Old Aug 11, 2012, 04:06 AM
crazy4airplane is offline
Find More Posts by crazy4airplane
Joined Aug 2012
New Product
High Speed pusher prop jet-Ultra Z Blaze
I saw a new Jet in the youtube. Called Ultra Z Blaze .
first , beautiful decal
second,durable EPO material.
third, pusher prop , i like this ... it is so nice in the sky and it fly very fast.
It can change into ducted fan jet , people try 64mm EDF. I would like to try 3 ducted fan together.
The structure of it is wonderful, there is a MAGIC plastic locker. This Ultra Z has two wings , with this Magic locker, two wings can be interchangeable.
This video is amazing , can help you know it.
ZETA ULTRA-Z astro & blaze (7 min 20 sec)
crazy4airplane is offline Find More Posts by crazy4airplane
Old Aug 12, 2012, 12:18 AM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
Nice looking plane and excellent flying!
djacob7 is offline Find More Posts by djacob7
Old Aug 12, 2012, 11:39 PM
rcfanfun is offline
Find More Posts by rcfanfun
Joined Aug 2012
yes, quite good. I like the design of "Magic plastic locker", easy connection between the wing and fuselage and easy to change the new one. i also saw a similar model ,like twins.
so this magic plastic locker can exchange the two pair of wings, oh...one fuselage, two wings, so it can fly slow or fast...haha so good
rcfanfun is offline Find More Posts by rcfanfun
Old Sep 10, 2012, 10:01 AM
frogforce is offline
Find More Posts by frogforce
Australia, QLD, Rubyanna
Joined Aug 2012
x3 edf
Oh Yeh get that idea into action, 3 fans got to better than one. Nice looking little delta. Could do in a funjet ultra. Keep posting your mods, Happy landings.
frogforce is offline Find More Posts by frogforce
Old Sep 15, 2012, 02:17 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
I've seen one of these at the LHS.it's quite a nice looking plane.who makes it though?can one order directly?
chop stiX is offline Find More Posts by chop stiX
Old Sep 15, 2012, 02:26 AM
chop stiX's Avatar
Joined May 2011
found the link to it http://www.rc-manufactory.com/produc...pcf7-f4-p73-o1
I think this could be an awsome twin pusher
Old Oct 29, 2012, 04:23 AM
rcfanfun is offline
Joined Aug 2012
http://www.rcmania.hk/article-995-22.html#.UEgbLmDxpoE
Old Oct 29, 2012, 10:28 AM
alanstraw is offline
Find More Posts by alanstraw
alanstraw
South Africa, GP, Randburg
Joined Apr 2012
The elevon setup on this as per the manual seems very strange indeed allowing no down aileron/elevator at all! Has anyone any experience with as it should be set up per manual?
alanstraw is offline Find More Posts by alanstraw
Old Oct 29, 2012, 10:52 AM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
I wouldn't be surprised if we would see this in HK fairly soon. Newzeta also makes the wing wing so if HK starts selling this, I would so buy it.
Koo is offline Find More Posts by Koo
Old Oct 29, 2012, 10:26 PM
rcfanfun is offline
Joined Aug 2012
Yes, it is necessary to follow the user manual, as I tried before. if not, it is not easy to find the CG and you will feel hard to fly it.
Old Oct 30, 2012, 01:36 AM
alanstraw
Joined Apr 2012
Even though using the setup as described in the manual allows for no down elevon? If I use the top hole in the servo arm and not the bottom one as described I can get down elevon.
Old Oct 30, 2012, 01:56 AM
chop stiX's Avatar
Joined May 2011
Something is wrong on this plane.it's not right to have to set your control surfaces like the manual?
who has flown this as per manual?
Old Nov 06, 2012, 01:55 AM
alanstraw
Joined Apr 2012
Have subsequently flown this as per suggested settings and strangely it performs just fine! Vey clever design as it leave lots and lots of options to play with motor size and correspondingly battery size and position.
What is very interesting , even with the setup as per manual (5 odd mm of up elevon) it flies inverted quite well??
Next stop a 28/26 3000Kv on 4s. It will really scream on that as its faily brisk as it is!
Old Apr 29, 2013, 11:40 PM
tom_sandiego is offline
Find More Posts by tom_sandiego
United States, CA, San Diego
Joined Jan 2006
Just got this bird from friend and will convert it to EDF 64mm fan. I need to know where is the CG and how the aileron/elevator set up, are they flush with the wings or few degrees up. Where i can find the manual for it.
Thanks, Tom
tom_sandiego is offline Find More Posts by tom_sandiego
Old Aug 25, 2013, 06:35 AM
ruppwf is offline
Find More Posts by ruppwf
ruppwf's Avatar
Germany, NDS, Wolfenbüttel
Joined Dec 2011
I fly the Ultra-Z Astro, having wings like the MPX FunJet. Central EDF is 64 mm -10 blade, Motor: Turnigy L 2855-2100kv on 6S 1500 mAh 45C.
Flight weight is 791 g , thrust 1050 g. Raises unlimited vertical.. Awsome sound - but very qiet. You nearly can't hear it flying past in a few meters.
ruppwf is offline Find More Posts by ruppwf
Sold Hitec HS-35HD Ultra nano feather high speed/torque servos $75 shipped for 4 ton2di Aircraft - General - Radio Equipment (FS/W) 2 Aug 03, 2012 11:15 AM
Discussion Skyangel / HK Nano jets Mig -29 converted to Pusher Prop UNGN Pusher Prop Jet Models 11 Jul 16, 2012 09:54 PM
Sold Futuba S9253 Ultra High Speed Tail Servo Tom.in.Maryland Aircraft - Electric - Helis (FS/W) 0 Jul 16, 2012 10:19 AM
Question Need More Speed on F.Jet Ultra: Bigger Prop or Smaller one? rcwarrior Power Systems 4 May 25, 2012 01:42 AM
Question FunJET Pusher Prop High Speed Jet alien7x7 Pusher Prop Jet Models 1 Nov 14, 2009 11:35 PM
