Old Sep 11, 2010, 07:58 AM
R. C. Day is offline
Find More Posts by R. C. Day
Grand Prairie, Texas
Joined Feb 2002
Speed 300
Any recommendations on Speed 300 motor for (RBC style, 24" W/S) small parkflier Warbirds?
R.C.
R. C. Day is offline Find More Posts by R. C. Day
Old Sep 11, 2010, 09:51 AM
eye4wings is offline
Find More Posts by eye4wings
...design-build-fly-publish...
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
All the 'speed' motors are old technology. Short service life and efficiency in the 40-50% area.
If you are just starting out on the hobby there seems little point in limiting yourself to short flight times when a small brushless motor can almost double your motor efficiency and therefore almost double your flight time on the same battery pack.
Why not have a look at the selection from Hobby King or similar budget sites?
eye4wings is offline Find More Posts by eye4wings
Old Sep 11, 2010, 12:08 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
This will serve you a lot better than a heavy 300 with lousy efficiency:
http://www.hobbyking.com/hobbycity/s...idProduct=8617
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 11, 2010, 12:25 PM
Joined Feb 2002
Eye4wings,
Thank you for the insight, I will follow your lead, Dr. Kiwi is right in step with you.
Dr. Kiwi,
I also appreciate the link and recommendation, I will order a few of them and give them a try.
Thanks for the help guy's, I really appreciate it!
R.C.
Old Sep 11, 2010, 01:16 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
You need to determine the best prop size for your aircraft... then choose the appropriate Kv for the Turnigy 2730 which you want to get... unlike a geared motor you can't change the ratio to suit the prop size you want... with outrunners you select the correct Kv to suit the prop and the pack (e.g. 2s or 3s) you want to use.
Old Sep 11, 2010, 09:12 PM
Joined Feb 2002
Dr. Kiwi,
My thread was intended to ask for a brushless outrunner recommendation to replace a brushed speed 280/300.
However my question was hastily assembled and did not transmit my request, yet in the end, the response was just what I was looking for.
I chose Turnigy 2730 1700kv, I will pair it with a 12Amp speed controller, 2S battery and 7x6 prop for a balsa built 24" parkflier (RBC) warbird.
Thanks for the help,
R.C.
Old Sep 12, 2010, 09:35 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
Hi R.C.
Another source for stuff is HeadsUpRC which is located in the USA. I like them 'cause all the info you need is there but in layman terms and easily understood.
Here's a link to their homepage-
http://www.headsuprc.com/servlet/StoreFront
Also have cheap shipping.
Jim
aeronca52 is offline Find More Posts by aeronca52
Old Sep 14, 2010, 10:52 PM
Joined Feb 2002
Jim,
I appreciate the help; I am putting together a few little 280 class park flier war birds and want to power them with a Lipo powered brushless equivalent.
Thanks again,
R.C.
Found SPEED 300 PLUS 7.2V / SPEED 300 motor and Motor Controller dennisofnc Aircraft - Electric - Power Systems (FS/W) 4 Mar 20, 2007 09:51 PM
Is the Graupner SPEED 300 motro the same as the GWS 300? AuzzieRCFlyer Parkflyers 16 Aug 18, 2003 08:21 PM
Speed 300 vs. GWS 300 C CooLJ92 Power Systems 7 Jul 02, 2003 01:17 AM
Graupner speed 300 vs GWS 300 dpoles Parkflyers 9 May 08, 2003 05:44 PM
Can i use the Graupner Speed 300 6v on the GWS EPS 300-C System? Nik-rc Power Systems 1 May 04, 2003 08:15 PM
