Old Apr 09, 2013, 08:58 PM
United States, AR, Pottsville
Joined May 2012
Help!
Newbie...Ran over log! Need ? parts.
Hit a log. broke prop. Bent shaft.
This is the boat. McCullough gas engine...Octura 1470 prop. Someone told me the prop was too small.
I need some help...I am new to boats-- If anyone would be so kind. I don't know a reputable place to buy boat parts. Also, exactly what prop and shaft should I get? Thanks in advance.
Michael
479-280-2142
MOJOMOJO1 is offline Find More Posts by MOJOMOJO1
Old Apr 09, 2013, 09:27 PM
Need a bigger runway
sandydr's Avatar
Dominican Republic, Puerto Plata, Cabarete
Joined Mar 2008
MIchael, I have always found Tony at Warehouse hobbies http://www.whobbies.com/ to be extremely patient and and they are a reputable outfit. There are other good dealers out there, but you need to know exactly what you want.
I can't blow your pics up enough to see the type of shaft you have. From a distance it looks like a 3/16 or 1/4 square end. For your size of setup, it should be 1/4.
I am clueless on props, I just trawl through forums looking at others setup who has a similar boat to mine.
sandydr is offline Find More Posts by sandydr
Old Apr 10, 2013, 09:25 AM
Joined Feb 2012
I would do some On-line research make model shaft size. Google would be best it looks pretty old. If all else fails I would also say shoot Tony an Email he will still want to know what size shaft you have though.
MN fish is offline Find More Posts by MN fish
Old Apr 10, 2013, 11:57 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
An Octura 1470 is the wrong prop for it as it's considered a lifting prop made for hydroplanes, not a Deep-Vee hull. Possibly an Octura X-470 as that's a no- to low-lift prop.
Tony Castronovo at Warehouse Hobbies is a member here but only pops in when he can.
Ron Olson is offline Find More Posts by Ron Olson
Old Apr 11, 2013, 09:25 AM
Joined Feb 2012
Give more up close pics I bet Ron can figure out what you need!
Old Apr 11, 2013, 11:04 AM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
I order a lot of similar parts through www.zippkits.com . you're probably going to need a new stuffing tube if that's damaged, local hobby shops or hardware stores carry K&S tubing so that should be easy to get locally. Go with 5/16" ID tubing as it gives the cable a little room.
Tony at WHH carries the square drive cables and anything else you might need.
Discussion I need some people to look over this. SingularInfinity Multirotor Talk 12 Apr 08, 2013 11:13 AM
Discussion Parker Mt 11/10/06. Ran over plane by car John Kim Dynamic Soaring 21 Nov 12, 2006 09:02 PM
My Corona got ran over! losinground Electric Heli Talk 9 Nov 20, 2004 06:45 PM
----WTB---- Spare DragonFly/Hummingbird parts FP (NEWBIE NEEDS EXTRA PARTS) Bschulz Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2004 11:23 AM
