Old Jun 11, 2015, 12:10 AM
RcPro97 is offline
Find More Posts by RcPro97
Joined Nov 2014
Car audio amp problem
Hi everyone. I bought a broken car amp in hopes that I could fix it and get it going again. The guy I bought it off said that it suddenly stopped working. The amp is a soundmagus Q-150, 4X150Wrms.
It powers up, as normal. The power light comes on, and then the protection light turns off about a second later. I only have 2 speakers at the moment to test it, so I am bridging it to make it 2 channel. I hooked 2 speakers to it and one just hisses, and the other makes a ticking like a clock. When I try powering it with only 1 speaker connected it just 'ticks', no matter what channel it is connected to.
I measured the voltage of the power supply and it gives a steady 32V and -32V, which is exactly what I would have expected. The voltage does not drop when speakers are connected and it is trying to play.
One of the 3300uf caps on the power supply was a bit swollen, so I replaced it with a 4700uf, because that's what my electronics store had available. I will get the right size eventually. But I figured that it would not matter on the power supply for testing.
I have taken all of the audio transistors off the board and tested them individually. They all appear to be in good shape, they are behaving exactly as I expected.
I also measured the voltage to the microcontroller, which measured 6V.
The last thing I can think of is if something is wrong with the section which takes the input signal, works out the output and supplies this to the transistors. Obviously this is going to be a bit harder to test. I'm wondering weather someone else who might know a bit more about this than me could suggest what It could be. Weather anyone has had a similar problem?
RcPro97 is offline Find More Posts by RcPro97
Old Jun 14, 2015, 01:13 PM
Peacemakr40 is offline
Find More Posts by Peacemakr40
Peacemakr40's Avatar
United States, TX, Burleson
Joined Aug 2011
Your best bet would be to get a signal generator to feed each of the inputs and a scope to track the signals. You can also check the DC rails to see if you're getting any deviations or excessive noise. I would guess that since you haven't popped any fuses that your output section is still ok. Get 4 - 8 ohm 50 watt power resistors for your outputs. This way you can isolate channels. If you have a bad component in your protection circuit, it will cause similar symptoms.
Peacemakr40 is offline Find More Posts by Peacemakr40
Old Jun 16, 2015, 08:53 AM
Xfactor940 is offline
Find More Posts by Xfactor940
United States, NC, Durham
Joined Apr 2011
you can find a generator program for the pc and feed the inputs off the pc's sound card using a 1/8 stereo to rca adapter. But you need a scope to verify your generators output and amplitude.
Xfactor940 is offline Find More Posts by Xfactor940
Reply With Quote  (Disabled)
Old Jun 16, 2015, 08:59 AM
Joined Apr 2011
you can find a generator program for the pc and feed the inputs off the pc's sound card using a 1/8 stereo to rca adapter. But you need a scope to verify your generators output and amplitude before u troubleshoot.
Sold Boss ar2000m 2000w mono block armor series car audio amplifier amp FieldofDreamsFlyer Non R/C Items (FS/W) 0 Apr 02, 2014 09:27 PM
Sold Boss ar2000m 2000w mono block armor series car audio amplifier amp FieldofDreamsFlyer Non R/C Items (FS/W) 0 Mar 31, 2014 08:03 PM
Sold Boss ar2000m 2000w mono block armor series car audio amplifier amp FieldofDreamsFlyer Non R/C Items (FS/W) 2 Mar 26, 2014 07:55 PM
For Sale Boss ar2000m 2000w mono block armor series car audio amplifier amp FieldofDreamsFlyer Non R/C Items (FS/W) 0 Feb 15, 2014 11:35 AM
For Sale Boss ar2000m 2000w mono block armor series car audio amplifier amp FieldofDreamsFlyer Non R/C Items (FS/W) 0 Feb 10, 2014 12:05 PM
