Old Jul 17, 2001, 10:50 PM
engr is offline
Find More Posts by engr
Scarborough, Canada
Joined Nov 2000
Motor overheating in Tucano
My speed 400 motor is getting very hot after flights.. There are cooling slots in the front of the firewall and a couple of slots on the side for cooling.. but it doesn't seem to get enought airflow. This is for the Tucano, I've built it to plans. Does anyone else have this problem? How should I go about increasing airflow to the motor? it is all enclose. I was thinking of adding a airscoop but it will counteract the cooling slot in front causing airlock..
engr is offline Find More Posts by engr
Old Jul 18, 2001, 12:34 PM
SheldonYoung is offline
Find More Posts by SheldonYoung
SheldonYoung's Avatar
Vernon, BC, Canada
Joined Jan 2001
I'm in the middle of building the Tucano and was wondering if the cooling would be adequate. The holes in the motor mount look great but the exits on the side seem small in relation. Isn't the rule of thumb that the exits should be two to three times as large as the intake?
I think I might add a duplicate set of cooling exits behind what is shown on the plans, or maybe even three for a grill-like effect.
There isn't any provision for cooling the battery compartment but it shouldn't get too toasty in there.
Nigel, any thoughts?
SheldonYoung is offline Find More Posts by SheldonYoung
Old Jul 18, 2001, 03:42 PM
Matthew Allen is offline
Find More Posts by Matthew Allen
Formerly of mcba fame
Matthew Allen's Avatar
Luxembourg
Joined Apr 2001
I believe you can now get air admitting spinners to aid cooling. Possibly Robbe.
Matthew Allen is offline Find More Posts by Matthew Allen
Old Jul 18, 2001, 04:09 PM
FLY ELECTRIC is offline
Find More Posts by FLY ELECTRIC
REGISTERED LUNATIC!
FLY ELECTRIC's Avatar
Carlisle, Cumbria UK
Joined Jun 2001
J yhink this may be something to do with the climate you enjoy!
Over here in the UK I don't know of anyone having this problem but even in the hottest summer we're lucky to get anywhere near the 30s!
In the kit I supply a CNC-cut motor disc which has holes exactly matching the motor front; there are 3 1/4" holes drilled in the "chin", and the two oval exit holes in the fuz. sides to match the motor can side slots.
The combination of these 3 airways seems to be MORE than enough cooling for ours, and we are using 6v motors with 8 x 800AR cells giving 7-8 mins flat-out aerobatics.
If your airways are the same, then it must be the hotter ambient temperature to blame. I could always send you the CNC cut disc if this would help.
As for battery cooling, again not a problem over here but if that is also an issue perhaps a scoop and an exit hole may help?
I'm sure I could put up with an overheating motor if we could have weather like yours over here!
Best wishes,
Nige.
FLY ELECTRIC is offline Find More Posts by FLY ELECTRIC
Old Jul 18, 2001, 04:18 PM
Vernon, BC, Canada
Joined Jan 2001
Excellent, that means in I won't have to cut any extra cooling holes. A small advantage of living in Canada.
Old Jul 18, 2001, 04:33 PM
engr is offline
Scarborough, Canada
Joined Nov 2000
Hi Nigel,
I do have cooling holes and the slot on the bulkhead, but the side vents don't match up to the vents in the motor.. perhaps that may be the problem.. but I've always wondered about this one, is that the cooling holes for the motor is behind the spinner.. is that still going to be effective? I guess I'll just cut another set of slots near the motor vents too..
thanks nigel!
p.s weather here is about mid 20's Celcius, so it's not overly cool, or hot either..
Old Jul 21, 2001, 04:07 AM
REGISTERED LUNATIC!
Joined Jun 2001
Hi Engr,
You may have touched on something significant in your last post:
Most of us in the UK use the excellent Paul Gunther push-on props. Whilst they are less scalish, they perform superbly in terms of speed and duration, what's more they DO allow cooling air into the front of the motor. Try one, I think this will both improve your performance AND cooling.
BTW - "MID 20s" ! ! !
We'd DIE for mid 20s! Today it is 12 degrees - quite warm for the Lake District in the summer!
Best wishes,
Nige.
Discussion New BL Motor Overheating in Blade CP Pro av8r Micro Helis 33 Apr 21, 2008 01:43 PM
Motor Break in dano287 Beginner Training Area (Aircraft-Electric) 7 Sep 09, 2001 11:59 PM
Litestick motor thrust in ounces? AW Parkflyers 10 Sep 06, 2001 09:53 AM
Motor Break-In hoppy Electric Plane Talk 7 Aug 01, 2001 08:57 PM
What and how to oil after motor break-in ? jnyoun Electric Plane Talk 3 Jun 05, 2001 09:18 AM
