Old Jan 12, 2015, 12:10 PM
2Doggs is online now
Find More Posts by 2Doggs
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Robust
All I can report is that mine have stood up well to many crashes on my 500, without any apparent ill effects!
I think they're unbeatable value for money on a 500.
2Doggs is online now Find More Posts by 2Doggs
Old Jan 12, 2015, 01:05 PM
ryane67 is online now
Find More Posts by ryane67
I'll fly (and crash) anything!
ryane67's Avatar
United States, MI, Orion Charter Township
Joined Mar 2013
Thanks I'm considering them on a 60" extreme flight airframe... or maybe I should get another 500 class heli.. hahaha
ryane67 is online now Find More Posts by ryane67
Old Jan 12, 2015, 03:29 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
It is too quiet about these servos. Seems the 500 class it not that popular anymore?
I never got these for my Protos500. The used frame came with Hitec HS-5245MG servos and they seem to hold up perfectly. Basically got the heli for free with the servos
Might get the 732 again to try on the hurricane425.
sp00fman is offline Find More Posts by sp00fman
Old Jan 12, 2015, 03:47 PM
2Doggs's Avatar
Joined Nov 2009
You lucky, lucky Dutchman! I would love to have a Protos!
Old Jan 12, 2015, 07:32 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
I just got another 3 for my Gaui X4 II. Ran them on the tester for half an hour to check them and bed in the brushes.
The case on these servos look very similar to the MKS DS9660A. I wonder if that is what they are modeled after.
My other set are still going well on the 500DFC, so that's what lead me to getting another set for the X4, that and the price.
beenflying is offline Find More Posts by beenflying
Old Jan 12, 2015, 08:09 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Compare this MKS DS9660A gear set with the picture in the first post:
Old Jan 12, 2015, 11:15 PM
ryane67's Avatar
Joined Mar 2013
pretty darn close!
Old Jan 13, 2015, 05:54 AM
Hexperience is offline
Find More Posts by Hexperience
devIAtion..one TX to bind them
Hexperience's Avatar
Canada, ON, Georgina
Joined Aug 2011
Are the rest of the internals the same as the old ones? I had one of the old ones that was bad out of the box and never got around to replacing it. Do you think we'd be safe mixing cyclic old and new?
Hexperience is offline Find More Posts by Hexperience
Old Apr 02, 2015, 12:37 AM
darrynl is offline
Find More Posts by darrynl
Cape Town, South Africa
Joined Sep 2007
So would you guys suggest these HK-752MG servos for the cyclic of a T-Rex 500 DFC with a BeastX FBL controller?
I am still learning on Forza 450, so I will only be doing sport flying, no 3D or anything like that?
TIA
darrynl is offline Find More Posts by darrynl
Old Apr 02, 2015, 04:17 AM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
They are great servos for pretty much any FBL controller. Should work fine.
ridge_racer is offline Find More Posts by ridge_racer
Old Apr 06, 2015, 02:51 AM
2Doggs's Avatar
Joined Nov 2009
TIA
The T-Rex 500 will sound noisy compared with your Forza! Don't forget you can run 350 blades on the Forza, maybe with the 14t pinion, which makes it fly a bit "bigger". I like how smooth and quiet (and tough!) my Forza is so much that the only 500 I will now consider is a Protos.
Old Apr 26, 2015, 01:38 PM
pdooley is online now
Find More Posts by pdooley
You can call me Pat
United States, FL, Tampa
Joined Dec 2013
I'm running TGY 930's on my 500 now. They are rated at 0.14sec/60degrees, but they feel more like 0.20sec.
Looks like the 752's are back in stock. I'm getting 3.
pdooley is online now Find More Posts by pdooley
Help! hobbyking new mini osd w/gps abletowinginc FPV Equipment 15 Jan 08, 2015 07:56 AM
Discussion New Henge MD732 and HobbyKing HK-732MG Mini Tail Servo beenflying Mini Helis 43 Apr 26, 2013 02:20 AM
Discussion Multiwii Mini Flight Controller HK Hobbyking alll Mini Multirotors 40 Apr 15, 2013 09:12 AM
For Sale Set of 3 Good Condition Futaba 9451 Coreless Digital Cyclic Servos helinut4ever Aircraft - General - Radio Equipment (FS/W) 0 Jan 04, 2013 06:54 PM
Sold 3x 3x HK-933MG (Henge) Servos - $22 shipped DudeInMyrtleBch Aircraft - General - Radio Equipment (FS/W) 1 Dec 31, 2012 05:44 PM
