Old Nov 13, 2008, 06:34 PM
andybuilder is offline
Find More Posts by andybuilder
Half scale electric builder
Knife edge square loop
The guys in my rc club in the UK are having a massive fall-out about whether a square loop can be done in knife edge. Watching some of the 4D footage on youtube would it seem that is is possible. Can anyone enlighten me (and my club) as to whether this move is possible.....this being a vertical square loop, in knife edge.....so knife edge along, snap 90 to go straight up, snap 90 to travel back in knife edge, and then the fun one - snap 90 to dive down and another snap 90 to pull back into the starting knife edge position.
Please help, its now a heated debate.
andybuilder is offline Find More Posts by andybuilder
Old Nov 13, 2008, 06:43 PM
mattk0 is online now
Find More Posts by mattk0
mattk0's Avatar
United States, MN, Apple Valley
Joined Jan 2004
Hmmm. Intriguing question. I honestly don't see any issue with the first 3/4 of the loop, but doing a 'quick' 90 while going down and pulling back into starting position would snap-out on every plane I've flown. Maybe more knowledgable physics/modeler members can speak up.
[edit] I would think a lot depends on the model too. It seems the lighter foam planes would have more potential of making that last corner 'snappy' as opposed to a larger/heavier planes.
mattk0 is online now Find More Posts by mattk0
Old Nov 13, 2008, 06:48 PM
Xpress.. is online now
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
Yes, it's entirely possible, if you have the guts to perform the last leg, and the height to. You will have to get your timings right with the throttle, and having a trimmed out model on knife edge for it to look clean. I know several variations of a knife edge loop are done with smaller indoor foamies, but they fly on knife edge as well as they do fly on the wing(s).
Xpress.. is online now Find More Posts by Xpress..
Old Nov 13, 2008, 06:51 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
possible, but most planes don't have the yaw authority to keep the corners tight.
theKM is offline Find More Posts by theKM
Old Nov 13, 2008, 07:45 PM
Neil Morse is online now
Find More Posts by Neil Morse
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
My RC Factory Yak will do it, although the last turn really takes a lot of nerve to pull off. So far, I have only attempted this at a comfortable altitude. I decided to try it after seeing the great 90 degree flat rudder turns that this model will do, both upright and inverted. It has less side slip coupling than any model I've flown. The only thing I'm not sure I understand about your description of the square KE loop is the term "snap" to describe the 90 degree turns. I just do 90 degree turns in KE with rudder only. This is not a "snap." If you're talking about some kind of snap roll at the four corners, then that's something different that I don't quite understand.
Neil
Neil Morse is online now Find More Posts by Neil Morse
Discussion AFPD Knife edge loop RCFlyer55 Simulators 2 Jan 24, 2007 06:22 PM
E3D Knife Edge Help Ninjak2k Sport Planes 5 Aug 23, 2002 07:02 AM
Diablotin Mini Knife Edge Roll Coupling Matt Fritz Sport Planes 17 May 09, 2002 12:19 PM
Another knife-edge qn stuartaw Competition Aerobatics 7 Feb 19, 2002 10:43 AM
What's the best way to enter a knife-edge? Ben74 Competition Aerobatics 3 Jan 26, 2002 10:25 AM
