Old Apr 26, 2002, 06:52 AM
steve f is offline
Find More Posts by steve f
Byram Twp. NJ
Joined Dec 2000
Zagi Elevon/Aileron Question
I've never flown a plane with elevons before and right now I'm in the process of finishing up a Zagi. My servos and rx are installed and I'm trying to set up my Flash 5 tx for the plane.
The elevons are working OK. In other words, when I push down on the stick, both elevons come up and vice versa.
But when I push the stick to the right the right aileron comes up AND the left one goes down. Is this correct?
Sorry for what is probably a very basic question, but all of my other planes are rudder/elevator only and I just want to be sure.
Steve
steve f is offline Find More Posts by steve f
Old Apr 26, 2002, 07:29 AM
sdl3 is offline
Find More Posts by sdl3
Atlanta,Ga
Joined Mar 2002
That should work fine.
Steve
sdl3 is offline Find More Posts by sdl3
Old Apr 26, 2002, 09:22 AM
sukhoi26mx is offline
Find More Posts by sukhoi26mx
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
steve f,
Just to confirm... You said
"The elevons are working OK. In other words, when I push down on the stick, both elevons come up and vice versa. "
I try not to think of the stick as pushing up or down... More like in a full scale airplane of pulling back or pushing forward. I'm sure you've got it right but when you pull back (towards the base of the TX, the elevons go up and when you push forward (towards the antannae) the elevons go down.
It sound like you're ready to roll.
Have fun, (Its nearly indestructible)
Scott
sukhoi26mx is offline Find More Posts by sukhoi26mx
Old Apr 26, 2002, 09:58 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
Sounds exactly right to me. Elevons should work as both elevators and ailerons.
mkirsch1 is offline Find More Posts by mkirsch1
Old Apr 26, 2002, 10:05 AM
steve f is offline
Byram Twp. NJ
Joined Dec 2000
Thanks for the replys. But, my question is "Is the left aileron supposed to go down and the right aileron go up when the stick is moved to the right for a right hand turn?"
Old Apr 26, 2002, 10:11 AM
Scott Stoops
sukhoi26mx's Avatar
Joined Mar 2002
Absolutely... Right hand turn = right aileron up/left aileron down
Left hand turn = left aileron up/ right aileron down
HAVE FUN!!!!!!!!!!!!!!!!!!
Scott
Old Apr 26, 2002, 12:40 PM
steve f is offline
Byram Twp. NJ
Joined Dec 2000
Thanks again. Seems I set it up correctly. Should be finished over the weekend. Just have the winglets to put on, set the throws and balance.
Steve
Question Zagi - Elevon Deflection Question Phoenix-IT Foamies (Kits) 6 Oct 28, 2004 01:49 PM
Zagi Servo/Aileron setup question max throttle Foamies (Kits) 2 Jun 26, 2003 02:30 AM
Zagi Elevon Question Phoenix-IT Foamies (Kits) 8 Mar 06, 2003 11:32 AM
Aileron Question??? Don Sims Electric Plane Talk 6 Jul 29, 2001 08:37 AM
45 Degree Angle in Zagi Elevon LE..Help Plez! MrPeabody Foamies (Kits) 3 Apr 23, 2001 11:13 PM
