Old Dec 01, 2010, 11:12 PM
VAPORIZED
pappy1's Avatar
Australia, SA, Adelaide
Joined May 2010
HobbyKing Decathlon Brushless Plug-n-Fly Tips And Tricks?
HI,ive got this plane coming from hobbyking ,Feel free to post your tips for this plane and modifications and pics so i and other people who own this plane can have a better experience
pappy1 is offline Find More Posts by pappy1
Old Dec 03, 2010, 01:05 PM
Quebec Aerotow Association
Charlescd's Avatar
Canada, QC, st-jean-sur-richelieu
Joined May 2010
Great Plane!
see here: http://www.rcgroups.com/forums/showt...ight=decathlon
I've flown this plane all summer in extreme wind. When everyone else was on the ground to scared to get their planes up, I was already flying.
weak point: the motor shafts. I replaced the motor with a towerpro 2409 and bought a dozen shafts. Since i was flying in the wind all the time, i had some wild landings and the shafts just don't hold up.
Happy flying.
Charlescd is online now Find More Posts by Charlescd
Old Dec 04, 2010, 07:45 AM
VAPORIZED
pappy1's Avatar
Joined May 2010
Hi Charlescd, i intend on using 2200 mah battery on this plane since it is very tail heavy.I will have to modify a new bat compartment,for the bigger battery.I will look in to the tower pro motor.NIce looking plane
Old Dec 04, 2010, 04:35 PM
Charlescd's Avatar
Joined May 2010
Hi,
I use 1300mah turnigy packs and get 10 minutes of flying time. I have 2200 packs for my Cessna and to fit those packs in there, you are going to have to cut out the entire middle section of the battery tray and then make a new battery door. You'll see what i mean when you get the plane. You'll get 20 minutes flight times with those.
Old Dec 04, 2010, 04:47 PM
Charlescd's Avatar
Joined May 2010
Here are some pictures
Old Dec 04, 2010, 08:04 PM
VAPORIZED
pappy1's Avatar
Joined May 2010
I was thinking of placing the battery vertically,there are some pics on the web showing this,ill give it a go i just want more flight time if i can fly for say ten mins then land,then fly another plane for a while then go back to the decathalon and finish of the bat ill be a happy chappy.Thanks for the pics I have also ordered the 1300 turnigy just in case the mod goes south.
Old Dec 05, 2010, 11:15 AM
Charlescd's Avatar
Joined May 2010
Another think i did was that i purchased the wheels from a multiplex funcub and built a second landing gear for tall grass. The wheels are light foam and are huge!!!!
Old Dec 09, 2010, 01:45 AM
VAPORIZED
pappy1's Avatar
Joined May 2010
Hi Charles.
I should get my plane very soon i just canceled the battery that was holding up the order.Is this the replacement motor you got for the plane?
http://www.hobbyking.com/hobbyking/s...idProduct=2046Also you got a link for the shafts for both of the motors ?
http://www.hobbycity.com/hobbycity/s...idProduct=7342Is this correct for the tower pro motor?
Old Dec 09, 2010, 07:29 PM
Charlescd's Avatar
Joined May 2010
yes sir. that's the exact same motor and the shafts.
If ever you need quicker shipping (I think you are in the U.S).
then go here:
http://www.headsuprc.com/servlet/the...lectric/Detail
Old Dec 10, 2010, 01:12 AM
VAPORIZED
pappy1's Avatar
Joined May 2010
Let me clarify,will the shafts from the towerpro motor fit the original motor in the decathalon?Ohh, and im an Aussie in Australia And for the battery mod im going to try use a 1500mah for the moment.
Old Dec 10, 2010, 12:31 PM
Charlescd's Avatar
Joined May 2010
Hi,
No. the original motor in mine was a different brand that hobbyking didn't even sell. I found the 2409 had the same specs and changed to that once i bent the shaft on the original.
Old Dec 10, 2010, 09:37 PM
VAPORIZED
pappy1's Avatar
Joined May 2010
Thanks Charles,I need to know if this would be appropriate for the towerpro motor.Hoping to get everything in my next order,plane should be here monday
http://www.hobbyking.com/hobbyking/s...idProduct=3738
http://www.hobbyking.com/hobbyking/s...idProduct=8237 Cheers
Old Dec 10, 2010, 10:42 PM
Charlescd's Avatar
Joined May 2010
Either one is good. as long as it's 3mm.
Old Dec 14, 2010, 02:57 AM
VAPORIZED
pappy1's Avatar
Joined May 2010
Hi charles got the plane,but it all looks a bit confusingCan you tell me if i am supposed to cut out the littlte indentation on the elevator?Have some more questions after
Old Dec 14, 2010, 10:15 AM
VAPORIZED
pappy1's Avatar
Joined May 2010
well i cut it out and joined them, should it be glued in the elevator to the fuse?
Discussion HobbyKing Decathlon Brushless Plug-n-Fly Scott Hannah Electric Plane Talk 56 Nov 03, 2013 03:46 AM
Mini-Review HobbyKing YAK 54 Brushless EPO Plug-n-Fly Review hobbykinglive HobbyKing 0 Sep 03, 2010 02:28 AM
New Product HobbyKing YAK 54 Brushless EPO Plug-n-Fly review liorz055 Foamies (Kits) 0 Sep 01, 2010 10:36 AM
