Old Jul 16, 2014, 01:18 PM
Torch8 is offline
Find More Posts by Torch8
Torch8's Avatar
NYC
Joined Aug 2010
Quads similar to V252
Which micro quad is most similar to V252 in terms of speed, agility, LED lights that you can see and wind resistance?
Torch8 is offline Find More Posts by Torch8
Old Jul 16, 2014, 02:47 PM
ogrope1 is offline
Find More Posts by ogrope1
France, IdF, Paris
Joined Oct 2011
JJRC 100 is very close. Also jxd 388 but a bit overweight, I just use the board on a light frame with some 0712 chaolis and it kills the v252 in every aspect.
ogrope1 is offline Find More Posts by ogrope1
Old Jul 16, 2014, 11:43 PM
davids2013 is offline
Find More Posts by davids2013
Joined Apr 2014
V929 and Hubsan X4
davids2013 is offline Find More Posts by davids2013
Site Sponsor
Latest blog entry: Build a mini Quadcopter?
Old Jul 17, 2014, 06:55 AM
MassiveOverkill is online now
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Except for LED lighting, JXD 385. The V929 is no where even close to a V252 in any way shape or form. The V242 is identical to the V252 except for slight difference in body shell. We have about 30 left. Once they're gone............they're gone forever
MassiveOverkill is online now Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Jul 17, 2014, 07:00 AM
SeByDocKy is online now
Find More Posts by SeByDocKy
http://www.drone-maniac.com/
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
YI ZHAN X4 also is great flyer too (V2x2 compatible)
SeByDocKy is online now Find More Posts by SeByDocKy
Old Jul 20, 2014, 05:39 AM
mahagr is online now
Find More Posts by mahagr
Joined Jan 2014
On those quads which I own, JJRC 1000 is the closest quad to V252 which I've flown. And personally I like JJRC more than V252 even if it's slightly slower.
mahagr is online now Find More Posts by mahagr
Old Jul 20, 2014, 07:07 AM
SeByDocKy's Avatar
Joined Dec 2012
The JJRC seems to be the winner contest
Old Jul 22, 2014, 10:12 AM
Torch8 is offline
Torch8's Avatar
NYC
Joined Aug 2010
ok I almost ready to get JJRC 1000.
Compared to V252 update frosted version with improve Yaw rate.
1. which has better Yaw Rate?
2. Wind Resistance
3. Outdoor daytime LED visibliltiy
I can see the red LEDs on V252 outdoors no problem.
4. Durability
Old Jul 23, 2014, 01:35 AM
Joined Jan 2014
1. Not sure about the yaw rate as I only fly with Devo 7E, which has fixed yaw in the model. There isn't huge difference between those two, though..
2. JJRC 1000 is slightly heavier which means that it's also less sensitive to wind.
3. V252 (frosted) has brigther lights, JJRC has dimmer but X shaped lights. X shaped lights help a lot on figuring out the orientation of the quad but may be harder to spot on bright sunny day.
4. Not sure yet as I've not crashed with JJRC. I do know that V252 (frosted) body is one of the weakest I own.
See also
http://www.rcgroups.com/forums/showp...3&postcount=34
Old Jul 23, 2014, 06:56 AM
muck76 is offline
Find More Posts by muck76
muck76's Avatar
Joined Mar 2006
The jjrc is heavier and you can tell in flight. I put the 0720-14 motors and that took care of it. The body is a tough frame. Even though the leds are backward in color versus the 252 l, they do show up very well at night. Almost a cleaner led. Its has been worth the 35 I paid from tmart.
My nanotech 300mah lipos do stick out the rear. So I bOught the 260s.
muck76 is offline Find More Posts by muck76
Old Jul 23, 2014, 08:55 AM
Torch8 is offline
Torch8's Avatar
NYC
Joined Aug 2010
Thanks I am just to use sam stock lipos that came with V252 and my LB V2.
Old Sep 04, 2014, 07:02 PM
Rexopg is offline
Find More Posts by Rexopg
Joined Aug 2014
v252 brittle body shell
Got a cracked upper arm seems like bottom shell holding up a bit, wondering instead of v252 replacement shells has anyone tried using jjrc1000 or cg022 shells might need some slight mod to fit the v252 board.
Rexopg is offline Find More Posts by Rexopg
Old Sep 22, 2014, 09:33 AM
gfb107 is offline
Find More Posts by gfb107
United States, NC, Cary
Joined Sep 2014
I'm also wondering about the feasibility of transplanting a v252 (improved) into a JJ/RC 1000 or Eachine CG022 shell.
Shells for the v252 are very hard to find, so I'm looking for alternatives. Anyone have suggestions for others shell that might work? Maybe a JXS 385 or Hubsan X4L?
gfb107 is offline Find More Posts by gfb107
Old Sep 26, 2014, 11:32 AM
Joined Jan 2014
Order one of these: http://micro-motor-warehouse.com/col...for-7mm-motors
As I have two extra V252 FCs, I'm going to try one as soon as I get them.
Old Sep 26, 2014, 12:12 PM
gfb107 is offline
Joined Sep 2014
Thanks. Ordered a couple, think I got the glow-in-the-dark ones!
Sold misc micro quad parts v252 nqx muck76 Aircraft - Electric - Multirotor (FS/W) 2 Jun 30, 2014 03:56 PM
Wanted Blackout Mini H quad (or a quad similar in size) Wrice4 Aircraft - Electric - Multirotor (FS/W) 7 Feb 11, 2014 11:45 AM
Mini-HowTo Prevent damage and make batteries easier to remove on v252 and Hubsan X4 series quads ajg23 Mini Multirotors 1 Dec 23, 2013 07:15 AM
For Sale camera / landing gear for a quad or similar.... Joe in Dublin FPV Equipment (FS/W) 8 Nov 23, 2013 04:08 PM
Sold Almost new V252 RTF Jasen40 Aircraft - Electric - Multirotor (FS/W) 1 Sep 13, 2013 11:54 PM
