Old Aug 22, 2015, 09:06 AM
vito2772 is offline
Find More Posts by vito2772
United States, NY, New York
Joined Nov 2014
APM 2.6 alt hold problem!
So today was the fist time I took my new h550 with apm 2.6 to an open field. Stabilize flies beautiful. The issue lies in alt hold. When I flip it on, alt hold remains pretty accurate, until I give it an elevator input. If I go foward, it drops in altitude very quickly until I let go of the stick, then it returns to where it was. And if I go backward it will gain altitude quickly and then when I let go it will sink back down to where I flipped the switch.
How can I fix this? Thanks!
vito2772 is offline Find More Posts by vito2772
Old Aug 23, 2015, 10:08 AM
vito2772 is offline
Joined Nov 2014
Anyone?
Old Aug 24, 2015, 09:03 AM
vito2772 is offline
Joined Nov 2014
bump
Old Aug 24, 2015, 01:49 PM
artemen is offline
Find More Posts by artemen
artemen's Avatar
United States, CA, Sacramento
Joined Jun 2013
it is a very common and good known problem called vibration... check your logs and I bet your vibes are high.
there is also another issue with alt drop with fast forward flight in alt hold/pos hold , this is a current limitation of arducopter, there are "work arounds", but they are a bit complex and do not give reliable result.
artemen is offline Find More Posts by artemen
Old Aug 24, 2015, 06:25 PM
vito2772 is offline
Joined Nov 2014
I have my apm mounted on a antivibration mount. My other apm never had this issue, is there a fix?
Old Aug 24, 2015, 11:29 PM
sportybuckeye is offline
Find More Posts by sportybuckeye
United States, OH, Gahanna
Joined Sep 2013
I assume you have already put foam over the altimeter on the board. Even in the shell, draft / propwash throws it off.
sportybuckeye is offline Find More Posts by sportybuckeye
Discussion Problem to configure Fail Safe in APM 2.6 with turnigy 9xr and module FrSky Mineirodf Multirotor Electronics 1 May 29, 2015 06:33 PM
Discussion PLEASE HELP! apm 2.6 problems bembo Multirotor Electronics 7 May 28, 2015 03:40 AM
Question Alt and BarAlt wont track!? APM 2.6 PatrikC Multirotor Electronics 3 Mar 31, 2015 06:50 PM
Discussion Odd Alt Hold behavior APM 2.6 matrixman324 Multirotor Talk 2 Nov 09, 2014 03:29 PM
Discussion APM 2.5 will not hold ALT, and other ALT issues Adrian Lewer FPV Talk 31 Jul 14, 2013 01:39 AM
