Espritmodel.com Heli Air
Old Aug 21, 2012, 09:23 PM
Canada, BC, Abbotsford
Joined Nov 2010
Originally Posted by rotoraddict View Post
What other blades, besides Align (in the blade arena, they are generally considered to be on the low end of the quality/performance spectrum), have you flown?
I listed the Align blades so people would have an idea on weight. Up to now been using HK wood blades that I machine the bottom for a closer type to scale.
What blades do you think they should be compared to, I only know of two makers of scale blades. And you can't really compare them to the sym blades since they are not designed for anything other than scale flight. You sure wonld never go inverted with these, and I run them as slow as I can with out burning up the esc. or untel I loose tail control.
JamesBC is offline Find More Posts by JamesBC
Old Sep 05, 2012, 10:24 AM
kin
Joined Sep 2007
The scale blades new 120g version out market since last month about 300 piece . All commend is positive and nothing complain , Just sorry for the first test pilot wrong sent you the (photo use) blades set .J x company Japan have testing it .Base commend is positive ,I have cut more than 3 type (super good band name ) 3-D blades .the safty level we still keep in high . We are not the best rotor blades, but i hope we can stay in the best safty blades . I cut my SM blades a section about 5 cm distance(close the blades grip ) from the screw hole . it still keep 35% carbon material in that section . extremely strong , just the production cost is higher ,But keep the customer safty is the first i want , but i hope that second photo germany products no more in market . the big bubble is a space inside (hollow) , it is the epoxy not stick well the inside filler material . after tempurature change especial after weather warm . the air get bigger volum . the bubble be come bigger , it is very dangerous if you make a hight G trurn , if the high G turn let the force focus in this point and than......... please see this topic .
http://www.rcgroups.com/forums/showt...489588&page=22
kin is offline Find More Posts by kin
Old Sep 06, 2012, 11:53 AM
Track clear , smoke on !
cap231ex's Avatar
3 miles from AMA HQ Muncie, IN.
Joined Jan 2009
So when will these blades be ready for test pilots and what length are these?
cap231ex is offline Find More Posts by cap231ex
Old Sep 06, 2012, 12:51 PM
kin
Joined Sep 2007
Infact the test is finished , the market is some pilot using , and flying happy !it is 650mm x 42mm width , semi-symmetical .full carbon . paint in mold drak gray colour .weight about 120g . it fit to 600 fuselage especial the raise tail version . and also fit 700 size 4or 5 blades head . so i let this length between 600and 700 commen use . over 350 piece in market flying now maybe a little still in assemble their scale fuselage . But no complain .in fact no MFG let the product in the topic . the market also have good and bad commend half /half . So no one set a topic about their products especial this sensitive parts . but my concept is different , maybe !!! i just want let you have a safty blades and let the scale helicopter more fun . more good scale !!! Because i like better scale .So i like the scale is not only in the outside (Skin ) inside also need scale look..rotor head is the next target . the scale blades will have 325mm and 430mm and 600 and 680mm coming out , the 780mm already completed .
Old Sep 18, 2012, 06:31 PM
Sunnyvale, CA, USA
Joined Apr 2000
Any news on when the 680s will be available? I have started flying with the 650s and they are very promising so far.
teamdavey is offline Find More Posts by teamdavey
Old Sep 18, 2012, 08:38 PM
kin
Joined Sep 2007
Oh sorry 680 in November . but now is doing the 780mm for 800 size . and 650 mm selling very good . Their commend is (nice ) .
Old Sep 19, 2012, 11:59 AM
Horseman's Avatar
The Netherlands
Joined Aug 2008
Hi Kin,
Is that 680 also asymmetrical?
Jan,
Horseman is offline Find More Posts by Horseman
Old Sep 19, 2012, 11:45 PM
kin
Joined Sep 2007
Originally Posted by Horseman View Post
Hi Kin,
Jan,
The mold still plan in next month , have to time can change the airfoil if customer have some request , but i have plan it in semi symmetical . but if some guy want it symmetical i can make one more mold .
Old Sep 21, 2012, 07:24 AM
Horseman's Avatar
The Netherlands
Joined Aug 2008
The mold still plan in next month , have to time can change the airfoil if customer have some request , but i have plan it in semi symmetrical . but if some guy want it symmetrical i can make one more mold .
Hi Kin,
That would be nice if there came also CCW Asymmetrical multi blade sets on the marked but I guess that the marked are not that big for that kind of special blades. otherwise please people respond on this.
But symmetrical scale blades can be used both sides and have (I think) enough marked to justify the investment of a second symmetrical mold.
Kind regards,
PS, good to hear that your second batch of blades are performing well as expected.
Jan,
Old Oct 08, 2012, 02:06 AM
kin
Joined Sep 2007
Smartmodel scale carbon blades 650 w/Turbine Hughes 500
Nice video for the scale blades 650mm and Turbine Hughes 500 ,A beautiful models and nice Centuryheli rotor head
http://www.rcgroups.com/forums/showt...15436&page=232
Old Oct 10, 2012, 01:58 PM
Sunnyvale, CA, USA
Joined Apr 2000
I was using the 650 mm blades on one of my models at the ScaleMasters. It was only set up a couple of weeks ahead of time so I was still essentially dialing myself in - still flew pretty well.
So far I am pleased with the performance to the extent that I expect to order a set of the 680s when available.
But - why the curved tips on a "scale" blades????
Old Oct 10, 2012, 11:25 PM
kin
Joined Sep 2007
I design it mainly for the eurocopter version . i can make straight tip end . it is no problem for me , but scale customer in big number in european i think .maybe wrong ! But i will make again more different type wing tip shape . . and thankyou for your flying and show in Scalemaster event . please post some photo your models in event ! thankyou . 680 will come out soon ! And Thankyou Mirko share the nice photo . The PHT2 is very nice !
Old Oct 11, 2012, 09:04 AM
Sunnyvale, CA, USA
Joined Apr 2000
Check HDFlyer.com for the Scalemasters. Mine is the Aloutte III which has Rotortechs on it. I will try to get pics of my As-350 up later which has the SM blades.
Old Oct 20, 2012, 09:37 AM
kin
Joined Sep 2007
Davey ! you are great !!!!!!!!! Happy to know you use Smartmodel 650mm carbon blades and help to get the Winner ! Super !!!!!!!!
Question 600mm scale rotor blades from SmartModel Horseman Scale Helicopters 11 Nov 01, 2011 12:46 PM
Discussion Smartmodel TFM-600-4 blades rotor head for 600 size wangzx Scale Helicopters 4 May 05, 2011 01:02 AM
New Product 600/700mm scale rotor blades from SmartModel Hoverup Scale Helicopters 67 Dec 03, 2010 07:49 AM
Discussion Smartmodel 450 scale rotor blades Piracy kin Scale Helicopters 4 Oct 19, 2010 08:47 PM
Discussion Smartmodel scale rotor blades for 450 size ! kin Scale Helicopters 172 Apr 13, 2010 02:17 PM
