Old Apr 09, 2015, 09:47 AM
SplinterNL is offline
Find More Posts by SplinterNL
Build & Crash
The Netherlands, NB, Eindhoven
Joined Aug 2013
Yeah, and don't hesitate to (re)create some parts as test beds for your painting - your model is absolutely worth a good paint job!
SplinterNL is offline Find More Posts by SplinterNL
Old Apr 19, 2015, 11:54 AM
shadowariez is offline
Find More Posts by shadowariez
Arch Angel Aries 7
shadowariez's Avatar
United States, IL, Romeoville
Joined May 2013
has anyone used and elfite safe recover in this aircraft? if so may i ask how did you set it up for the flight mode on a dx6i?
shadowariez is offline Find More Posts by shadowariez
Old May 06, 2015, 05:03 PM
Ratita77 is offline
Find More Posts by Ratita77
Joined Feb 2014
Hello,
I made the profile SU37 last year, and still flying. Very pleased to get this model. I crashed it 2 times at first and i wasn't sure to repair it with the last one but one day, i took the hot glue and still enjoying (foto before crash and not finished. Just got this one right now).
I'm thinking in making this version, but in 120% because i want something bigger than the standart one, but i don't want to get something too big (too expensive).
I would like to install the TV system, and a little landing gear retractable. I don't want to make a scale one, just something nice to see and fly with some nice details
Probably 2x2826-2200kv (same motor as my actual version) with 40A. I didn't thought about the lipo right now.
I read before that the weight could be a problem with the 120% version, and with all i want, maybe i'm on a hard way...
So, what do u think about this project ?
PS : sorry about my english !
Thanks 4 reading
Ratita77 is offline Find More Posts by Ratita77
Old May 10, 2015, 07:00 AM
Torsten288 is offline
Find More Posts by Torsten288
Germany, SN, Dresden
Joined Nov 2008
Hi Ratita77,
if you have a look at #1984 you will see my 120% SU-37.
With 3S2200mAh accu she needs additional weight of 90g in the nose cone to get the CG right.
This SU-37 made over 100 flights and is still in very good shape.
At the moment a second 120% SU-30 MK is waiting for maiden flight. This model was modified to carry 3S3200mAh accu. To place such an accu into the SU-37 I had to cut a gap to the frontmost bulkhead. Some additional weight of 30g was still necessary.
This model at 120% is no problem, but you have to consider to place as much weight as possible in front of the CG. A landing gear would be awkward to balance the model.
Good luck!
Torsten
Torsten288 is offline Find More Posts by Torsten288
Old May 16, 2015, 10:33 AM
DepRon S is offline
Find More Posts by DepRon S
Netherlands, LI, Weert
Joined May 2015
depron SU37
Hi there,
Last year I built a XL version of the Steve Shumate SU37 (approx 140%)
Specs:
Depron 5mm
Wingspan: 1100mm / 43 inch
Lengt: 1560mm / 61inch
Weight: 2.6 kg / 5.7lb
Engine: two 70mm EDF 4s
Retracts
Canards
Depron SU37 (Steve Shumate) (1 min 18 sec)
Depron SU37 (Steve Shumate) (1 min 41 sec)
Greetz,
Ron Stals
Netherlands
DepRon S is offline Find More Posts by DepRon S
Old May 16, 2015, 11:58 AM
T3chDad is offline
Find More Posts by T3chDad
(TechDad) Bob Templeton
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Great job! That's something to be proud of.
T3chDad is offline Find More Posts by T3chDad
Latest blog entry: Latest Projects...
Old May 31, 2015, 10:22 AM
Atindra is offline
Find More Posts by Atindra
Balsa Snob - Mostly
United States, PA, Riegelsville
Joined Jul 2001
Originally Posted by DepRon S View Post
Hi there,
Specs:
Depron 5mm
Retracts
Canards
Ron, that is a super job. Can you share some info about the type of retracts and the canards (fixed ?)
Thanks!
