Hi,
A (multicell) LiPo battery will typically have 2 connectors: A DC output (high current connector) A balance connector. Deans, EC3, etc that you described would be DC output connectors. Sometimes people use the same connector that comes on the battery, some people just prefer a specific type and solder their own to their batteries, chargers, cables, etc. Here is a very good website explaining the differences: http://www.tjinguytech.com/reviews/rc-connectors I would suggest reading most of the pages on his site, as they are a very good source of information. |
USA, AZ, Chandler
Joined Nov 2007
I looked at the Flyzone website and it appears that they use a proprietary battery connector made by SuperTigre, which I never heard of until now.
http://www.flyzoneplanes.com/airplan...010/index.html When you look at the Tx-R version, they show a SuperTigre to Deans adapter as an option you can buy seperately. Or, if you can solder, just decide on a popular connector such as Deans, XT60 etc. to make your own connections. If the stock battery is rated as 10C, that's a very cheap battery. Buying any battery with a rated discharge higher than 10C will make the motor run a bit stronger. Plus, the battery will have a longer service life. But with a basic setup like this it doen't make sense to pay a lot of bucks to get a 65C...15C to 35C would be appropriate. A battery with either a higher C-rating or mAH capacity will make a motor run stronger because the voltage drop will be less. Parkzone makes a low C-rated 3s 1300 they use in their P51 for one, but it is way over-priced and has EC3 connector. Any 1500 should be just a little more weight, but keep in mind different mfrs list different weights for 1500 mA batteries. If the battery is near or centered on the CG it won't affect much except make the plane a tiny bit heavier, if the battery is not near the CG you will have to move the battery and/or add weight to restore the CG to be on target. The extra weight of a 1500 will very slightly degrade the handling characteristics (but that is subjective) but give you more flight time. Sometimes when a plane is very floaty and there's a fair amount of wind, you would consider adding weight to IMPROVE the handling characteristics. |
| Thread Tools | |
| Wanted 6S 5000+mah Lipo 10C - 20C | rchelijc | Aircraft - Electric - Batteries & Chargers (FS/W) | 3 | Jul 15, 2012 11:09 PM |
| Sold Different Charge Wires, Deans, XT-60, EC3, Traxxas | Mtrchs | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | Jun 04, 2012 12:26 PM |
| For Sale 4 zippy 1800 2s 20c lipos with deans | 62 bugzilla | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Apr 06, 2012 12:57 AM |
| Sold 2 20c 3 cell ZIPPY 3000 mah LIPO/deans 45. shipped | ryramZ | Aircraft - Electric - Batteries & Chargers (FS/W) | 3 | Mar 24, 2012 08:07 PM |
