Old Jan 23, 2015, 10:24 PM
I beat the man from Atlantis
United Kingdom, England, Lincoln
Joined Dec 2013
6s flies this a beaut ;-) should be good for bungee if your familier with launching that way ;-)
I have my elev servos in the vertical stab atm but I'm going to remove them and place them directly in the horizontal stabs (like herb did)
Also gonna upgrade the fan and motor, but keeping it on 6 cells as it is plenty quick enough ;-) keep us posted as perseverance pays off with this model ;-)
Coddy is offline Find More Posts by Coddy
Old Jan 24, 2015, 04:07 AM
porkster's Avatar
United Kingdom, England, Bury St Edmunds
Joined Jul 2013
Thanks Coddy, I'm pretty happy to bungee launch, although I'd love to put in a nice set of scale retracts. Without access to a concrete or Tarmac runway this would be pointless I feel and just add weight.
I'm taking my time with it for two reason, 1, I want it to be very nicely finished. 2, I keep buying other stuff so spoiling my budget for this plane!
Pleased it should be good on 6s too.
porkster is online now Find More Posts by porkster
Old Jan 24, 2015, 01:55 PM
United States, VA, Springfield
Mine flies just fine off grass with eflite 15-25 retracts and wire struts. Using pretty small wheels maybe 1 3/4 main . It helps to have 2500 watts on tap.
lrb75 is offline Find More Posts by lrb75
Old Feb 24, 2015, 02:12 PM
Quest for Speed!!!
Mike_eee's Avatar
Fremont,CA
Joined Aug 2005
From threads on the Mig 15 , its known the flaps on this plane does nothing..I am building the plane light with just 6 s ..so was wondering if I can omit the flaps all together and close it shut..Will it affect performance? any landing characteristics lost etc?
Mike_eee is offline Find More Posts by Mike_eee
Old Feb 24, 2015, 02:49 PM
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
I have them but they are not needed to fly it. they do very little to slow it down
davecrash is offline Find More Posts by davecrash
Old Feb 24, 2015, 10:34 PM
Quest for Speed!!!
Mike_eee's Avatar
Fremont,CA
Joined Aug 2005
will it land within a 400 feet AstroTurf runway without flaps?
Old Feb 25, 2015, 08:09 AM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
Yes it will, Its getting the approach speed down enough thats a little tricky. She holds the speed up pretty good. I'm running 7S at about 2300 watts. once its on the turf it will slow quickly.
Old Feb 26, 2015, 06:15 PM
Joined Dec 2013
i found the trick is to extend the glide IE hold it at about 3-4 feet off the ground when coming in for a landing..that way it it sinks nicely but it always comes in a little hot..not that it bothers me ;-)
Old Feb 26, 2015, 06:19 PM
Joined Dec 2013
Just thought id add, that iv ordered a few bits to change out in my mig for this year.
Iv gone for a cs 12 blade fan along with a Dr mad thrust 1600kv motor and as I mentioned it before, im also moving the elevator servos into the stabs..should make for a more positive feel on the turns (I hope!)
Old Feb 26, 2015, 08:41 PM
Double E's Avatar
Atlanta, GA
Joined Mar 2009
The 8s setup in my JTM L-39 is a good system. Wemotec Midi 90mm fan with an Arc 36-75-1 motor. Performs well on 8s but can also handle 9-10s if you are looking to push the envelope. My 12lb. L-39 flew around 150-160mph on 8s and close to 175mph on 10s with that setup.
Double E is offline Find More Posts by Double E
Discussion Hobby Topgun 90mm Mig 15 maiden flights! 4stripes Foamy EDFs 20 Jun 07, 2012 09:51 PM
Discussion new:4/15/2011Fiberglas hobbyking Kits: F22 dual 70mm Kit & 90mm MIG texbird Electric Ducted Fan Jet Talk 0 Apr 15, 2011 12:27 PM
New Product ProDesign Mig-15 90mm, test fly on page 2. ProDesign Electric Ducted Fan Jet Talk 27 Sep 03, 2009 09:32 AM
Video Mig-15 90mm ProDesign Fuel Plane Talk 2 Aug 18, 2009 12:46 PM
Sold NIB Wemotec Mig 15 90mm all-composite ARF FL62 Aircraft - Electric - Jets (FS/W) 1 Mar 05, 2008 08:53 PM
