Old May 30, 2014, 11:50 AM
scigs30 is offline
Find More Posts by scigs30
Joined May 2005
Build Log
Guillows Lancer Build
I am building the Guillows Lancer for the 2014 Guillows challenge. It is built per the plans with minor modifications. 1. Removable nose block. 2. Made the landing gear wire longer and used thread to attach to the fuselage. The new kits are coming with the grey and white tissue, don't know why this makes for an ugly build. I have a older Lancer kit and used the yellow and blue from that kit. Also I don't like the side plastic cowlings so I won't be using those. The plans show a different color scheme for a built gas powered Lancer and that is what I went with. Except I had to extend the blue tissue on the wing tips because the second rib would not be suitable for anchoring tissue. All built she weighs 26 grams.
scigs30 is offline Find More Posts by scigs30
Old May 30, 2014, 01:43 PM
scigs30 is offline
Joined May 2005
Here she is finished in Old Guillows Tissue. Applied with thinned white glue and finished with 2 coats of Nitrate Dope. The wood quality was ok, little die crunched but lite enough for freeflight. Built in couple of days using white glue and Testors Cement. This is the second Lancer I have built, the first when I was 9 and did not know what I was doing. Back then I built the plane with Testors wood glue and the fuselage came out looking like a banana. I attached the tissue with colored Aerogloss dope and it came out ugly. I tried to fly the plane and the landing gear broke off and I crushed the wing trying to attach with rubber band, this time I glued the wing on.
Old Jun 03, 2014, 09:16 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
Waiting for the flight video.........
aeronca52 is offline Find More Posts by aeronca52
Old Jun 09, 2014, 10:35 AM
MiZer1981 is online now
Find More Posts by MiZer1981
United States, WA, Mt Vernon
Joined Jun 2014
Nice!
Brings back many a fond memory of my childhood
MiZer1981 is online now Find More Posts by MiZer1981
Old Jun 30, 2014, 09:00 PM
ccarley is offline
Find More Posts by ccarley
Joined Dec 2005
I will be putting one of these together with my daughter soon
ccarley is offline Find More Posts by ccarley
Old Jul 03, 2014, 02:32 PM
larryg is online now
Find More Posts by larryg
Joined Jan 2007
i just bought a Javelin kit today, same wing and span as the Lancer, just wondering if a little bigger prop than whats comes in the kit is better ? just looks small at 6 inches lol , your Lancer looks beautiful
larryg is online now Find More Posts by larryg
Old Jul 03, 2014, 07:11 PM
Culper Junior
eastern pa
Joined Feb 2007
Larry,
You most likely already know this, but I was always taught that the prop diameter should be 1/3 the wing span. So your 24" wing should use an 8" prop for good results.
Here's some thoughts...http://volareproducts.com/BUY/index....ex&cPath=70_71
Discussion guillows lancer build paulatgis Micro Ready-to-Fly 3 Aug 11, 2009 09:32 AM
Discussion Guillows Lancer RC Conversion *Power Questions* finchkid24 Scratchbuilt Indoor and Micro Models 22 Jun 02, 2009 02:37 PM
Discussion Guillows Lancer and Javelin williame3590 Vintage & Old-Timer Designs 6 Sep 26, 2008 05:15 PM
Discussion Guillows Lancer duration Mr-Punk Free Flight 4 Sep 06, 2007 11:08 PM
Guillow's Lancer- Not great Megowcoupe Scratchbuilt Indoor and Micro Models 5 Sep 07, 2006 07:15 AM
