Old Sep 25, 2014, 11:16 AM
ehall8702 is offline
Find More Posts by ehall8702
United States, FL, St Augustine
Joined Sep 2014
NEEWER Mystery Cloud-100a ESC
yeah i know its cheap, but ive been all over looking for programming instructions and all i see is frustrated people like myself. Description i bought it for was "Mystery 100amp LiPo cool water brushless speed controller for boat" all the programming i have found does n ot work . I have managed to be able to change between lipo settings (ie 2s-6s) and forward nd reverse OR forward only nd thats about it mine has 6 main options .1st option has 7 sub options, which are battery settings 2nd option has 3 sub options which i have no idea what they are, 3rd option has 3 sub options (1st is forward only and 2 is forward and reverse, no clue what 3rd sob option does) 4th option has 5 sub options, 5th option has 3 sub options, and 6th option has 2 sub options which i believe is the RPM limit settings. It doesnt line up with any of the programming instructions i have found . ive tried ALL settings and options and my main concern is getting the "soft start" turned off.....it drives me nuts. Honestly ive got another ESC and took water block off and put regular heat sink on and put in my car so u can only imagine how annoying it is with soft start and the 4s lipos kick in after a second or two... Any help would be appreciated...
ehall8702 is offline Find More Posts by ehall8702
Old Sep 26, 2014, 02:50 AM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi ehall8702,
I use these instructions for my Mystery ESC's and did manage to get all of them working:
http://www.google.nl/url?sa=t&rct=j&...76247554,d.ZWU
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Oct 02, 2014, 11:45 AM
Joined Sep 2014
those are the ones I have tried to use but only can change battery section and forward/reverse ( as far as I can tell) ohh well ill keep it for a back up esc as soft start isn't an issue on the water. I just ddont want timing settings to ruin a motor because idk what itstset to.
Old Oct 16, 2014, 05:46 PM
walt pommnitz is offline
Find More Posts by walt pommnitz
Sunny Springer
walt pommnitz's Avatar
United States, NJ, Clark
Joined Jul 2007
Walt P here and I can relate to your fustrations with MYSTERY ESC's. I can't believe they send out a product without instructions or a way to contact them. I have their 80amp Cloud and a 70 amp UBEC and I don't know what to do.
walt pommnitz is offline Find More Posts by walt pommnitz
Old Oct 18, 2014, 06:24 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
This should be it i am thinking. Cant hurt to try, its made by mystery.
scorpion1 is offline Find More Posts by scorpion1
Old Oct 29, 2014, 10:18 AM
PTSkipper is offline
Find More Posts by PTSkipper
Joined Oct 2014
scorpion 1 the manual is a great help have just got a 200 first one I have bought, it is going into a second spartan boat with mod setup arrangement andain thanks
PTSkipper is offline Find More Posts by PTSkipper
Old Oct 29, 2014, 04:09 PM
Sneek, Netherlands.
Joined May 2004
All cheap ESC's should be checked;
- take off the shrinkwrap.
- lift the (water)cooler from the Fets.
- check how many Fets actually touch the cooler. (see picture below)
- file the Fets into one plane and refit the cooler with a light smear of heatconducting paste.
- put on new shrinkwrap.
- if your boat isn't 100% dry after a run, seal the shrinkwrap to avoid shorting out the ESC.
The light spots show where the Fets had physical contact with the cooler...:
Regards, Jan.
Discussion Mystery 100A esc curtqn Racing Boats - Electric 2 Nov 15, 2013 04:10 PM
For Sale Mystery PENTIUM ESC 100A, used, PP $40 ditman Aircraft - Electric - Power Systems (FS/W) 0 Feb 05, 2012 07:27 AM
Sold Mystery 100A ESC w/3A UBEC Pickle72 Aircraft - Electric - Power Systems (FS/W) 6 Aug 12, 2010 06:29 PM
Sold Mystery 100A ESC gallfer Aircraft - Electric - Power Systems (FS/W) 3 Nov 02, 2009 10:21 AM
Discussion Watercooling Brushless Mystery 100A ESC?? syncronized Racing Boats - Electric 10 Sep 16, 2008 12:20 PM