Atindra is offline Find More Posts by Atindra
Old Jun 03, 2015, 01:12 PM
DepRon S is offline
Joined May 2015
Thanks!
Hi Atindra,
The retracts I used are from hobbyking, digital servoless retract system 54 gram. Approximately $9,- a pice. (The total setup is from hobbyking)
The canards are working on a 9 gram metal gear servo. I programmed the canards on a separate channel so I can switch them on and off. They are working as an elevator, not as tailerons. (Both canards are linked by a carbon spar 4mm).
Greetz, Ron
Old Jun 16, 2015, 04:07 PM
DepRon S is offline
Joined May 2015
Here are a fiew action photos of my SU37.
Greetz, Ron Stals
Hi there,
Specs:
Depron 5mm
Retracts
Canards
https://youtu.be/ABcipVhF6mI
https://youtu.be/OOYXwP2Dd8o
Greetz,
Ron Stals
Netherlands
Old Jun 16, 2015, 08:19 PM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
Awesome work!
Old Jul 29, 2015, 03:05 PM
Arch Angel Aries 7
Joined May 2013
Originally Posted by headlessagain View Post
This is for anyone who wants a nimble indoor model for those cold days when only indoor flying is possible.
My brother has always been a fan of the Flanker and decided to make a 200% version of an earlier depron indoor model that used the guts from a Silverlit twin and I persuaded him to build one for me
Came out at 550mm span and 660mm from nose to tail. Motive power comes from two HobbyKing 10 gram 2000 kv motor's running cut down normal and contra rotating 5 x 3 quad props. The good thing is that a single Plush 10 esc works perfectly. I'm running a 4 channel Orange RX and a couple of small digital servos. Nothing smaller available so I used a 500 3s pack.
I'm trying to persuade him to do a build log but in the absence of one I thought I'd post my maiden video. Paint to follow once I swap out the servo that failed at the end of the flight
Two are already up and flying at out indoor sessions (my brother and John Stennard of Q&EFI mag fame) and I'll be joining them on Friday. These might even replace our Sumo's as the weapon of choice for indoor combat.
http://www.youtube.com/watch?v=OCvK-...rhjgkqnzl3bjcw
Andy
did you scale up 200% or down 200%?
Old Jul 29, 2015, 03:24 PM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
It's a 200% scaled up version of the original Aero Ace Toolbox designs.
http://www.aatoolbox.no-ip.org/
Click on the 2nd pdf for the model named "Flankerish" and use something like Adobe 10, Scale and Tile or PosteRazor to up scale and print out plans.
Andy
headlessagain is offline Find More Posts by headlessagain
Old Mar 30, 2016, 08:21 PM
kjhartwell is offline
Find More Posts by kjhartwell
Joined May 2012
Where can I buy clear plastic canopies for your designs? They really give the models a more scale look. I am going to attempt a twin edf build on this one. Don't know if there is a build thread for that, but suspect there is.
kjhartwell is offline Find More Posts by kjhartwell
Old Mar 30, 2016, 09:18 PM
T3chDad is offline
T3chDad's Avatar
USA, AL, Huntsville
Joined Apr 2007
6mm Fly RC
Build Log Super Bandit Park Jet jetset44 Pusher Prop Jet Models 1094 May 04, 2016 08:36 PM
Discussion SU-38 super Flanker... pps/ going e-power Insanety Pusher Prop Jet Models 2 May 02, 2008 09:47 AM
Video Sukhoi Su-37 Maiden Flight Nadim Electric Plane Talk 2 Jul 12, 2007 04:41 AM
For Sale Walkera SU-27m/SU-35 Super Flanker $100 skotbro Aircraft - Electric - Jets (FS/W) 3 Dec 06, 2006 08:42 AM
Power set up for Great Planes Sukhoi SU-31 3D Profile Park Flyer Airplane? ChrisK7 Beginner Training Area (Aircraft-Electric) 0 May 14, 2005 06:15 PM
