Old Feb 06, 2002, 01:17 PM
E-Minn is offline
Find More Posts by E-Minn
E-Minn's Avatar
Minnesota USA
Joined Oct 2001
TM Motor Mount Mods?
Do any of you have any mods that you have done to the motor mount on the tiger moth?
I think i am regretting using epoxy on mine already.
E-Minn is offline Find More Posts by E-Minn
Old Feb 06, 2002, 02:43 PM
Sloper Mario is offline
Find More Posts by Sloper Mario
Seņor Meember
Sloper Mario's Avatar
Joined Sep 2001
The only thing I did to mine was drill a hole in the mount so I could run a tiny screw through the mount into the wood to hold it.
Mario
Sloper Mario is offline Find More Posts by Sloper Mario
Old Feb 06, 2002, 04:39 PM
Darren Hintze is online now
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
I didn't modify the mount, but I used that thin double-sided sticky tape GWS provides to hold the plastic on the center of the bottom wing to hold the mount onto the stick.
That tape doesn't too well at holding the wing. It works great holding the motor.
On my first moth I ended up just wrapping the stick in packing tape after the motor became loose. That solved the problem too.
Darren Hintze is online now Find More Posts by Darren Hintze
Old Feb 06, 2002, 04:43 PM
T6Junkie is offline
Find More Posts by T6Junkie
T6Junkie's Avatar
Homer Glen, Illinois, United States
Joined Sep 2001
Motor Mount mod
E-Minn,
I made a small mod to my motor mount stick which has worked out great. I drilled a 1/16" hole all the way thru the mount/stick. I then used a piece of .060 cf rod and ca'd it into the wood. This makes the wood just about bullet proof. This can be done after the stick is glued into the fuse. I had to since I broke my stick off on a vertical landing.
T6
T6Junkie is offline Find More Posts by T6Junkie
Old Feb 06, 2002, 06:45 PM
marauder is offline
Find More Posts by marauder
Central Texas
Joined Nov 2001
E-minn, I drilled a hole horizontal thru the gearbox side and wooded mount then slid a T-pin thru it and cut the pin off about 1/4 of an inch long.
I use a dental rubber band, at least I'm getting something for my 100 dollar a month kids dental visit, to secure the pin in place.
As I need to oil the gearbox and motor I just slide the pin out and off comes the gearbox, sweet and simple!
Maybe part of the reason I'm still on my first motor after 4 or so months.
Lynn
marauder is offline Find More Posts by marauder
Old Feb 06, 2002, 10:29 PM
E-Minn is offline
E-Minn's Avatar
Minnesota USA
Joined Oct 2001
Thank you all!
Thank you all for responding to my post!
If any more ideas I thank you also!
TM Motor Mount MadDog Flaherty Parkflyers 2 Oct 05, 2002 11:32 AM
best method for TM motor mount replacement amike_321 Parkflyers 4 Sep 05, 2002 01:54 AM
suggestions for smashed TM motor mount? DanB Foamies (Kits) 3 Aug 12, 2002 10:42 PM
New TM motor and mount.. Sparky Paul Parkflyers 4 Jul 15, 2002 02:07 AM
TM motor mount alignment special K Parkflyers 8 Nov 23, 2001 06:41 PM
