Old Aug 12, 2014, 03:34 AM
Australia, QLD, Barcaldine
Joined Aug 2013
Question
Are Wltoys and OrangeRx transmitters compatible?
My Wltoys F929 aeroplane arrived today and I had expected to be able to bind it with my OrangeRx transmitter but it doesn't. A Google search revealed that the Wltoys transmitters are not compatible with the Spectrum DSM2 transmitters and since the OrangeRx transmitter is a DSM2 transmitter I suppose that's why it won't bind.
Is there a way around this binding problem? I expect not, but I thought I'd ask anyway.
I tried a DeVention transmitter that came with my Ladybird quad but that didn't bind either. I also have a no-name transmitter that came with another quadcoppter but I haven't tried it in case it does bind and I'm then stuck with a very short range set up.
Outback_flier is offline Find More Posts by Outback_flier
Old Aug 12, 2014, 10:23 AM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
http://www.rcgroups.com/forums/showthread.php?t=1953649
also read post #18 on that thread.
cmdl is online now Find More Posts by cmdl
Old Aug 12, 2014, 10:41 AM
Canada
Joined Nov 2000
Put on workboots, Place WLthing on ground.
Jump up as high as you can, landing on top of the thing.
Repeat as necessary.
Problem fully solved :-).
Arguably drastic, but decidedly effective.
Bare is offline Find More Posts by Bare
Old Aug 12, 2014, 07:15 PM
Joined Aug 2013
Thanks cmdl for the link. I read through it and the associated links and the only conclusion that I could make is that the module might work with the OrangeRx transmitter.
The cost of the module is greater than the Wltoys transmitter so I don't think that it's worth the trouble. I did discover that the no-name transmitter that I have is actually a Wltoys transmitter (a V959 I think) and the binding process worked without any effort. Now to check the range.
Your suggestion, Bare, might be a little premature. The 939 is an amazingly light and small aeroplane and it looks like it should be a lot of fun.
Old Aug 13, 2014, 11:42 AM
Dragons, Windmills. All Same.
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
"Put on workboots, Place WLthing on ground.
Arguably drastic, but decidedly effective. "
Perhaps sharing "How to properly handle the Hitec Feather RX"
Jared
jcstalls is online now Find More Posts by jcstalls
Discussion Is my Devo10 transmitter and Wltoys V626 Compatible? ebike Multirotor Talk 1 Mar 19, 2014 04:40 PM
Discussion Is my Devo10 transmitter and Wltoys V626 Compatible? ebike Beginner Training Area (Heli-Electric) 0 Mar 19, 2014 11:41 AM
Wanted OrangeRX Open LRS 433MHz Transmitter 1W ( JR Compatible) faitron Aircraft - General - Radio Equipment (FS/W) 0 Mar 07, 2014 12:10 AM
For Sale [Vic/Aus] OrangeRX DSMX/DSM2 2.4GHz Transmitter Module (Futaba Compatible) Brand New. Felixrising Aircraft - General - Radio Equipment (FS/W) 3 Mar 06, 2014 05:26 PM
Discussion WLtoys v949 bind issues with OrangeRX Transmitter rookiejas Mini Multirotors 2 Mar 12, 2013 07:00 AM
