Old Jun 19, 2015, 07:53 PM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
United States, AR
Joined Nov 2014
Build Log
Three hour build of the Moon Drifter!
My newest design. I give you the Hinieball. Basic airframe is done, will start on the undercarriage, get a weight and pick the electronics, 5g servos on the rudders, X2
9g on the elevator.
If this is my last post at RCG, it has been fun. I have been reported for less. Kimber got a
suspension for posting Bart Simpson mooning.
I hope it flies good, I would hate to crack it up.
Moving right along with this project, sure don't want to get behind. Be interesting to see
how it handles wind. Do you think this prop makes the tail look big?
With all the stuff still in the bags, piled on the scales, AUW is 308g. That includes the battery.
All done, ready to fly, AUW 300g. Span 29.5". Power available. 99W.
I put all the mechanicals underneath to keep the top clean, painted the motor stick
and control rods white to blend in.
I christened it "Moon Drifter".
BHOFM is offline Find More Posts by BHOFM
Old Jun 19, 2015, 09:10 PM
C₄H₁₀ is online now
Find More Posts by C₄H₁₀
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
Joined Aug 2009
Any particular reason you've gone with a separate motor mount stick on top? The way I've always built this sort of model, I just mount the motor to the main stick underneath.
Looks like it needs a pilot figure named "Ben Dover".
C₄H₁₀ is online now Find More Posts by C₄H₁₀
Old Jun 19, 2015, 09:22 PM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
The under stick is balsa. Don't feel it is suitable for motor mount. I did the stick on top to get
more prop clearance. Glad I did, the 10X4.7 draws 11.9A with a 2s battery. The motor and ESC
are rated to 12A, 15A momentarily. Tried the 9X4.7 first, just at 9A.
May add a pilot!!!!
Old Jun 20, 2015, 12:30 AM
S.Davy is offline
Find More Posts by S.Davy
Save a tree fly a foamy
United States, CA, Marshall
Joined Apr 2005
Originally Posted by BHOFM View Post
May add a pilot!!!!
Yikes!
PS Think you should make it a twin with contra rotating three blade props AND differential thrust.
S.Davy is offline Find More Posts by S.Davy
Old Jun 20, 2015, 01:31 AM
SpaceDrydock-22 is offline
Find More Posts by SpaceDrydock-22
"Use the foam, Luke!"
SpaceDrydock-22's Avatar
Finland, Kuopio
Joined Aug 2010
Looks like stretched nutball.
SpaceDrydock-22 is offline Find More Posts by SpaceDrydock-22
Old Jun 30, 2015, 07:27 AM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
Well, this project was pretty much a fail. File it under "learning".
Worked on it most of the afternoon yesterday. Many flights, maybe a dozen.
Rudders are not in the prop wash. Very ineffective. Max throw, 125%, they only work
at high speed, slow into a hover and they are gone. Min elevator throw was still very dicey.
When it got down wind, the only thing to do was put it down and go get it. Tried to circle
and get it back, but each circle just got farther away. Four long walks is too much for a
bald headed old fat man.
It has tremendous amounts of power, even on 2s, 3s was a bit too much. Just that the rudders
are too far outboard.
It did fly, in light air it was manageable. Not fun, just manageable. One minor crash, broke the
prop. The rest of the flights, landings were just acceptable.
I am going to cut it down to a hybrid Nutball, O-Fungle. Some lighter wheels and a smaller
prop, or smaller motor.
The fact that it came home undamaged after so many flights, maybe "fail" is the wrong word??
Old Jun 30, 2015, 02:12 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Not a 'Fail'.
Obviously needs a second motor and differential throttle.
eflightray is online now Find More Posts by eflightray
Old Jun 30, 2015, 07:20 PM
cflchurch is online now
Find More Posts by cflchurch
cflchurch's Avatar
United States, PA, Plum
Ive always wondered what BHOFM stood for..... now I know. Cant wait to see the dual motor version .
cflchurch is online now Find More Posts by cflchurch
Old Jun 30, 2015, 08:46 PM
BHOFM is offline
Kimbers Keeper.
United States, AR
Joined Nov 2014
It is too late, it went under the knife. It is now a 19" Nutball with slightly modified control surfaces.
Getting ready to glue the wind dihedral, making coffee at the moment. My personal special blend.
Shipped in from South America.
Pictures later if anyone is interested, just a Nutball. Like butt holes, everyone has one and they
pretty much look the same.
For Sale 2 gopro cams.. need gone in three hours! SageHillsPilott FPV Equipment (FS/W) 2 May 05, 2015 02:35 PM
Build Log Craft air drifter 2 build clwhipper Sailplane Talk 18 Feb 16, 2014 12:07 PM
Discussion First full scale flight in three hours! infopimp Slope 24 Nov 27, 2006 10:50 PM
I just spent three hours........................ turbojoe Parkflyers 24 Apr 15, 2003 07:32 PM
