, thanks.
Old Feb 07, 2016, 07:09 AM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
I was looking at the pictures I took of my planes yesterday and I noticed that I was using A123's in 2006. I am still using those packs.
Al M is offline Find More Posts by Al M
Old Feb 07, 2016, 07:50 AM
vollrathd's Avatar
Joined Jan 2007
FYI reminder for readers of this thread. That's 19 Amp charge rate for a 2P pack, or 19Amps/2 which is 9.5 Amps per cell
Old Feb 07, 2016, 07:54 AM
vollrathd's Avatar
Joined Jan 2007
I'm kicking my self for not putting a 'new' date on the cells pulled out of those 36 Volt DeWalt packs. They are somewhere around 8 years old, and are still being used.
Old Feb 07, 2016, 10:55 AM
natterjak's Avatar
Berkshire, UK
Joined Nov 2005
That's a worthwhile clarification as I'd overlooked that distinction. Thanks.
Old Feb 07, 2016, 06:39 PM
Al M is offline
Wallingford, Ct
Joined Sep 2001
Vollrathd,
I started out to build four 4s 2300's and did, but I found 4 somewhat weak cells so I bought for more cells and replaced them. I built another pack from the culls and it was about 1800 mah. That pack became marginal a couple of years ago so I ditched it. Last summer I had one cell fail(short out)in one of the four remaining packs. I needed a 3s cell pack for some smaller planes so I reconfigured it and it works fine. All the cells were bought directly from A123 when you could still do that for the full price. It shows the price per flight or even year is trivial. Just checked my log and 1020 flights were accumulated.
Old Feb 08, 2016, 12:28 AM
vollrathd's Avatar
Joined Jan 2007
Vollrathd,
Yeah
One of my club members is using a 2S1P A123 battery pack for receiver power in a $$$$ kerosene turbine model. That pack was purchased new in 2009. I just ran a battery analysis on the pack on my Western Mountain CBA battery analyzer.
At 15 Amps load, it checked out at the same voltage, and within 2% Amp hours of a brand new A123 pack.
Old Feb 08, 2016, 07:03 AM
Al M is offline
Wallingford, Ct
Joined Sep 2001
And taking care of them does not take over your life if you want to be safe.
Old Feb 08, 2016, 07:09 AM
losi man is offline
Find More Posts by losi man
losi man's Avatar
United States, MI, Detroit
Joined Oct 2015
A123 cell can take abuse in charging and discharging..
I have A123 cells that are over 10 years old.. I always charge them at 5 amps. but in a jam charged them at 20 amps. cycle those weak batts and they should jump backup in capacity if not discard them..
losi man is offline Find More Posts by losi man
Old Feb 08, 2016, 11:45 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
For years I charged my A123s, while in the plane, with a Mastech 5020 @ 20amps.
With 2P planes that's effectively 10amps per cell; 20 for 1P.
Still do 20 via an iC3020 off 2Pbs in series; used for Zipping at 20 w/6S!
jrb is offline Find More Posts by jrb
Old Feb 08, 2016, 02:23 PM
vollrathd's Avatar
Joined Jan 2007
Yeah, really agree. A few years ago, I really screwed up while charging a two cell A123 2300 Mah battery. It blew the top off of the cells.
(They were being charged with my variable voltage, variable current limiting power supply. Unfortunately, the power supply was set to 14 Volts DC while charging two cell A123 pack.
Right after that, I bought my first Cellpro PL8 charger.
Kyleservicetech A123 Screw Up
http://www.wattflyer.com/forums/showthread.php?t=58745
Discussion Old Lipos left fully charged, safe? PeterSte Batteries and Chargers 11 Aug 12, 2015 12:34 PM
Discussion At what current can my Sub-c battery charge safely? PleaseandThanks Car Talk 5 Oct 07, 2014 10:19 AM
Discussion Charging Two Cell A123 Batteries 019019cjl FMA Direct 2 Feb 14, 2014 08:28 PM
Discussion Charging Two Cell A123 Batteries 019019cjl FMA Direct 0 Feb 14, 2014 10:44 AM
Help! I'm looking for a simple A123 charger capable of charging 5S at up to 10A current? 3D Romeo Batteries and Chargers 22 Oct 02, 2011 01:15 PM
