Old Aug 10, 2014, 02:55 AM
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
+1 on the 10 amp BEC
bryansifsof44 is online now Find More Posts by bryansifsof44
Latest blog entry: Weights for planes
Old Aug 10, 2014, 06:28 PM
AeroHeadTW's Avatar
United States, NJ, Berkeley Heights
Joined Nov 2009
Thanks guys.
I'm ok wo buying the castle link as I just want the default 5.1v (not using high volt servos)-- right?
AeroHeadTW is offline Find More Posts by AeroHeadTW
Latest blog entry: My Selected FPV Flights
Old Aug 10, 2014, 07:54 PM
Joined Oct 2011
6.3v gives you a faster stronger non HV servo... I would strongly consider bumping the voltage up.
Old Aug 14, 2014, 01:04 PM
tmsn's Avatar
USA, CA, San Francisco
Joined Dec 2009
Finally building my Extra EXP. Almost done.
Does everyone think it is absolutely necessary to open the bottom of the fuselage for air exhaust? Someone at a local field decided not to do it and reports no increased temperatures, and the plane does look nicer (and ostensibly flies nicer too)
Edit: Also, I will be running my 7245MHs at 8.0v, but HiTec's specs seem to specify a 7.4v limit on voltage. Is that not right?
tmsn is offline Find More Posts by tmsn
Old Aug 14, 2014, 08:02 PM
Joined Oct 2011
I noticed 20F difference in motor temp from 1 flight, when I forgot to cut mine out... Plus it will cool the battery.
On the servos... I conformed from mike at Hitec their HV servos are designed to run off of a fully charged lipo. I set mine to 8.2v to simulate sag. A BEC will have some sag to, I just never needed any more speed or power then 8.2.
Old Aug 14, 2014, 08:31 PM
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
Originally Posted by AeroHeadTW View Post
Thanks guys.
A couple of years ago, I started using the CC 10-amp separate BEC so I could bump the voltage to my servos up to 6 volts from the 5 volts the Turnigy Plush speed controls I'd been using (with great success) supplied.
The difference was phenomenal. Every plane I did this on "woke up" instantly. In some cases it was like it was a whole new plane.
You really need to go to 6 volts. It makes a very significant difference.
Depronicus is online now Find More Posts by Depronicus
Old Aug 16, 2014, 02:47 PM
hanzipv's Avatar
Czech Republic, Olomouc, Prostejov
Joined May 2012
I bought a used EF Extra 60 last fall. It's now a couple of years old and has been flown on 6s using an airboss 80amp esc and the built in bec.
According to the manufacturer, older versions had a bec that wasn't so great when used with 6s (apparently newer versions are ok?).
I took a pic of mine, but it looks the same as all the others on the web. Does anyone know how to tell the difference? Note I have the older version of the motor, so I'm running the smaller 15x6 prop size.
I'd like to get some flights in this weekend, but I'm a little spooked.
If it comes to it, any suggestions for a bec?
Aero
I recommend BEC WESTERN ROBOTICS !
Perfect !
better than castle Creation !
http://www.western-robotics.com/herc...ini_plane.html
hanzipv is offline Find More Posts by hanzipv
Old Aug 17, 2014, 01:22 PM
tmsn's Avatar
Joined Dec 2009
I'm still waiting for a replacement stab and elevator - broke mine while building - so I haven't flown yet.
But I did do a partial fitting of all the parts and installed all the electronics and balanced the plane.
It felt extremely heavy though, so I weighed it and my AUW seems to be 6.2 pounds. Way heavier than any of my other EXPs, even though part by part it's got the same electronics as my old Laser EXP.
Ice Lite 100, CC BEC, 3300Mah 6s battery, torque MK2, 7245s all around, etc.
I was expecting more like 5 or 5.5 pounds.
What's everyone's AUW?
Old Aug 17, 2014, 04:36 PM
Depronicus's Avatar
Southern California
Joined May 2009
Originally Posted by tmsn View Post
... AUW seems to be 6.2 pounds...
...Ice Lite 100, CC BEC, 3300Mah 6s battery, torque MK2, 7245s all around, etc.
With essentially the same component list as yours except for two 3S 3300 batteries in series:
Laser: 6 lbs., 3 oz.
Edge: 6 lbs., 4 oz.
MXS: 6 lbs., 6 oz.
Old Yesterday, 02:14 AM
Joined Oct 2011
Here are my 60" Extra weights
Dry w/o pants - 4.48lb, Dry w/ pants - 4.56lb,
With batts 6s3300s of various weights
Ideal 5.62-5.7lbs, Heaviest - 5.74lb
MF 4315-480 (lightened)
Xoar PJN 16x8
Ice lite 100
10amp BEC
7245s
Build Log Extreme Flight 70" Extra 300 EXP - build/fly/video hercdriver7777 3D Flying 2454 Aug 14, 2014 06:39 PM
Build Log Extreme Flight 60" Edge 540T EXP - Build/Fly/Video FlopGun 3D Flying 249 Apr 16, 2012 10:46 AM
Help! D-60 build thread Chronic DS'er Dynamic Soaring 3 Jun 23, 2011 10:04 PM
Sold Extreme Flight 58" Extra Ready To Fly (GA) traderdave2 Aircraft - Electric - Airplanes (FS/W) 11 Apr 26, 2011 05:33 PM
Video EXTREME FLIGHT RC EXTRA 300EXP in Action! EXTREME FLIGHT Electric Plane Talk 1 Jun 10, 2009 08:45 PM
