Old Apr 23, 2015, 02:22 PM
jayxer is offline
Find More Posts by jayxer
Joined Oct 2007
scratch build newbie looking for help
I've been longing for a good scale F-5E for a long time. The Freewing hits the scale marks much better than previous offerings. But reports have it being tricky to fly, and needing to be flown FAST. I don't have a lot of options to fly bigger/faster models, so I am looking for something to be built light, but still scale.
I'm wondering how plausible it might be to take the eflite 28mm, and build myself a depron twin F-5. Thoughts from some of you accomplished modeler's? I read through Corsair Nuts larger T-38 and F-5N build threads, but I'm looking for something without all the bells and whistles, hand launched and belly landed on grass, in a park sized model. I assume there aren't any plans for something like this already. I'm not against creating them, I have access to 3D CAD software, I've just not done anything like this with it before.
jayxer is offline Find More Posts by jayxer
Old Apr 23, 2015, 02:47 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Considering the (F-5E Tiger II)
Length: 47 ft 4 in (14.45 m)
Wingspan: 26 ft 8 in (8.13 m)
Height: 13 ft 4 in (4.08 m)
Wing area: 186 ft (17.28 m)
and the (F-20) are almost the same
Length: 47 ft 4 in (14.4 m)
Wingspan: 27 ft 11.9 in / 8.53 m; with wingtip missiles (26 ft 8 in/ 8.13 m; without wingtip missiles)
Height: 13 ft 10 in (4.20 m)
Wing area: 200 ft (18.6 m)
You can get the F-20 plans here: http://www.parkjets.com/f-20-tim-h/
and a build thread here: http://www.rcgroups.com/forums/showthread.php?t=412333
Keep in mind these are designed as "pushers" so you will need lots of mods ..enlarge the plans to suit your scale
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Apr 26, 2015, 12:49 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Seeing as you are making this from depron, all you need is the formers, etc. I enlarged portions of these plans, and traced the parts, for a 30"WS version. About 40+" long. There are no parts on the plans. So tracing the parts is necc. Section of plans showing side keels, wing, and tail surfaces, need enlarging to desired size. CG is noted on plans and there is an actual airfoil used. It was intended to fly catapult launch.
I flew the original kit, and it is a great flyer/glider, verifying the CG.
If I ever remember having these plans and build it, I'll use it with a single oval exhaust. Could even go larger for one of the CS fans(about 5%) And this F-5E is quite scale in outline.
http://www.pennvalleyhobbycenter.com...odf5etiger.htm
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Apr 27, 2015, 12:48 PM
jayxer is offline
Joined Oct 2007
thank you both for the input!
Discussion newbie looking for pointers on first build. TrEmor Racking FPV Racing 8 Feb 04, 2015 11:45 PM
Help! Another newbie looking for help on prop/battery selection Flyswamper Power Systems 9 Dec 10, 2014 12:58 PM
Discussion My First Scratch Build, Looking for a little help with motors. MarylandFly Scratchbuilt Multirotors 8 Jul 17, 2014 12:52 PM
Help! Newbie looking to build quad - Almost done (need ESC help!) webdev77 Scratchbuilt Multirotors 14 Jun 20, 2014 05:53 PM
Discussion Newbie looking for guidance to build a heli from scratch brigade82 Electric Heli Talk 14 Aug 03, 2011 10:18 PM
